Question about Brother MFC-8460N All-In-One Printer
Clicking noise on power on and every print
My Brother MFC 8460 makes a clicking noise when i turn the machine on and every time something prints. Sounds like it is coming from the back of the machine. Have tried powering off, removing the paper try and toner cartridge, then powering back on. It still makes the same noise.
  • 101 Answers
This can be all that is pleased , main reason there is defect of lubrificant there where this it is necessary, recommend you to apply to nearest service.
Posted on Mar 07, 2009
Laser printer makes light clicking noise when idle
When idle is potentially the fuser unit, after heating and cooling. However the print quality issue associated with the clicking sound could indicate an electrical issue. The HVPS maybe faulty causing the print quality issue (due to dependant parts) and the electrical click. In any case I would recommend calling Brother and finding the nearest authorised service agent.
Oct 20, 2012 | Brother Mfc-9840cdw All-in-one Laser...
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Feb 12, 2010 | Brother MFC-8460N All-In-One Printer
Problems printing to Brother MFC 8660DN printer
Pull the paper tray, likley a small black lever to the left of the roller called the edge actuator is dislodged and hanging down. When in position the actuator should easily push up and appear flat next to the roller.
Dec 09, 2009 | Brother MFC-8660DN All-In-One Laser...
Clicking noise with MFC-8640D
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
Jun 24, 2009 | Brother MFC-8460N All-In-One Printer
Brother HL-5250dnt - Clicking Noise and not picking up paper
You may have to use a true Brother toner cartridge as I have the same problem with me MFC 8500. If I use a compatible cartridge it clicks and if I use a geniune Brothr cartridge it does. Brother direct brought this to my attention.
Apr 06, 2009 | Brother HL-5250dnt Laser Printer
Clicking noise
Sounds like a clutch has spun out to me...It's going to require tech.
Mar 13, 2009 | Brother MFC-8460N All-In-One Printer
Brother MFC 8460 N, all in one copier. Loud clicking noise (from tray area) when trying to make a copy, it will not do a copy now, says to load paper - tray has fresh, higher quality paper in it. Is this...
Make sure the stopper in the paper tray is snug against the paper. sounds like the paper is not properly in place and the tires are making the noise.
Could be it's trying to lift the tray and it can't, determine why; something stuck, out of place,
Jul 21, 2008 | Brother Office Equipment & Supplies
Brother mfc8440 clicking sounds while printing
I had the same problem when I used a refurb toner cartridge, had to replace cartridge with oem for it to print. After a while started making same noise, had to take it in to have parts replaced. Now I don't take any chances on non-oem parts, it's not worth it.
Mar 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8500 clicking noises
If you open the cover and remove the toner/drum unit, you will see (on the left side as you remove) a small hole with two triangle teeth.
on either side of this hole are two small phillips head screws. this is the problem we had with our clicking noise. As the machine tries to turn the toner/drum, the innards of the toner are becoming harder to turn. So the part of the fax machine that fits in the hole end up stripping the teeth in that hole. If you have an old toner cartridge, you can remove the gearing from it (where the small phillips head screws are) and use it to replace the gearing on the newer cartridge. Or go buy a new toner cartridge.
Jul 24, 2006 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC-8460N All-In-One Printer Logo
952 people viewed this question
James Cagle
James Cagle
Jim Keysor
