Question about Sony MegaStorage CDP-CX355 300-Disc CD Changer
NEED MANUAL FOR REMOTE RM-DX350 FOR SONY CDP-CX350 CD CHANGER
I DOWN LOADED O.M . FOR 355 BUT IT USES A DIFFERENT REMOTE , THIS REMOTE HAS A DISPAY ON TOP AND A FLIP OPEN DOOR .
5 Suggested Answers
SOURCE: Sony CDP CX 235 200 cd changer-cd's dropping off
Hi there.
I reckon that they are not being put back correctly by the loading mechanism! This is a common problem with these units. It is highly unlikely that they are actually falling off the carousel.
Open the unit, and watch it as it loads and replaces the cd's from the carousel. You will probably find that instead of grabbing the disc off of the spindle and putting it back, it might be grabbing before the cd is even in its grip. This then simply bumps the cd out of the way, and it will fall inside of the unit.
The good news is that it can be fixed with a bit of very gentle bending and persuading. But be very carefull when doing this!
Good Luck!
Posted on Mar 07, 2009
  • 263 Answers
SOURCE: Need to know if there's an online manual for Sony
esupport.sony.com/US/perl/model-documents.pl?mdl=CDPCX355
Posted on Aug 04, 2009
tech240
  • 169 Answers
SOURCE: My Sony MegaStorage CDP-CX455 400 Disc changer
Pretty much the only thing you can try at home is cleaning the laser lens, if the cleaner works then remember to use it now and again.
If the CD lens cleaner does not work the take it to the nearest sony tech/dealer for repair. Multi CD systems are very complicated and need specialist attention.
Hope this helps
Thanks for using FixYa
Posted on Aug 09, 2010
SOURCE: sony cdp cx 355 displaying table error
What worked for me was taking the cover off and carefully threading a belt back onto a wheel. There are two motors at the back of the unit, one (I believe) that grabs the discs and moves them in & out of the player, and a second one that rotates the table (i.e., the round slotted thing that holds all the discs). The belt had simply slipped off the wheel that drives the latter. I did remove the back panel as well, to access it better, and inadvertently disconnected a sensor plug, which led to a second round of troubleshooting, but - in the end - I got it working!
Posted on May 29, 2011
Disk does not play
you would probably need to have the laser replaced.
Feb 28, 2015 | Sony CDP-CX350 300-Disc CD Changer
What is wrong when jvc cd changer reads "no disc" even when disc is available?
I too have this problem with my Pioneer PD-X77M. It will not recognize the CD in the case & goes through all six saying NO Disc.
Jun 13, 2014 | Sony CDP-CX350 300-Disc CD Changer
Cd is not loading andrepeating trying to load
go to sony help support,you might be lucky and get an answer from them..they manufacture those cd players so they should know what the problem is...good luck
Aug 25, 2013 | Sony CDP-CX350 300-Disc CD Changer
Disc table does not turn but motor sounds as if turning
The gears are probally slipping Or some thing is broke on the mechanisim,Just get a different one ,It will cost you less then haveing that one repaired,
Dec 06, 2012 | Sony CDP-CX350 300-Disc CD Changer
I have a Sony CDP-CX350. I recently discovered the remote will not control anything on the player. The remote has fresh batteries and displays that a signal is sent out. The same display usually shows...
If you have turned it back on then this would indicate the receiving module that picks up the infrared signal is not working and has become defective, but I would double check your manual so nothing was over looked.
Jan 30, 2011 | Sony MegaStorage CDP-CX355 300-Disc CD...
I need the user manaual for a Sony Mega Storage 300CD
Click Sony Support to download user manual copy for CDP-CX355
If model number is different, let me know to provide you that manual copy.
Thanks.
Nov 04, 2009 | Sony MegaStorage CDP-CX355 300-Disc CD...
Sony MegaStorage CDP-CX355 300-Disc CD Changer Logo
404 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
