Error:0xc1ab0003 I keep getting the following error message: Error:0xc1ab0003 730:;lib_micci2_tango.c on my HP Photosmart 2575 All-in-One If I play with it long enough, it might print one copy (which prints out fine) then the message pops up again. HELP
O Erro: 0xc1ab0003 também ocorre na minha impressora, como faço para soluciona este problema e o que causa o mesmo?O Erro: 0xc1ab0003 também ocorre na minha impressora, como faço para soluciona este problema e o que causa o mesmo?
You can't post conmments that contain an email address.
Is this a Hp cartridge or a cheaper brand? I got this error myself too with cheaper cartridges. You cal solvo this error by buying the original Hp cartridges
I had this problem also and came to find out that in order to scan, you have to go into your "PAINT" and go to "FILE" and scroll down to "FROM SCANNER OR PRINTER" and then follow the instructions. It works!
did a search on hp website and found over 100 hits go here to find out what your error means http://h10061.www1.hp.com/ccsearch/search?pname=HP+Photosmart+2575+All-in-One&pid=441248&productBigSeriesOid=441263&spid=441240&opname=HP+Photosmart+2575+All-in-One&contextual_lname=&pname_desc=HP+Photosmart+2575+All-in-One+Printer%2FScanner%2FCopier&ptype=consumer&stype=pn&spname=HP+Photosmart+2575+All-in-One&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&qry=Error+codes&Submit.x=0&Submit.y=0&Submit=go
Please review the excerpt from HP technical support website
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&lc=en&cc=us&dlc=en&product=441240&rule=31105&lang=en
Use the instructions below to resolve the issue by restarting the product.
1.
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
2.
Open the cover of the product and remove the print cartridges.
3.
Close the cover and wait for the Insert Ink Cartridges message to display.
4.
Disconnect the power cord from the back of the product and wait for one minute.
5.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6.
Open the cover and reinsert the print cartridges.
7.
Close the cover. If prompted, print a calibration page.
8.
Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance.
Error:0xc1ab0003" have this same codew on hp 2575 all in one
I have the same problem
