Question about Casio Watches
Instrutions for setting time/time zone on casio lwa-100 felite
5 Suggested Answers
  • 13433 Answers
SOURCE: instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Posted on Jun 10, 2008
SOURCE: Casio Wave Ceptor WV-100 Manual Needed
you can download the manual on this website:
http://www.casio-radio-controlled.com/euro/support/
for the WV-100 the code is 2512
Posted on Nov 22, 2008
  • 183 Answers
SOURCE: How do I set my casio felite watch?
There are several models in the Felite line. To get setting instructions use the model number from the back of the watch to access instructions on the Casio website.
http://support.casio.com/manual.php?rgn=1&cid=002
Thanks!
Posted on Sep 19, 2009
SOURCE: HOW TO SET TIME ON CASIO FELITE LWQ-300LE-1EER
I found the manual on casio site: support.casio.com
Posted on Dec 29, 2009
  • 2501 Answers
SOURCE: how do i program ca
I presume that you need the city to set your time. This being the case, then you press the mode button to arrive at the city setting and use the 2 or 4 O'clock buttons to change the setting until it reaches "ATH", "CAI" OR "JED".
Then press the mode button to return to the normal setting (you willhave to press it several times)
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Posted on Mar 12, 2011
How do I change time zones?
denver to montana HUMMMM thought they were same time zone if not only 1 hr different
Feb 23, 2015 | CASIO, INC. Casio Protrek PRG270-1 Solar...
When I set my casio wave ceptor to my timezone and set the time correctly, the hands move to a different time. Both hours and mins. are off. When I set to zone 0, both hours and mins are correct. I am...
If your watch is exactly an hour out, then you need to set the daylight saving time (DST) via the mode button.
If this is not the case, then I cannot help you.
~Good luck
Mar 31, 2011 | Casio Watches
How do i program ca Casio Ladies Felite Watch - LWQ-300LU-7E for romania?
watches;
Accept terms
Mar 12, 2011 | Casio Watches
On my Casio G-shock GW500A, the time is off. i dont want it on 24time and its an hour ahead
Sounds like you're set for the wrong time zone, and your 12h/24h setting is off.
To change time zone: Hold down the adjust button until it beeps. Your time zone will be flashing at the bottom of the display. Use the Time Memo and/or Receive buttons to change it to the correct time zone. Then... To change to 12H mode: Press adjust again. 12H or 24H will be flashing at the bottom. Use the receive button to cycle the mode. When it's what you want, press adjust once more.
Feb 26, 2011 | Casio G-Shock GW500A-1V Wrist Watch
Got mine yesterday and its set on eastern time zone, i need pacific time zone and it will not sync, how to manually adjust ime
You should be able to set your watch to the Pacific time zone.
f you haven't got instructions on how to do this, you can get
watches;
Accept terms
You shouldbe able to find the setting method in the manual.
May 12, 2010 | Casio Atomic Timekeeping WV58A 9AV Watch
World time zones
It may be set to DST (daylight saving time), see instructions for changing this.
Select "support" and the "manuals", watches;
Accept terms
Mar 07, 2010 | Casio Baby-G Wristwatch
Dec 28, 2009 | Casio Watches
Thanks!
Sep 19, 2009 | Watches
Setting time
Forget it!!! Please cancel concern
Nov 06, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
116 people viewed this question
Top Casio Watches Experts
Jimmy Accardi
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
