Question about Philips FWM587 CD Shelf System
How to hook up to the tv or get sound from cable box
  • 8,596 Answers
Connect a red and white audio cable from either the TV's audio outs (if it has one) or the cable box's audio outs (it will almost definitely have one or two), and connect the cable to R/L audio in on the back of the Philips. Change the mode on the Philips to "AUX".
-Tha Mp3 Doctor
Posted on Mar 06, 2009
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
No sound on my fujitsu 50" plasma TV
its not hooked up right your cable box or tv manual should show you how, cable audio out, tv audio in left and right
Jun 15, 2013 | Fujitsu P50XHA10 50 in. Plasma Television
We just got a new cable box and now the Picture works but no sound. The volume is not muted on the tv or cable box. We've tried connecting the cable box three different ways and still get the same...
Does say a dvd player give sound when connected to the same input? If you have determined that the source is good and the speakers are turned on in the menu then I would replace the main board.
Sep 08, 2011 | Sony KDE-50XS955 50 in. Plasma HDTV
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
Apr 18, 2010 | Sanyo DRW-500 DVD Recorder
I have a cable box...(hddvr) and a TV cable set it up on video 2 now i bought a insigna home sound, how do i hook it up the user guide only shows me how to hook it directly to TV and its not working, so...
First, if you have the jacks in back of your TV for audio out, you may have to set the audio on the TV for external audio. Go to menu and then click on audio or audio options, and see if there is a mode for external or aux audio out.If that does not work, then use cables with the RCA ends and hook up from cable box to audio in or aux in of your surround sound system. Look at the back of the cable box for audio out or aux audio output and connect these two jacks to the audio in or aux input of your surround system.
If the cable box does not have extra audio out, you can take Y connectors and branch off the two jacks that are going to your TV. Radio Shack has these Y connectors. They allow two cables to be connected to one jack.
Hope this helps, if so Please rate, and Good Luck!
Aug 02, 2009 | Audio Players & Recorders
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Jul 23, 2009 | RCA Audio Players & Recorders
Vcr hook up
Have you tried to run:
Coax from the wall to your cable box.
Coax from the cable box out to the VCR cable in.
Coax from the VCR cable out to your TV?
What connections does your TV have? RCA or coax?
Mar 21, 2008 | Sharp DV-RW340U DVD Recorder/VCR
Sound is ridiculously low
if it is a stereo tv, there should be rca jacks on the back of the tv [red,white yellow] try connecting the rca outputs to a stereo system and see if the volume is any different.there might be a loose connection to the tv speakers inside.if you have a cable box hooked up to your tv, check the connections in back. you can also try bypassing the cable box by connecting the cable wire directly into the tv to see if it's the tv. if it is the cable box try unplugging it for a minute then hook it up again.i had the same problem with my cable box. hooking it up to a stereo system sounds like a pain, but at least you will have sound.
good luck
wg
Jan 30, 2008 | Toshiba 32AF44 32" TV
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
No audio
try to reprogram the channel. it seems that your tv's sound circuit is fine.
Jan 09, 2007 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Philips FWM587 CD Shelf System Logo
80 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
