Question about Refrigerators
My freezer/refrigerator is not cooling
My side by side refrigerator/freezer is not cooling. It is clean underneath, both fans are working but the compressor is very hot and clicks about every minute or two.
  • sprussell76 Mar 06, 2009
    Neither the freezer nor the refrigerator is working - the codes are flashing E (freezer) and F (fridge) where the temperature ususally is displayed
  • 27 Answers
There may be some problem with the starting relay of the compressor or the compressor itself may be faulty
Posted on Mar 06, 2009
The strip between freezer and refrig become hot then cools off. It's like it is going thru a cycle. We cleaned the coils underneath, but it is still getting hot and then in about 15 minutes, it's...
When you cleaned the coil underneath did ya notice that their was air being blown out their by a fan,having clened the coil was a good start but if the fan by the compressor isn't running that divider between the ref/freezer will be hotter than normal( its normally warm and thats ok),so check that the condenser fan is running and that it seems to running at a good speed.
GENE
Sep 23, 2011 | Whirlpool GC5SHEXNS Side by Side...
Gibson/Frigidaire GRS20ZRH - Refrigerator section does not cool. Freezer cools OK. Water and ice dispenser is OK. Model is a side by side. Underneath coil/compressor section is clean. Please advise....
Check your fan that goes from the freezer to the refrigerator. It is probably faulty. If not then check your defrost timer.
I hope this helps
Please rate me
May 27, 2010 | Frigidaire FRS3R5EMB Side by Side...
Freezer works, frig doesn't
there is a fan on many newer units that blows cold air from the freezer side to the frig. If that fan is not working, the frig will be cool, but not 34° like you want it.
Nov 25, 2009 | Frigidaire Refrigerators
Fridge is side by side Kitchenaid. Quit cooling, I defrosted and cleaned the coils. Turned it on fan is working, cool air blowing underneath the refrigerator. but can't tell if it's cooling the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 16, 2009 | Kenmore 57182 / 57184 / 57188 / 57189 Side...
Side by side, refrigerator works, but freezer does not The freezer just started thawing everything. We can still hear something running in the refrigerator.
This is unusual. The more common set of circumstances is that the freezer works but the refrigerator doesn't. The cold air in a side-by-side is produced on the freezer side and is than transferred throughout the freezer and to the refrigerator by a fan in the freezer.
You say you hear something running in the refrigerator. This could be the freezer fan. It is located behind an access panel in the freezer. This fan should run.
You should also hear the compressor (underneath the refrigerator) running. If this doesn't run, you will not get cooling. Also, there should be a compressor fan (underneath the refrigerator close to the compressor) running. This fan removes heat from the refrigerant coils and transfers the heat to the outside. If this fan doesn't run, proper cooling cannot be obtained.
Check these things out.
Oct 20, 2009 | Refrigerators
Freezer is not working and mass amount of water leaking frombelow
That is probably the compressor. There should be a fan close by. When the compressor runs, does this fan turn? The fan must work properly for the entire refrigerator to cool adequately. The purpose of the fan is to pull cool room air over the coils and remove heat. If this heat is not transferred to the outside of the refrigerator, the cooling cycle will not function properly.
If the fan is not turning, it will need to be replaced. These are readily available.
Oct 12, 2009 | Maytag MSD2650HES Stainless Steel Side by...
Won't freeze on freezer side ( defrosting) and won't get cold on refridgerator side
If you have confirmed that the unit is defrosting and the freezer isn't getting cold. Make sure underneath the refrigerator is completely clean and the fan is running underneath the refrigerator next to the coils. If this all checks out then you have a bad compressor or lost of refrigerant due to a leak in the system. One last thing: Is the cooling fan running in the freezer?
Oct 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer and refrigerator are not cooling
We called an appliance repair company and it was the Control Panel that was causing the problem. $317 later it is now working properly.
Dec 03, 2008 | Refrigerators
Whirlpool Gold 25.4 cu ft side by side
After cleaning the lint you need to give the unit at least 24 hours to recuperate. If you try letting it run for 24 hours and it still doesn't work let me know if the compressor (the main motor) and the fan underneath is working and the fan in the freezer is working.
Nov 24, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Warm fridge
how is the freezer side check theese and get back to me hold the rating till we are done is the freezer fan running as the freezer cools both sides is there heavy frost on the back wall of the freezer down toward the bottom is the compressor running is the fan that cools the compressor running are the coils underneath the unit clean is the ice cream to soft milk too warm
Mar 02, 2008 | Amana ASD 2624 Side by Side Refrigerator
Refrigerators Logo
208 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
