Question about Maxtor 1.5TB 7200RPM 16MB USB 2.0/FW400/FW800 Barracuda 7200.2 FireWire 400 (1394a) Hard Drive
1.5TB only showing 81 gigabyte
I have recently bought an external hard drive. Maxtor Basics Desktop. When I check the capacity by viewing Properties and then disc space, it is only showing 811 gigabytes.
The pc I connected to is on an XP platform, I then connected to my vista laptop and again it showed 811 gigs. I have been told that the problem may maybe that the bios my not be recognising the size.
Any advise would be welcome
Chris
  • 92 Answers
You got it man you have two reason for bios like you tell me and your partition table so download magic partition on your windows xp and you will be able to correct this easely
bye and good lock if you have other problem for this tell me
Posted on Mar 07, 2009
I dropped and dragged some sizable folders from a desktop onto the Maxtor external drive. When I plug the drive into a different computer, I only see the files that I put on the drive a year ago on the...
Several things could be happening.
1. the hard drive direct drive motor is giving out.
2. the hard drive is full.
3. the hard drive needs to be optimized ( that is defragmented) using the Windows defragment utility. If the drive is large it will take some time to complete.
Jul 22, 2011 | Maxtor Hard Drive
How do i reformat (NTFS) my maxtor Basics 160gb external drive to get it back to 160 - it only shows 149gb
it is usual, that you wont be able to access entire 160gb...certain amount of disk space will be reserved in the HDD for boot sector...
Sep 29, 2010 | Maxtor BASICS Personal Storage 3200...
Restore factory settings on maxtor basics external storage 1000gb
What do you mean by factory settings. From the factory, the drive came just formatted with no data on it. If you want that then format the drive in WIndows. My Computer->Select the drive that is Maxtor, right click it and in the box that opens format is one of the options. Select and follow instructions.
Nov 16, 2009 | Maxtor Hard Drive
I need to know the power rating for a Maxtor 160GB external Hard Drive for use with a Yamaha PSRs-900 keyboard. Yamaha requires the rating to be not greater than 500-600mA
The Maxtor STM901601EHD301-RK is part of the Maxtor Basics Portable family.
It uses a 2.5 inch Internal harddrive inside. (2 and a half inches across the Width. Same size used for a laptop. Desktop's use 3.5)
It connects with a USB Style A male plug, via the USB cable.
It's has a 160GB storage capacity, has an 8MB Buffer, (Cache), and an External Data Transfer Rate of 60 MegaBytes per Second.
Other than that, I find no more information from Seagate, (Seagate bought out Maxtor, and has the data base for Maxtor products)
http://hddlist.com/maxtor/all/maxtor_basics_portable
What I do know in reference to your question.
I know that the USB 2.0 technology uses 5 Volts DC. The Positive pin on the USB plug will support up to 5 Volts.
http://en.wikipedia.org/wiki/File:USB.svg
[Viewing a USB-A style plug, view it with the white plastic spacer at the bottom. Open part at top. The Positive pin is all the way to the right. The Negative pin all the way to the left. The Data + pin is on the left next to the Negative pin. The Data - pin is on the right, next to the Positive pin]
The Maximum current draw is 500 mA for a USB 2.0 port.
[ Current is rated in Amperes, or Amp's. You are looking at Millionths of an Amp.
Milliamp, or abbreviated as mA]
This would lead me to believe that the Maxtor Basics Portable external harddrives will not use more than 500 Milliamp's.
However I do not feel comfortable, telling you that it is okay to use your Maxtor STM901601EHD301-RK, on your Yamaha PSR2-900 keyboard. Would hate to be mistaken, and have you burn out the finals of your keyboard.
I do feel comfortable with the following suggestion.
What about transferring as much data as you can from the Maxtor Basics Portable, to a USB thumb drive? They have large thumb drives now, and hold a lot of data.
Most programs will fit on a large USB thumb drive.
Or am I missing the point somewhere?
Oct 20, 2009 | Seagate Maxtor OneTouch 4 Mini 120GB...
Maxtor Basics 320 GB external harddrive cant be recognized
There's a good chance the shop you bought the drive from didn't have SP3 installed. For some reason, SP3 has an issue with USB peripheral devices. Windows has created a patch to rectify the problem. Click on the link below and install the "Fixit" patch to enable your PC to recognize your HD. Best of luck.
Greg
http://support.microsoft.com/kb/925196#fixit4me
Jun 18, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Maxtor Basics external portable hard drive not getting detected
Right Click on My Computer, click on Manage, go to Disk Managment, if the drive is available you will see it there. Check to see if it has a drive letter assigned to it, if not right click on it and choose Change Drive letters. Make sure you are on the external drive though, you don't want to change your C drive accidentally. It should pop up in My Computer.
May 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Maxtor Basics 1Tb external hard drive not working
option 01. try the unit on another windows pc. if its the same. i am afraid you might have an issue with the device.
option 2 . you could remover the **** from the enclosure & fix it directly to the pc so that you can retrive the data. however this will have an impact on your warranty
May 23, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Open external drive maxtor basic 500GB
it may be like the one i have which is a maxtor basics 1.5tb drive. There is only one screw behind the sticker. The rest is clips. This is the guide i used when opening the case.
http://www.computer-aid.com.au/blog/2009/02/17/how-to-take-apart-a-maxtor-basics-external-35-usb-drive/
Mar 28, 2009 | Computers & Internet
Reformatting external Hard Drive
click on the hard drive and use the disc manager to format
or right click on the hard drive properties and use the format tab
May 11, 2017 | Maxtor BASICS Personal Storage 3200...
My pc dose not come up my maxtor basics external desktop hard drive
What OS are you using? Windows 98SE does not always recognize exterrnal hard drives. Try the external HD on a computer running Windows XP and see if that works. If it works on WinXP and not Win98SE or possibly WinME the External HD is good.
May 06, 2008 | Maxtor Hard Drive
Maxtor 1.5TB 7200RPM 16MB USB 2.0/FW400/FW800 Barracuda 7200.2 FireWire 400 (1394a) Hard Drive Logo
181 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
