Question about Dell Dimension 2400 PC Desktop
Pc does not save data or files when i restart
When i download or install or uninstall something my computer does not save the files or what i did to uninstall or anything its like i did nothing everything goes back to the way it was brfore i did anything anyone now how to fix this?
  • dallaspaint Mar 06, 2009
    well also its the files i download are not there after i restart
  • Rob
    Rob May 11, 2010
    Is this a work PC or home PC. If it a work PC and the machine cannot find a domain controller, it may be logging you on with a temporary profile, and thus not saving anything.
  • 374 Answers
Adware are common files that are coming in and out to you windows and sometime the firewalls is blocking your install files you can add this in exemption so it will not block the file,doing this click panel control,click firewall windows,click excemption and add the file you want so it will appear and install in your windows.
Posted on Mar 05, 2009
How to install about 4tch pc camera
Hello there,
Link
1 ) Press Download button to download the desired driver .
2 ) Save it somewhere where you will remember after download . We recommend that you save it on your desktop , so it will be easy to find .
3 ) After successfully downloading the driver , do not open the driver file until you make sure the following has completed : ***REMOVE / UNINSTALL any original mouse driver from the PC . ( If you forgot to do this part , your driver may not be able to install correctly and successfully later )
4 ) After the original mouse driver has been removed , open the downloaded file .
5 ) Follow the on-screen instructions .
6 ) When it's successfully installed , please restart your computer .
7 ) After you have restarted the computer , plug the webcam into your computer and it will automatically recognize the new hardware.
Jul 09, 2011 | A4tech PK-635 Webcam
I cannot intall my down load driver of A4tect cam
Make sure you FIRST uninstall and disconnect your webcam completely. Restart your computer, then run the installer, follow any directions given, then restart pc and connect webcam.
Failing this you need to give specific info as to your computer and O/S and what webcam software u are trying to use
Jan 16, 2011 | A4tech PK-635 Webcam
No software intaller
Click HERE! to download the software installer!
1 ) Save it somewhere where you will remember after download . We recommend that you save it on your desktop , so it will be easy to find .
2 ) After successfully downloading the driver , do not open the driver file until you make sure the following has completed : ***REMOVE / UNINSTALL any original mouse driver from the PC . ( If you forgot to do this part , your driver may not be able to install correctly and successfully later )
3) After the original mouse driver has been removed , open the downloaded file .
4) Follow the on-screen instructions .
5 ) When it's successfully installed , please restart your computer .
6 ) After you have restarted the computer , plug the webcam into your computer and it will automatically recognize the new hardware.
Jan 02, 2011 | A4tech PK-635 Webcam
I downloaded the software for the HP PhotoSmart C4480 on my Mac but when I try to print I get an error message that says Operation Could Not Be Completed client-error-not-possible. Is there a way to fix...
Are you sure that you downloaded the correct file ?
Please check to make sure.
If you did, then let's try uninstalling it and installing it again with a clean install.
>Turn off the Printer and unplug it from the computer.
> Go to Start/Control Panel>Install.Uninstall and scroll down until you find the printer software.
>Highlight it and Uninstall it.
>Turn off all running programs including your internet and virus control.
>Go to the file that you downloaded. It should be an 'exe' file. I always save mine to my desktop, so that I can find them. ( If you cannot locate the file you will need to download it again and save it to your desktop this time)Click on the file to install your software. When it is installed plug your printer back in to you PC and restart your PC.
Be sure to restart you virus control if it does not start automatically.
Try a print.
Please let us know if this works for you. Thank you.
Dec 21, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
How can i download driver for my a4tech cam
All you need to do is to click here and download the basic driver.
Instruction on How to download and install the driver properly :
  1. Press Download button to download the desired driver .
  2. Save it somewhere where you will remember after download. I recommend that you save it on your desktop, so it will be easy to find.
  3. After successfully downloading the driver , do not open the driver file until you make sure the following has completed : ***REMOVE / UNINSTALL PC cam PK-635 . ( If you forgot to do this part , your driver may not be able to install correctly and successfully later )
  4. After the cam has been removed, open/extract the downloaded file .
  5. Follow the on-screen instructions .
  6. When it's successfully installed , please restart your computer .
  7. After you have restarted the computer , plug the webcam into your computer and it will automatically recognize the new hardware.
If you cannot open the rar file, download and install 7-zip or winrar.
Dec 03, 2010 | A4tech PK-635 Webcam
How to install a4tech pk-7mar without installer kit?
First download A4tech Pk-7mar's Driver click to download.
**Save it somewhere where you will remember after download . I recommend that you save it on your desktop , so it will be easy to find .
**After successfully downloading the driver , do not open the driver file until you make sure the following has completed : ***REMOVE / UNINSTALL any original mouse driver from the PC . ( If you forgot to do this part , your driver may not be able to install correctly and successfully later )
**After the original mouse driver has been removed , open the downloaded file .
**Follow the on-screen instructions .
**When it's successfully installed , please restart your computer .
That's all!
Nov 25, 2010 | A4tech PK-7ma Flexi Webcam
I cant uninstall the driver on my pc
click here
(http://www.a4tech.com/driver/A4%20PC%20Camera%20H.rar)
to download driver for your web cam (win 7 compatibility) from official site of A4tech.
since it is rar file you need software like 7zip or winrar
follow the instructions below for proper installation
  • Save driver somewhere where you will remember after download . i recommend that you save it on your desktop , so it will be easy to find .
  • After successfully downloading the driver , do not open the driver file until you make sure the following has completed : ***REMOVE / UNINSTALL any webcam driver from the PC . ( If you forgot to do this part , your driver may not be able to install correctly and successfully later )
  • After the original driver has been removed , open the downloaded file
  • Follow the on-screen instructions .
  • When it's successfully installed , please restart your computer .
  • After you have restarted the computer , plug the webcam into your computer and it will automatically recognize the new hardware.
i hope that this will work
regards,
cseian
May 12, 2010 | A4tech PK-635 Webcam
I am trying to download the Adobe Player and the system is not letting me
Check a necessary messages/command why you can't even download Adobe Player to your system.
There are many basis why your system wouldn't have you to download such files.
Use any programs that can support you to download this freeware such as download manager.
Please rate us!
Oct 05, 2009 | Dell Dimension 4600 PC Desktop
Solve this
Please find the driver here
Sep 27, 2009 | A4tech PK5
I lost my cd driver how can i get how can i install my webcam?
Hello Arumdapta,
You can download the driver for your webcam from the A4Tech website:
http://www.a4tech.com/ennew/downloads.asp
Use the input fields below "Downloads" to select 'PK' in the first field, and '635' in the second field.
Click 'GO'
Click 'Driver For PC' in the yellow sidebar and save the file CameraA.zip to your desktop.
As this driver is archived in a .ZIP file, please ensure that you have installed Winzip on this pc.
Before installing the driver, please ensure that you uninstall any other webcam software and drivers from your pc. (you may need to restart your computer following an uninstall)
To install the new A4Tech PK-635 driver:
Open the downloaded file and follow the onscreen instructions.
Once installation is complete, restart your computer.
If you have any futher questions regarding this issue, please contact me for assistance.
Regards,
JFC
Mar 19, 2009 | A4tech PK-635 Webcam
Dell Dimension 2400 PC Desktop Logo
Alun Cox
