Question about Aprilaire 700 Humidifier
I have an aprilaire 760 that leaks water from bottom of case, I put new filter, cleaned all parts but I have the feeling that the fan is going in the wrong direction. Weird? Does anyone know what is wrong
    Problem Solver:
  • 8 Answers
Could use a little more info, but check this
These guys like to sit level and have all the parts in correctly. Double check that its is mounted level. When you change a filter on them the has to go in the exact way it came out and the plates with the tube have to line up just so. The filter has to also sit level so the water can trickle in the holes on top properly. That top bracket has to be sitting on the filter properly. Hope that helps
Posted on Mar 06, 2009
Aprillaire 760 leaks from the bottom left of the case. panel is new, drain is clear, all vents open in the house, the panel cage is free from excessive scale. Any ideas?
Here is a link to your humidifier http://www.iaqsource.com/article.php/my-aprilaire-humidifier-is-leaking-what-to-do-about-it./?id=35
Oct 19, 2011 | Aprilaire 700 Humidifier
How do I know my aprilair 760 humidifier is working?
A simple check you can perform on your aprilaire 760 is the following:
1) locate the two brown wires coming out of the 760 (these wires will be wired to tell the 760 to turn on when the hvac bower is on and the humidistat is calling for moisture).
2) temprarily disconnect the two brown wires from the external wiring and then short the wires together. All you're doing here is bypassing the your thermostat and bower-on indicator.
With the 70 unit plugged in to the wall outlet and the two brown wires connected together, both the fan and the solenoid valve (water inlet valve) should both be activated.
Dec 13, 2009 | Aprilaire 700 Humidifier
When the system calls for heat My Aprilaire 700 fan turns on, but the solenoid doesn't open up. The indoor humidity is around 35% now, outside temperature was around 35 with relative humidity of 75%. In...
do you hear a clicking at the solinoid? grab the solinoid and turn it on to see if its getting voltage, you should feel it energize. you can turn off the water supply and disconnect the water line from the solinoid. there is a black pre screen inside the inlet if you have a tiny flat heat screwdriver insert it into the inlet and turn it out. clean it and retry. you can also make sure the orifice isnt clogged its located on the outlet side of the soliniod. when you remove you will probably have a stream of water come out of the feed tube thru the orifice, even if it has sat all summer. if water comes out you dont have a clogged orifice. donot try to **** out the orifice if its clogged you will need to get a new one fron www.aprilaire.com . you can verify it clogged by after cleaning the prescreen reconnect the water line inlet and turn on humidifier if water comes thru the solinoid with the outlet feed tube not connected then the orifice is clogged. If you clean the prescreen and the orifice is fine ,still no water then you will need a new solinoid you should also be able to purchase from aprilaire. here is links to the solinoid and orifice
http://estore.aprilaire.com/catalog/humidifiers/all-humidifier-parts/299
http://estore.aprilaire.com/catalog/humidifiers/all-humidifier-parts/267
hope this helps,
Mac
Nov 07, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 leaks water from bottom of case
Install new water panels yearly. On the new panel make sure that the painted dot on the edge of the panel is on the top when you install it.
Always clean the distribution tray and the frame. Make sure the notch on the edge of the distribution tray faces away from the furnace. Make sure the humidifier was installed level. Keep the drain tube opening clear. Insure there is no blockages in the drain tube.
Good luck
HVAC Teacher
Feb 10, 2009 | Aprilaire 700 Humidifier
Water runs out of the bottom of the unit
Check your plastic water orifice. It is in the hose fitting connected to the outlet tube of the water solenoid. It should be a blue one. Mine was completely eaten through, allowing full water flow, and thus overflowing the distribution tray. I replaced mine yesterday and no more water drips. May as well reflace the filter on the inlet tube of the solenoid at the same time. I used a piece of very stiff, but thin, wire formed into a small hook to remove both old parts. Replacements are readily available from multiple sources on line.
Feb 05, 2009 | Aprilaire 700 Humidifier
Water is leaking from the bottom of the unit
The tune up kit that I ordered arrived on Friday and I installed most of it on Friday night. While it is nice to have a new frame and the distribution panel and I think the price of the whole kit was fair considering it comes with the parts and 2 water panels, the fix was really simple.
The kit came with the water distribution tube with with a new blue orifice (Aprilaire #4232) already inserted. This orifice is in the end of the plastic tube at the solenoid end. When I removed the old water distribution tube, the old orifice was not really dark blue anymore but kind of a light blue and was deteriorating from 12 years of exposure to the chemicals in the water. What should have been a pin-hole size opening in the orifice was up to about 2mm or a little more so the orifice was letting way too much water through.
If anyone else has this leaking problem, and your orifice is several years old, I would check that first. It is a $2.75 part and may be the cause of the leak. The whole feed tube kit is only $8.75 and includes the feed tube, nozzle, orifice, ferule, compression nut, strainer so if you need to replace the orifice, I would order the whole feed tube kit for a little bit more.
Hope this helps,
Roger...
Jan 17, 2009 | Aprilaire 700 Humidifier
440 Aprilaire Humitifier small solinoid doesn't open
Make shure that the the filter in the bottom of the valve is clean. Turn water off use a 1/2 & 7/16 wrench to take apart the bottom connection on valve use a small screwdriver and push the small screen out and clean then put it back together.Use the same wrenches and take apart the top of valve clean inside valve and clean small orfice in plastic water line put back together. Make shure 24volts is gettin to valve you should her a click when furnace is running or fan. It may take a couple times to clean. Hope this helps
Jan 11, 2009 | Aprilaire 600 Humidifier
Water Leak
there is a nozzel at the end a black tube at the top of the hummidifier that has come off or the tube is cracked
Dec 24, 2008 | Aprilaire 550 Humidifier
Lots of water run-off from Aprilaire 760 Humidifier
HI would check the filter in side might need changing or cleaning clean out wter tray in side, it could be just a blocked filter , hope this helps
Jan 03, 2008 | Aprilaire 700 Humidifier
Water dripping from unit
if the water panel needs to be replaced , this can happen. instead of going through the panel , water will run on the outside of the panel and drip through the seems on the humidifier cover. make sure the plastic hose that goes into the water panel is inserted into the water panel.
Dec 27, 2007 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
178 people viewed this question
Top Aprilaire Humidifiers Experts
paulcarew
Ken Thomas
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
