Question about Philips 50MF231D 50 in. Plasma Television
I purchased my TV two years ago during the summer of '07. I was very satisfied and I've had no complaints until about 1 month ago when I noticed my TV was behaving different from usual.
Whenever I powered it on, the TV typically clicks twice (the clicks were always about a second apart), then I immediately would hear a slight buzz, and then the picture and sound comes on.
But last month when I pressed the power button on the remote, the picture would take longer and longer to come on. I followed the advice of others and would unplug and plug it back in. I would do this for about 10 mins until finally, I hear that slight ''buzz'' and usually the sound comes first, and then the picture. I would have to do this each time I powered on the TV, until one day when I tried to turn it On, it clicked only ONCE! I left it On and plugged in for about an hour and nothing.  No sound, No picture, just the little green light in the corner.
I unscrewed the back and checked out the center power supply board and what do you know, found the two slightly bulged capacitors standing side by side. I removed the board, took it to a professional and had them replaced with 3300uf 50v caps and was charged $50.  Now I'm back home, set my TV up again, and when I plug it in, STILL, only one click. No picture and No sound.  But before I screwed on the back of the TV panel, I noticed that on the power supply board, when I plug in the power cord, there are two green led bulbs about 1 inch apart.  Only the left LED green bulb clicks and lights up once plugged in, but the right side green LED bulb does not click or light up.
  • 35 Answers
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
Posted on May 08, 2009
3 Suggested Answers
  • 691 Answers
SOURCE: this cap right here 3300uf
if it puffed out yes
Posted on Jan 11, 2011
  • 1591 Answers
SOURCE: Failed Repair Job. A friend of mine called a
replacing the 10V caps with 25V caps is perfectly fine. In fact, if it was manufactured like that, those caps may not have blown.
Replacing a 680uF with a 1000uF could be problematic depending on it's function.
680uF is pretty specific when 500uF and 1000uF are much more common and therefore cheaper - one would think that the engineers would have tried using those in the design rather than a 680uF - makes me think the value of the cap is important to the frequency of the circuit it's in.
Other concerns might be whether he got any of them in backwards or not.
That's a rookie mistake, but still an easy enough one to make (for a rookie).
Also, with that many swollen caps, I wonder if there were any that leaked out the bottom before swelling at the top (IE - if some caps were missed in the replacement procedure)
Also, with that large a number of caps gone, other components may have been compromised or blown.
I'd be testing the transistors around those caps (most likely punched through rather than open), looking for fusible links (surface mount fuses, 0 OHM resistors) that may have opened up etc.
The initial attack on the problem was basically correct, and in many cases probably would have fixed it (if say the 680uF cap was functioning as a ripple filter).
But when that didn't fix it, a deeper analysis should have been done to complete the repair (including locating a 680uF cap).
Posted on Feb 27, 2011
Testimonial: "Excellent and through description of recommendations."
Viore 42" plasma tv has
The tv was working fine until this morning, then the picture went out but the sound is still working.
TV is only 3 years old, no real electrical problems
Jan 29, 2011 | Toymax Viore 42 in. Plasma TV
I have a 42" Maxent plasma TV about 7 years old.
Is it 7 years old? Marvelous. Exciting. the lifetime of Maxent televisions are 6 moths the most!!!
You're lucky.
May 12, 2017 | Maxent MX-42VM10 42 in. HD-Ready Plasma...
The tv just turned off and the power botton blinks
you tv has two boards inside a power supply one and a main one so the main one its the one controlling all your imputs picture and sound too manufacturer and tv repair guys waste of money go to search your tv and model for the main board. The price you r going to be satisfied without complaint.
Apr 13, 2010 | JVC HD-56G787 Television
Turn the TV on, clicks back off - no sound, no picture
hello, your power supply has to be repaired and you are looking at $275.00 for this job
good luck
Jun 23, 2009 | LG 42PG20 42 in. Plasma HDTV
42 inch LG Plasma TV - Lost picture
If you paid by cheque or credit card, that is your proof of purchase.
Mar 09, 2017 | LG 50PG6000 50 in. HD-Ready Plasma TV
50 inch LG plasma model 50PX5D. Lost picture and sound
well it looks to me u need a new tv....all the details u give are pointing that ur picture tube is gone.....but call LG help and costumer line and ask them......u may get away from it to get a new tv
make sure when u get a new plasma to extend ur warren tie to a max o 3 to 5 years and if this would happend u get it repaires for free.......cost for a new screen app 1000 to 1500 dollars
Mar 12, 2009 | LG 42PC3D 42 in. Plasma Television
Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Nov 01, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Toshiba 50hp66 picture waves
Please describe the 'waves' and what you are watching when it happens, is it on everything? e.g. normal TV and when watching a DVD? Are the Waves a grey close pattern going diagonally across the screen for some other sort of pattern?
Jun 13, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Philips 50MF231D 50 in. Plasma Television Logo
722 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
