Question about Poulan Garden
Drive and blade engagement shutsdown the engine.
The engine seems to run fine. The belts are on the mower according to the mower description on the side panels. Every time I try to engage the drive (reverse or forward) it shuts down. It also does it when I try to engage the blade. The lawnmower is a Poulan 13.1Quiet with a Briggs and Straton engine.
  • Darryl Woolery Mar 08, 2009
    That was the problem. Thanks so much.
  • 24 Answers
Sounds like the seat safety switch.
Posted on Mar 06, 2009
  • Kirk Marvin
    Kirk Marvin Jun 16, 2014
    I understand there are 3 safety switches on my 18 hp Poulan riding mower. One is under the seat. Where are the others?
My PB19542LT cranks and idles fine. But when you engage the blade it will not rev.
BlAde belt torque IS TOO HIGH It's reducing the engines running speed TO IDLE ALMOST check the blade brakes are releasing fully and the blade bearing are not tight or seem to move stiffly if the blade moved by hand ige ENIGINE OFF SPK LEAD TAKEN OFF PLUGS FOR SAFTEY AND IGNITION OFF TO AVOID ACCIDENTAL HAND CRANK ROUND START HALFWAY ENGAGE THE BLADE SYSTEM SO THE BRAKE SHOES RELEASE FROM THE PULLEYS AND THE DRIVE BELT IS LOSE NOT ENGADEGED FULY TURN THE BLADE AROUND BY HAND IF THECBLADEXOR PULLEY IS HARD TO TURN UNLESS ITS CLOGGEDUP BY GRASS DEPOSITS BUILT UP IN THE DECK OR BEARING HOUSINGS TO FIX IT WILL NEED DISASSEMBLING AND CLEANING OUT OF DEBRIS THEN PUTING BACK TOGETHER IF THE PULLEYS ECT ARE NOT CLOGGED UP THEN THE BEARINGS may need either lubricating with a race bearing grease compound or or if the blade is almost impossible to turn then the blade BEARINGS are worn out And WILL need REPLACING by mechanic the deck ajustment may also be to much and its over TIGHENING The drive BELTS slowing down the engine HOPE THIS HELP WITH THE DIAGNOSIS OF FAULT CHECK THE DRIVE SYSTEM FOR THE BLADES FULY
INCLUDINGVANYVTENTIONING PULLEYS ETC UNDER THE MAIN BODY OF THE MOWER INVOLDED WITH THE BLADE SYSTEM IF ANY PULLEY ENGAEGERSXSEEM TO BE STIFF OR SEEMS TIGHT WHEN THE BELT IS LOSSEND THE PULLY BEARINGS NEED CHECKING OR LUBRICATING ETC THE BELT COULD ALSO HAVE SHRUNK TOO SMALL IF THE MOWERS BEEN STANING STILL A LONG TIME IF THE BELTS HAS DEGRADED AND SHRUNK IT WILL NEED TO BE REPLACED
Jun 01, 2016 | Garden
Blades won't engage. I hit something, blades quit turning, check belt, its okay. When you hit button to engage blades, you hear click
When you look under the mower do you see two belts ? Top one goes to the rear axle and lower one goes to mower deck spindle.
Your description sounds like the electric clutch is engaging,so if you are seeing two belts coming off the bottom of the engine maybe the belt bounced off a idler pulley on the deck and is not tight enough.
Apr 09, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Why did Craftsman LT2000 stopped moving? Engine starts and blade engages fine.
The transmission drive belt is a separate one from the blade belt. The clutch pedal when released puts tension on the transmission drive belt so it tightens up and drives the gearbox pulley by way of a large spring. Make sure the spring is ok. The belts don't last forever and probably needs replacing looking at the age of the machine. That is a fun job as it is right up under the machine and runs from the engine pulley right back to the top of the transmission. You have to drop the deck right off and I usually find a tree with a large branch and haul the front up with a rope or winch so the mower is vertical. Makes it easier to work on. Drain petrol first though. Hope this helps otherwise get a mower shop to do it for you if you feel it's to much of a task. Good luck.
May 19, 2014 | Craftsman Garden
Does Not drive, belt position not sure is correct, connected and tight. Engin runs and Blade turns just fine. Craftsman, 917.374511, Lawn Mower
"belt position not sure is correct," from your description above
The first thing to do would be make sure belt position is correct, connected and tight.
This system is quite simple, the belt goes in the pulley on the engine shaft and the pulley on the transaxle only, nothing else. Using a short piece of rope or anything else readily available, temporarily tie down the safety bail (handle) and engage the drive handle. Now check your belt, it should be fairly tight and you should not be able to turn the transaxle pulley without considerable effort, if it is easy to turn, replace the belt. Now release the safety bail (handle)
If the drive belt seems to be working okay as above, remove the front wheels and inspect the gear teeth in them. If the outer half of the teeth are worn down more than 1/2 the original size as compared to the inner half, replace the wheels.
While you have the wheels off, if you have a couple of blocks of wood or similar items, set one under each corner of the front of the main frame outside the arch of the blade and start the engine, engage the drive and observe the pinion gears, they should both be turning. If they are not, then you have a bad transaxle and are going to have to either replace it , use it strictly as a push mower, or replace the mower.
Oct 31, 2009 | Craftsman Garden
When deck is lowered blades do not engage
Is the belt in place that drives the blades?
Is the belt at the correct tension?
With the mower engine off.....try to turn each pulley the belt drives and on the mower deck with the mower in up position and or down....do they turn a little......this is to check for a seized bearing on one of the pulleys also look under the deck for something stuck........ jamming a blade.
Also check for the mower belt safety system (which stops the blades quickly when disengaging them) that may be stuck in stop mode.
With the mower engine running.....have some one engage the blades while you look under at the belt system....is the engine driving the belt.....is the belt driving the blades.
DO NOT TOUCH ANYTHING......MOVING OR STOPPED while the engine is trying to drive the blades.
Sep 06, 2009 | Mtd Garden
Blades don't engage
Check the drive belt for the blades
Jul 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
No power when drive is engaged
Hi
Check your drive belt and the tensioner pulley that holds tension on the drive belt. Its possible for the tensioner pulley to be sticking and not putting enough pressure on the drive belt causing it to slip.
Grab hold of that tensioner pully and make sure it moves in and out freely against the drive belt.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
528 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
