Question about Kenmore 73262 / 73264 / 73269 Top Freezer Refrigerator
Remove the sheet metal panel from Whirlpool refridge
Not sure how to get the big panel off the back of the whirlpool model et21p12xgw00 refridgerator, I see the screws but it appears the white part of the sides of the unit wrap or cover or hold the metal panel in place. I did not what to pry it out if someone knows how to get it out easier. i did not start yet. Need to get this off to clean the drain hose.
  • 410 Answers
The rear panel is not removable. you need to clean the drain from inside the freezer compartment.
  • 1 remove food from freezer
  • 2 remove shelving and icemaker if equipped
  • 3 remover rear access cover in freezer usually 2 or 3 screw
  • 4 clean ice out from underneath the coil you will uncover the drain hole
  • 5 force hot water thru drain hole i use a turkey baster or large syringe
  • 6 reassemble in reverse order.
if you have any further questions please ask here and I'll be glad to assist any way I can. thanks Peyton
Posted on Mar 05, 2009
Where do I find the tech sheet for my Whirlpool Double wall oven model
On most whirlpool units, it is located behind the control panel. On most of the ovens, there are two trim pieces on each side and there is a screw at bottom. Remove the trim and then look for two hidden screws that secures the control panel. Make sure you turn power off before doing. Good Luck
May 24, 2016 | Whirlpool Kitchen Ranges
Need Manual or instruction sheet for Whirlpool Gold Conquest Model # GS5SHAXNQ
Manuals and Troubleshooting ' Whirlpool
www.whirlpool.com/manuals/
Whirlpool Home AppliancesFind your Whirlpool appliance manual and any other appliance related literature such as use and care guides or model specific information.
[PDF]REFRIGERATOR USER INSTRUCTIONS - Whirlpool
www.whirlpool.com/.../Use%20and%20Car...
Whirlpool Home AppliancesPERFORMANCE DATA SHEET. ... your old refrigerator, please follow theseinstructions to help ... If door removal is necessary, see the instructions below
Nov 28, 2015 | Whirlpool Refrigerators
Water leaks
Need more information
Does the refridgerator have plumbing for water/ ice? Is the water connected? Check that fittings are tight and not leaking.
How old is your machine? Older refridgerator have a drip pan in order to be frost free. Drip pan could be not in correctly or the hose from compressor is not flowing to drip pan.
Is the refridge level?
Oct 15, 2015 | Whirlpool Refrigerators
I have a Whirlpool refridgator it is set on the recommented settings. The problem is that it has water running down the inside of the refridgator.Now it's strating to ice up in the back. I am having...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 19, 2011 | Whirlpool Refrigerators
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
Whirlpool side by side (106.56692501). Refrig was not cooling but freezer is. Freezer is slowly heating up though. Unit is still running. It just isn't blowing air into the refrigerator.
You have ice in freezer fins. You need to remove back panel inside of freezer, melt all the ice replace panel, plug refridge back in. The ice causes bad airflow to the refridge side, causing to heat up.
Jul 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Need to remove the big piece of sheet metal on whirpool refridg
the rear panel is not removable. you need to clean the drain from inside the freezer compartment.
Mar 05, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Whirlpool side by side freezer ice cold refridge only at 55
My frigidaire has a flapper valve assembly that opens and lets the cold air in from the freezer as required. The frigidaires are known for the flapper breaking and staying open and allowing too much cold air in to the refridgerator side.. Check yours out. Mine has a shroud at the top of the refridgerator. Remove it and look around, I feel sure you have the same problem.
Dec 11, 2008 | Kenmore 57029 Side by Side Refrigerator
Whirlpool conquest side by side 2003 model
facing the back of the frige there is a cardboard or metal panel across the bottom that covers the compressor. remove panel, on left side of compressor is the main control for the frig. there is a short in that board that causes this problem. youll need to replace te board
Nov 20, 2007 | Refrigerators
Kenmore 73262 / 73264 / 73269 Top Freezer Refrigerator Logo
102 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
