Question about Dryers
Belt installation for maytag electric drier model D312? do you have a diagram?
  • Dryers Master
  • 8,205 Answers
Posted on Mar 05, 2009
I need a diagram of how the drum belt is installed on a maytag centennial dryer. Mine came off and I don't know how to put back on.
Hi c ellerts..
Here is the picture of the routing of your Maytag..
You can get this at the following wepage
Please take time to rate me thumbs up
http://www.expertappliance.com/dryerbeltconfiguration.html
Sep 12, 2011 | Maytag Dryers
Cant figure out how dryer belt goes around pully and moter
Go to repairclinic.com and click on the "Get Repair Help" link. Select the "Dryer" category, followed by "Click here for a dryer belt installation diagram". There are numerous illustrations that you can use to assist you with the proper routing of your dryer belt. If the model number is correct, refer to diagram H. I hope this helps you.
Feb 16, 2011 | Roper REK2950W Electric Dryer
I would like to be able to get to the tensioner pulley. The drier is knocking when running. How can I get to that pulley to look at it? Drier model PYG2300AWW thanks
disconnect all vent hoses and cords, flip unit on its back, you may need to remove a inspection cover depending on model......most likly the knock is coming from a worn drum roller or the felt bearings are worn out......poss a chunk gone out of the belt or the tentioner arm spring has lost its tention. hope this helps....
Nov 19, 2009 | Maytag PYE2300AY Electric Dryer
Maytag electric dryer belt repacement how to do it yourself
Below are some links provided by www.repairclinic.com, that may assist you. Depending on the model of your dryer, this may be a simple DIY job.
1. Belt /Pulley diagram.
http://www.affordableappliance.com/Tips/beltdiagrams.htm
2. Parts breakdown/disassembly procedures.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
3. Belt image page.
http://www.repairclinic.com/SSPartDetail.aspx?s=b4i529597&PartID=529597
Aug 25, 2009 | Maytag PYE2300AY Electric Dryer
MY MAYTAG DEPENSBLE CARE PLUS DRYER HAS HEAT IT JUST DOESN'T TUMBLE WHAT COULD THAT BE??
Nased on your description, MY MAYTAG DEPENSBLE CARE PLUS DRYER HAS HEAT IT JUST DOESN'T TUMBLE, I have provided some links that may help you diagnose your issue.
1. Drum Belt
2. Drum Belt and Roller kit
3. Parts breakdown and disassembly diagram
4. Belt installation diagram
You will need to provide the model number off the product ID tag located on your dryer to access the links information. Click link number 1 to begin.
1. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8i529597&PartID=529597
2. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8i587636&PartID=587636
3. http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
4. http://www.affordableappliance.com/Tips/beltdiagrams.htm
Aug 24, 2009 | Dryers
Need to replace the belt
Below is a link, courtesy of www.repairclinic.com, That shows the belt for your model dryer.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MED5800TW-%3d%3di529597&PartID=529597
This link shows a parts breakdown and disassembly procedures.
This link shows how to install the belt around the pulley.
Aug 23, 2009 | Maytag MED5800TW Electric Dryer
Maytag electric dryer:attached belt as per directions,but is still loose,the pulley seems to not give enough tension
You can verify your belt installation by going to repairclinic.com. Click on the "Repair Help" link at the top of the page, then locate the "Dryer Belt Diagrams" link under Special Features. Refer to Diagram E under the Maytag heading. If you say you have the belt installed correctly, make sure the tension spring is still installed. I hope this helps you.
Jun 27, 2009 | Dryers
Maytag neptune dryer wont tumble
The standard drive system on all driers is a large belt that fits around the tub. These belt don't last forever and can brake or slip off if warn. It's not a super detailed job for someone with mechanical skills, but it will require braking down the machine to get to the belt.
May 07, 2009 | Maytag Neptune MCE8000AY Electric Dryer
How do I install the belt on a maytag med5840TW0
All you have to do is tilt the machine back and look under the machine and the pulleys should be exposed. next just roll the belt onto the pulleys
Feb 09, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer belt replacement
maytag.gif Diagram E
Style: Flat with ribs
Installation Tips: Flat side of belt against drum
Jan 03, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
85 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
