Question about Simplex Kaba Ilco Unican 1000 keyless lock
Unican combo lock handles are loose
There seems to be a lot of play in the handles
    President:
  • 2,692 Answers
If the handle has been forced their is a part inside that is broken and it appears as if the handle is loose. I have priced the replacement parts and they were over 75% of  what I could purchase the whole thing for ,so I elected to purchase new and go with the direct replacment model L1000 (Lever) to make it ADA compliant at the same time.
Posted on Mar 05, 2009
I have a unican and need to take it off the door and replace it but need the instructions?
Look for a small hole in the side of the spindle, close to the lock. Poke a stiff wire into the hole to release the inside handle.
Jul 21, 2014 | Simplex Kaba Ilco Unican 1011 keyless...
Simplex 1000
Try loosening the collar as much as possible and access the poke hole. I'm not sure how you managed to get the handle on, You might need to drill the collar, but if drilled while the collar is loose, the damage could be hidden. Good luck! Replacement collars are available, if all else fails.
Jul 20, 2014 | Simplex Kaba Ilco Unican L1000 keyless...
Simplex 1000 lever handle when correct combo put in lock combo lock operates fine except unless you let the lever snap back lock dose not reset in locked position, in other words if you slowly let the...
I don't have a direct answer, but here is the contact info you need for customer service:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
1-800-849-8324 (option 1)
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Technical Support (Simplex, E-Plex, PowerLever, 4000 Series, Solitaire 850L, Solitaire 850/950)
1-800-849-8324 (option 3, and then option 6)
Tech Support is probably your best bet!
Aug 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I tried reseting my combo on the simplex LP 1000/8100 series and messed up. I entered a new combo and the latch did not work. Not only did the new combo fail, I could not open it with the old combo. What...
Contact Kaba Ilco for technical assistance:
Jul 03, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Lock has a Best core in the outside handle but door cannot be locked
I recommend that you contact Kaba Ilco directly for technical assistance.
good luck!
Mar 16, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
How do I remove a unican L1000 lock from the door? I have the upper lock cylinder out, and used the spanner wrench to remove the ring on the non entry side. How do I get the handle off to remove the lock...
use the other side of the spanner wrench with the point and insert it into the hole in the inside sleeve and you will feel some spring tension.........push in the tool and pull the handle off at the same time.
Jan 04, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I changed my combination and dont know what i set it to
If you forgot the combo you will need to reprogram it. If you can not get in to open the door to reprogram you can email llco at info@lilocksmith.com for an override code.
Good Luck
Dec 28, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Nov 12, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
313 people viewed this question
Top Simplex Locks & Locksmithing Experts
sonic boom...
sonic boom...
Dwayne L brown
Dwayne L brown
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
