Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
How to replace a cord?
Bought a cord from a reputable vacuum dealer and would like to replace cord myself, do you have a diagram?
Thank you
  • 10,865 Answers
Just open up the area where the electric cord is attached and make a diagram of which colors go where. Then remove one wire and reinstall one wire at a time.
Posted on Mar 29, 2009
Kenmore Progressive canister vacuum cord rewinder is "jammed." How can I fix it myself? Thank you! dan :)
It has to come apart to fix that. I wouldn't recommend doing that yourself, as you will probably break it. Take it to your local vac shop for repair.
Jun 09, 2017 | Kenmore Vacuums
I need to replace electrial cord attached to machine myself
Make sure all electric is off strip off plastic covers on all parts of the cordes to be attached about 5incs easy to do with a razor slice on both sides or wire strippers then twist wires together and wrap with black electrical tape. Plug in and should have power
Jul 09, 2013 | Vacuums
I recently bought this machine 2nd hand but the power cord is missing. Can I get one from a dealer or whomever?
Contact any vacuum ckleaner repair shop in your area and they can supply a replacement cord. Check the local phone book under vacuum cleaner parts retailers.
Mar 04, 2011 | Vacuums
Need diagram to replace cord thank you
I'm sorry, but diagrams for these machines are only available to the owners and service techs at Aerus Electrolux stores. No hard copy, and nothing on the net.
I don't recommend doing it yourself anyway, for the following reasons.
1. risk of breaking tabs.
2. unable to reassemble correctly
I strongly recommend taking it to your nearest Aerus Electrolux store.
http://www.aerushome.com/storelocator/
Mar 04, 2011 | Electrolux UltraLux 2000 Bagged Canister...
How do I replace the pull cord? do you have a manual that shows the 'guts' of the blower so I can replace it myself? Thank you Kathleen
If the unit is a canister, you will have to take the plastic cover completely off exposing the motor and cord reel. The cord reel will come out by gently pulling right side away from the left of the casing. from there the two wires from the cord reel are attached to the PCB board by wire nuts you will find tucked next to motor.
If unit is upright with cord reel you will find the situation to be really similar to the canister, but you will have to remove a few more screws to get the casing off this one.
Nov 17, 2010 | Vacuums
Need a readable motor wiring diagram for Eureka Vacuum Bagless Upright 4388.....
take the black lead of the power cord to one on-off switch lug, then take wire off other switch lug to one motor connection terminal, brilg other motor terminal wire back to other wire on the line cord.simply a series power circuit
Sep 27, 2009 | Vacuums
Burning smell kenmore canister
Had a burning smell coming from the vacuum. Opened it up and noticed sparks in the motor area. Ordered a new motor from Sears and replaced it. Works great now.
Mar 04, 2009 | Kenmore Vacuums
I have a Dirt Devil Broom Vac that won't hold a charge. I need to replace the rechargable battery. Is there a dealer near Bartlett, TN that can do that or would I be able to do it myself if I bought a...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=730257
Generic problem for all Vacuums
I have a Dirt Devil
Posted by maryk813 on Jul 02, 2008
I have a Dirt Devil Broom Vac that won't hold a charge. I need to replace the rechargeable battery. Is there a dealer near Bartlett, TN that can do that or would I be able to do it myself if I bought a new battery?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only place that I know if to contact the Royal factory cust serv line listed below or to check the website and they may direct you to a local dealer in your area. All you would need is a new rechargeable battery and you can do it yourself. The problem that I see is that the new rechargeable battery may cost as much as a new vacuum if you consider the part plus shipping and handling. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Vacuums
Replace power cord on bissell vacuum model 3596
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=574515
Replace power cord on Bissell
Posted by bah4995 on May 06, 2008
Replace power cord on Bissell vacuum model 3596
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually the Bissell needs a genuine cord because there is a special grommet or cord protector that goes into the bottom of the Bissell of the machine or sometimes you can use a replacement cord and then also use a replacement cord protector as well to replace the cord. If you have a problem then contact your local vacuum cleaner dealer in your area or contact the Bissell factory cust service to get an owner’s manual for the Bissell. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Go Ahead. Use Us.
May 06, 2008 | Vacuums
Yanked the cord out of the vacuum
Wasn't able to find any diagrams either, but there should be some screws to take out, and the top and bottom should separate. Don't let the cord reel spring unwind if it hasn't already done so. If it hasn't, one half of the reel should come aprt so you can re-attach the cord. then put the reel back together and let it wind the cord on the reel. If the spring is unwound and/or the reel wasn't made to come apart, then you will have to replace the cord reel asm.
Feb 28, 2008 | Bosch BSG71360UC Bagged Canister Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
228 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
