Question about SanDisk Sansa e260 MP3 Player
I need to know the maximum GB external micro sd card I can put in a sansa E260 4 GB Mp3 player and a sansa express 1gb mp3 Player.
  • Becky Gauna
    Becky Gauna Mar 05, 2009
    Thank you, This was very helpful
  • 544 Answers
thank you for choosing Fixya.com
you can use 4GB it is the applicable memory on your mp3.
if you will try to use much higher than 4gb sometimes it is the reason why our player are hanging up.
please don't forget to rate our answers properly.
Posted on Mar 05, 2009
  • SanDisk Master
  • 19,396 Answers
That depends on the firmware version, on first firmware version version 01.xxx the sansa 260 does not support over 2GB, newer versions support up to 4GB.
There is a tag at the back that tell you the version, r for rapsody, the regular and version 2-v.2. v.2 allow 4gb cards the others only 2gb.
Old sansa can also be updated to third party firmware rockbox that should support up to 8 GB, but sometimes upate to third party firmware can damage the unit.
see: Micro SD Card limitations in the ...
Micro SD Capacity
The e260 will not recognize any microSDHC cards. It will only use microSD cards, which are limited to a maximum of 2GB in size.
Apr 14, 2010 | SanDisk Sansa E280 MP3 Player
Can I attach an 8 GB Micro SD Card in the expansion slot of my Sansa e250? If not, what is the maximum storage size it supports?
The e250 uses microSD cards, not microSDHC cards. The maximum size of microSD cards is 2GB. Anything larger are microSDHC cards.
Mar 16, 2010 | SanDisk Sansa e250 MP3 Player
Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Jun 29, 2009 | SanDisk Sansa e260 MP3 Player
Sansa c240 and a 4 GB Micro SD HC card.
Sansa C240 can only read SD cards that are NOT SDHC - that means it can only read up to a 2gb Micros SD card.
Jun 05, 2009 | SanDisk Sansa c240 MP3 Player
Micro sd probelem
Well, the most memory from a micro sd card the Sansa mp3 player can take is 2gb, because anything more will freeze up the player because it was not designed to read that much memory. So if you have a 1gb or a 2gb memory card, then you can use them.
Mar 01, 2009 | SanDisk Sansa MP3 Player
Sansa mp3 player could not detect micro sd add on card
I believe you can fix it by going on the player, then to settings, then to USB mode, and switching it from MTP to MSC. If you're in MSC already and it fails to recognize, then I don't know. :(
Dec 24, 2008 | SanDisk Sansa e250 MP3 Player
Trouble with expanded memory
The Sansa Express was only designed to hold up to a 2 GB Micro SD card because that is as much expandable memory it was meant to read. Anything bigger as in your case will cause the player to go slower than normal as it tries to read the card and after a while, it will most likely freeze. If you try it with a 2 GB Micro SD card, it should work.
Dec 10, 2008 | SanDisk Sansa MP3 Player
Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
Sep 20, 2008 | SanDisk Sansa e260 MP3 Player
My Sansa Express Music Player shows mulfactioned error
Insert A Micro SD Card And Start It Up
It Should Work
Shut It Down And Remove The Micro SD Card
It Should Startup Fine.
Sep 09, 2008 | SanDisk Sansa c150 MP3 Player
Micro sd 4gb card problems.
Check the Sansa tutorials at http://www.sandisk.com/Retail/Default.aspx?CatID=1468
to make sure you have followed all the steps first.
In my experience, every mp3 player/photo frame/etc with a card reader has a MAXIMUM memory limit for the type of card that it can read. It is possible that the Sansa player can only read 2GB Micro SD cards or smaller - and thisi nformation may not have been available when they printed the manual. If you have followed all instructions, and it still will not read the card, try switching to a 2GB Micro SD card.
Mar 22, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
249 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
