Question about IBM ThinkPad T40 2373 Notebook
PC won't run: Fan Error
When I try to turn on my old IBM ThinkPad sometimes I just get a text error in the upper left hand corner of the screen:
Fan Error.
What should I do?
  • mark_lubeck Mar 05, 2009
    The fan does seem to go on. I hear it running.
    Right now the machine is working, vista is running and the fan is quietly working. I'll have to listen for the fan when I get this error.
  • 3 Answers
First blow compressed air through the vents to clean out the dust. If that does not help open the laptop and remove fan. I have a Thinkpad Z60m that had fan error. Removed the fan and then pulled just the plastic blade unit out by gently turning back and forth and pulling it away from the body simultaneously. Cleaned the shaft and then the sleeve which the shaft goes into with a toothpick. Dropped 1 drop sewing machine oil into sleeve and put back the blade unit. Works great. If all else fails, order a new fan for your laptop.
Posted on Jun 15, 2016
  • 78 Answers
This is a self test that is checking the fan and finding that it is in error. You might have the fan damaged or else just stuck with dust inside and therefore to protect from over heating the laptop gives you this error.
Please check if the fan actually works when you switch on.
Posted on Mar 05, 2009
  • Mr fix.it Mar 05, 2009
    Yes check the fan when the error appears so you can find out if it is a hardware issue or a software issue.
Thinkpad X41 starting two short beeps, fan error and shuts of
The IBM POST code states that after the 2 beeps the screen displays the error.
In the case you have a faulty fan and it needs to be replaced.
Sep 19, 2012 | IBM ThinkPad X41 Notebook
The fan on my R52 has been getting noisier of late, and now when I turn on the laptop it makes a fan noise (as bad as it has been) and after about 4 seconds the laptop shuts down and Fan Error is displayed...
FAN is out...replace fan...else ur processor will die soon....dont use the machine....take it to a tech shop and replace fan ASAP....
pls revert back...kindly give a feedback and rating to this solution....it will help me move to the next level "Guru,,,,"
regards
Sep 29, 2010 | IBM ThinkPad R52 Notebook
Fan Error message but the fan's working on another machine
One option would be to replace the motherboard. You can use one from T40 -T43 with your monitor. I bought one on Ebay for $90 which came with the board installed to the bottom plastic tray. I only had to install my monitor, memory, keyboard, hard drive, & plastic bezel and I had a good working unit for $90.
May 15, 2010 | EliteGroup A530 Notebook
When booting up the screen displays FAN ERROR
Is the fun running? you can first confirm that before you alter anything in the Bios. touch on the fun air exit point you will feel it if its running.
Regards
May 05, 2010 | IBM ThinkPad T30 2366 Notebook
IBM thinkpad t42 boot up problem.
The most common reason is memory.
First, try to reseat (remove and reinsert).
If still a problem, test one module at a time.
Hope this helps.
Aug 17, 2009 | IBM ThinkPad T42 Notebook
My IBM ThinkPad showing a black screen with a small computer symbol in the upper left hand corner with a lock symbol next to it ??? computer unreactive.
That usually means there is a system password that needs to be entered. If you do not know it, you must remove the CMOS battery from the laptop and reset it.
Jun 30, 2009 | IBM ThinkPad R31 2656 Notebook
Need to recover password
hi i hope this will help you, but be careful with these solutions..do this at your own risk.
here's the url:
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Mar 21, 2009 | IBM ThinkPad T21 Notebook
I am a service provider in central Minnesota and have a client that has an IBM T23 Thinkpad that now is locked with a icon of a padlock and a computer in the upper left corner of the screen. THis happens...
LAPTOP MAY HAVE BEEN ILLEGALLY OBTAINED. CERTAIN SOFTWARE PROGRAMS ON THE MARKET WILL LOCK THE COMPUTER TO PREVENT INFO THEFT OR USE.ASSUMING THIS IS NOT THE CASE SEND THE LAPTOP TO FACTORY FOR QUICK FIX.HOPE THIS HELPS.ALSO I CAN NOT BELIEVE THAT THE FACT. SERVICE TECHS GAVE YOU THE RUN AROUND THAT'S UNUSUAL FOR THIS COMPANY.ALSO CONGRATS ON YOU GOING ABOVE AND BEYOND TO HELP YOUR CUSTOMER.RICHARDM69
Dec 02, 2008 | IBM ThinkPad T21 Notebook
T40 2373 ibm fan error
One of three things; 1- when the fan codes on some IBM's, the code locks in the bios, there is a download the has to be ran in order to clear the code and the machine to run properly. Check IBM's support site to see if this is the case for your machine 2- If the machine overheated in the process of the fan going out, then the processor may have been damaged, causing the problem and 3- if there was a malfunction with the motherboard which initially caused the fan to stop working, a new fan won't work either. Test the old fan by hooking power up to it, it is power direct and has two leads positive and negative, when power is applied it will run or not. If it does run then the problem is with the motherboard. Try these and get back to me.
Jul 29, 2008 | IBM ThinkPad T40 2373 Notebook
ERROR 0271
Are you a computer whizz? (do you know a lot about computers like me?)
Could be the Cpu fan (Central Processing Unit)
That could be lethal to the laptop.
Just as well it's a IBM other wise . . .
As for the error it means the time and date are not set.
soloution: run the bios setup utillity to reset time and date.
1358
Jun 25, 2008 | Acer Aspire 5610-4648 Notebook
IBM ThinkPad T40 2373 Notebook Logo
590 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
