Question about Weather King 10AJA2501AH Air Conditioner
30amp breaker labeled heat strip trips and no hot water
I have a 30amp breaker in my breaker box thats labeled "heat strip" and it has been tripping. when it trips my hot water goes out, what does this mean?
  • 10,865 Answers
That 300 amp breaker must be controlling both your hot water tank and some heat strip somewhere in your house which is designed to either prevent a pipe from freezing or melt ice on the eves of your roof.
please mark this answer as a fixya
Posted on Mar 05, 2009
The thermal breaker keeps blowing
Replace the limit, by tripping often they become even more likely to nuisance trip.
Apr 29, 2016 | Stiebel Eltron TEMPRA 24 Tankless Water...
My 30amp 2 pole gfci circuit breaker keeps tripping right after i reset it. It's connected to my endless pool and has never trip before. Is it a bad gfci ?
Replace GFCI and see if the breaker is bad.
Otherwise, my guess is that you have a short in the pool or pool heating element.
If you have AFCI (arc fault), then a loose wire connection anywhere along the line will trip breaker
Troubleshoot resources:
http://waterheatertimer.org/How-to-wire-GFCI.html#spa
Gene
Water Heater Timers Save Money
Aug 03, 2015 | Electrical Supplies
Hotpoint condenser tdc60 , trips electrics
Either the dryer has a short or the breaker is bad.
Does it trip when it starts, when plugged in, when turned on? in the heat cycle?
Breakers should be replaced about every 20 years and a 30amp cost about $10. I would try that first if yours is from the 80s. Look at the brand you have and buy the same or compatable to your fuse box. They clip in differently.
https://www.youtube.com/watch?v=lnO90_Te_jU
Oct 20, 2014 | Dryers
I HAVE A 2 1/2 TON PACKAGE HEAT PUMP . THE60 AMP BREAKER AT THE DISCONNECT BOX KEPT TRIPPING . I DISCONNECTED THE HEAT STRIPS AND NOW THE 60 AMP BREAKER ISNT TRIPPING . WHAT IS CAUSING MY BREAKER TO T
You need to check the current rating of your heat strips. If it is more than 60 amps then you need a bigger breaker. If 60 amps or less then your heat strips are going bad. Also make sure your fan turns smoothly without any wobble.
Jan 06, 2014 | Electrical Supplies
Tempstar 2400 blows the a/c breaker when heat is on
How long before the breaker trips?,does the a/c work ok,gas heat or heat pump?,electric strip heat on auxiliary heat,if these are shorted they will trip a breaker,if the breaker trips instantly you have a dead short in the system,if it runs for a while it may be a weak breaker,you may have a bad compressor if it trips fast or a shorted out heat strip,need more info!
Mar 08, 2013 | Heating & Cooling
No lights upstaires circuit breaker keeps tripping
Jan 2013
1) Move wire to another same-size circuit breaker to eliminate bad circuit breaker as suspect.
Do NOT increase size of breaker or it will cause fire.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html
2) Put hand on each appliance and outlet to see which ones are warm. Outlet should never be warm or hot. Replace outlet. Inspect wires for loose and burned connections.
3) If the breaker is good, then add up total watts being used by checking watt rating on each device. 100 watt light bulb is 100 watts. Big screen TV has a label that shows 300 to 500 watts. Computer has label. Space heater has label showing 1500 watts. Iron has a watt rating label. Take total watts and divide by 110Volts and this will give amp load. Total watts used = 2000 and then divide 2000 by 110 volts = 18.8 amps
Compare amp load with circuit breaker.
20 amp circuit breaker has 80% safe maximum, or 16 amps.
If amp load is 18.8 amps, then 20 amp breaker is starting to get hot, and weak breaker will start tripping.
If amp load is 18.8 amps, and breaker is 15 amps, then you are overloaded and breaker is feeling the heat, and tripping because of heat.
Solution is to reduce amp load.
4) If you have short circuit, that can also trip breaker.
Unplug everything and then plug things back in slowly to see which plug or appliance is causing the problem.
Jan 18, 2013 | Electrical Supplies
Powerstar 115 tankless tripping reset ontop of #2 heat chamber #1 does not get overly warm mainly because of incoming water temp. but #2 seems to be heating after water flow stops to hot to touch and...
I don't have specific suggestion for tankless tripping breaker or if that is a circuit breaker problem or a tankless problem.
1) Move wires to another same-size breaker and see if problem persists.
2) Compare amp draw on tankless label with wire size and breaker size amp rating.
For example 30 amp breaker using 10ga wire is rated for 80% of listed amps or 24 amps.
3) If you are drawing full 30 amps, then 30 amp breaker is getting hot. Breaker trips with heat. Older breakers can trip more easily.
4) Before calling service technician, open following link for Bosch troubleshooting steps.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
5) Be sure to read manual for yearly maintenance requirements.
6) Add a tempering tank for incoming cold water problem.
http://waterheatertimer.org/Tempering-tank.html
7) All gas tankless brands can be repaired by homeowner for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Apr 22, 2011 | Bosch PowerStar AE115 Tankless Water...
THE INSTA HOT HEATER KEEPS TRIPPING THE BREAKER?
Hire an electrician.  The breaker needs to be replaced or the wiring in your house is not able to handle it.  I believe most need 2-30amp breakers.
Mar 03, 2009 | Emerson Insinkerator 2.5 Gallon Water...
Sde5401ayw keeps tripping breaker
ck the element if the breaker poping as soon as you use heat dead short eather element are wire going to it
Mar 18, 2008 | Maytag SDE5401AYW Electric Dryer
Weather King 10AJA2501AH Air Conditioner Logo
76 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
