Question about Fisher Price Swing 'n Comfort Crib
The plastic handle that swings the basinette broke in half
Is there repair or parts available for this item? The dark blue plastic handle that holds the basinette and allows the basinette to swing, it is circular on the top that locks on to the stand; it has broken in half. Is this part available for purchase or repair?
  • 10,865 Answers
You can replace it at fisherprice.com
please mark this answer as a fixya
The repair might be a five minute epoxy glue available at a home depot, lowes or other hardware store.
Posted on Mar 05, 2009
Door wont stay shut
the part you need is a small plastic clip that fits in the hole first , the rod is pushed through the hole and the rest of the plastic clips around the rod ,holding it in place
available fro service dealer spares or from the wreckers/junk yard s
May 27, 2017 | 1994 Nissan Pathfinder
How do I fix the door/lock of my 1991 Acura Integra? I can only open the driver side door from the outside
There are only 2 places that you have the problem on the inside door handle. one is at the handle,and the little plastic holder that holds the rod to the handle broke, or the plastic clip the the door lock mechanism broke. the first can be removed without taking the door apart. the inside door handle has a screw holding it in place. you can remove the handle and see if its broken. the second requires you to remove the door panel, to replace the clip that hold the rod to the lock. I door handle in the car is a dealer item only(sorry to tell you that), the clip for the lock, you can get at the auto parts store. hope this helps
Jan 11, 2011 | 1991 Acura Integra Hatchback
Broke off control handle for side view mirror. Is
completelmirror unit but they are not expensive about 30 euros
Jan 18, 2010 | 1999 Volkswagen Passat
My Eureka Optima vacuum handle broke right at the metal tube.
I have exactly the same problem. I plan to drill a hole in the handle through plastic and metal, and then pass a metal pin to hold them together. I don't rotate the handle much, so the loss of handle spin functionality will not be a major issue for me.
Aug 05, 2009 | Eureka 431A Optima Bagless Upright Vacuum
1992 Ford Explorer Sport. Outside door handle not
Door handle seems loose and not connected? Then the plastic clip broke inside the door. Take off the door panel, 3 screws, and door lock cap and plastic insert around inside door handle. pry around the bottom first, and go up, when you reach the top, pull up, please be carefull to not break any more plastic. you will see a squarish opening midway up the door toward the latch. reach in and pull a rod toward the opening. You see a broken piece of plastic on the tip? if so take it off and get the replacement part for it at an autoparts store, install the new one and your set. I have broke to many of these so i ended up bending the end of the rod and using a nut to hold it in.:]
Jun 20, 2009 | 1992 Ford Explorer
Oven door handle (right side)came loose
If you put the door at a 45 degree angle on the hinges, it will lift right off. Then once on the ground, it should be easy to remove the screws of the inner panel and expose the screws that the door handle attaches to.
Mar 13, 2009 | Maytag MER5555Q Electric Kitchen Range
Swing along castle broken parts need to order My
Go to littletikes.com. They have a seciton to choose outdoor products and you can drill down to the swing and slide castle. All the replacement parts are available there.
Feb 19, 2009 | Little Tikes Swing Along Castle
Door handle broke off
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can get Samsung parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 18, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
Lever broke
The plastic used is a thermoset, so should not want to melt in order to join together again by that method.
I would recommend using a clear 2 part epoxy resin. Make sure all parts are clean using a degreaser - cleaner, and dry thoroughly for several hours before repair. Use elastic bands or tape to hold items in place while the adhesive sets - about 24 hours for full cure.
If there is still a problem after this, please contact again, or rate so that other may follow the advice given. Thank you.
Jun 08, 2008 | KitchenAid KTT570 4-Slice Toaster
Handle
when door is open on the edge you wil find a plastic strip .remove carefuly with flat screw driver .when removed youwill find the screws holding the handle undo screws and replace .dont 4get to replace plastic strip
Apr 23, 2007 | GE JVM1440 Microwave Oven
Fisher Price Swing 'n Comfort Crib Logo
85 people viewed this question
Top Fisher Price Baby Gear Experts
Lyle Siemens
Lyle Siemens
Jennifer Rock
Jennifer Rock
Jerry Umali
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
