Question about Samsung Propel A767 Cell Phone
I left my phone n my bag.....
N i looked at it agaiin n it keeps restarting i dont know what to do
  • jessicamuse2 Mar 11, 2009
    Im having the same problem.. It restarts over and over but does not get past the at&t logo.. Today was the first time it changed screens and its now telling me download. Its a black and red screen. Help anyone??
  • princessjd_7 May 09, 2009
    I turned on my phone, and every once in a while it would turn off, then everytime im in the middle of a conversion it would turn off, then it wouldnt turn on for hours, and now it wont turn on at all. all of this took olace over the course of one week! How do I start it again?!?
  • 240 Answers
I think it may be due to software problem . if u know the proper procedure to the load the working software of your mobile pahone try it out or else go a service station having facilities to load the phone software again.
Posted on Mar 11, 2009
Need help on how to disable safe mode box on my cell phone screen
If your phone is STUCK in Safe Mode though and restarting it or pulling the battery doesn't seem to help at all then it could be a hardware issue like a problematic volume key (key might be stuck)
Jun 29, 2017 | Cell Phones
My lg kt520 just keeps stalling/freezing and turning off,i was told i need to doould be ok bot dont know how my lg kt520 just keeps stalling/freezing and turning off,
it looks like the phone needs resetting, in reseting the phone, you may loose data, so better if you have them backed up first.
restart the phone, from the standby screen type in:
2945#*# and select option 6 (reset) from the menu.
The phone will restart and after about a minute you'll be working again. Make a note of the code, because you'll be needing it every few months.
hope this helps
Aug 06, 2008 | Cell Phones
How to restart printer
simply press the power butoon for few seconds... if it is not working, unplug the power chord then re-plug it agaiin
Feb 27, 2014 | Office Equipment & Supplies
My honda civic ex sedan 99 model horn doesnt work when my wheels is at the center but when i turn it to the left or right then press the horn it works i dont know the prob anymore please help me i checked...
You took the air bag off and checked the contacts for the horn switch ?
There is a clock spring which keeps the connection as the wheel is turned. Might be a problem with that part.
You must disarm the air bag system before working on the wheel.
Jul 03, 2012 | Cars & Trucks
No send sms,& phon are restarte contiueasly?
hi,
your phone is having a corrupted software..in order to fix that you may go to a certified mobile care center to do your phone by a gadget called z3x LG..by before you go and spend money try this one first ,remove your battey ,simcard and memory card for 5 to 10 minutes ..then insert it agaiin and turn on ,lets see if what is happen..
Feb 06, 2011 | LG GM200 Cell Phone
Have a problem with start button
Im telling the solution step by step.It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically.
Try this Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu [default security code:12345] {i know most of people have done this thing,but remember u have 2 go with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months. During these time u can1
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime. but remember below
DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times and automatically swiched off.}
Jan 14, 2010 | Nokia 3110 Cellular Phone
My camera on my blackberry curve is not working.
when i try to use the camera on the blackberry 8310 it tells me to close other application, how can this be fixed
Jun 02, 2009 | RIM BlackBerry Curve 8310 Smartphone
Iphone running slow
To restart: Hold Sleep/Wake together for about 10 seconds. The screen will go blank but don't let go until the Apple logo comes up.
It sounds like your problems will be solved by upgrading to 2.1 firmware. Just connect to iTunes, click your iPhone in the left column, click "Check for Update", and let it do what it does.
Good luck,
Colin
Aug 31, 2008 | Apple iPhone Smartphone
Samsung Propel A767 Cell Phone Logo
155 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
