Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
Error code 09
what is error code 09
  • 463 Answers
Er00 - The software that was available for upgrading was of an older or of the same version as the one already in the digital-box.
Er01, Er02 -The upgrade failed. Some information was missed out.
Er03 - The internal memory is not large enough to receive the upgrade.
Er04 - The signal was disturbed during the upgrade.
Er05 - Wrong type of data was received during upgrade.
Er06 - Not used.
Er07 - Access problem in back-up memory (EEPROM).
Er08 - Access problem in video memory.
Er09 - Can not find any data to do an upgrade.
Er10 - Poor or no cable-TV signal.
Er11,12 - Not used.
Er13 - Unauthorised data signals received by the digital-box.
Er14 - Faulty data signals received by the digital-box.
Pb01 - A problem in the ROM memory is detected.
Pb02 - Memory size is too small.
Pb03 - A problem occurred during start up (initialisation
problem).
Pb04 - Internal communication failure.
PbF9 - Hardware error identified during start-up
From elsewhere on the web:
1. Turn off the unit for 15 minutes to cause a full reset.
2. Turn on the PVR with everything attached except the antenna input.
3. You will get an Er09 on the display. On my PVR there was no output on the TV screen whatsoever (totally black screen).
4. Press 'OK' on the remote (confusing as there is no clue that this is what you should be doing, though Sagem support thought that the PVR should prompt you.
5. The box reboots in standby mode."
Good Luck...
I also see some mention that if the above procedure doesn't work, try pressing "Menu" twice to see if that clears error 09.
Posted on Mar 05, 2009
Error code F.09 on display.What does it mean
Error code F.09 according to Bosch means "unexpected heating". It would be hard to diagnose this problem with that from my vantage point but may be useful to you.
Mar 02, 2015 | Bosch Dryers
What does error code Err 09 for a Wolf oven mean?
Hello Joni;
My name is Peter. I am a retired field service appliance technician.
The error coded means: Short circuit in PT sensor or in its wiring.
Feb 03, 2015 | Wolf Range Kitchen Ranges
Po340 and jerky motion 09 hhr
http://www.chevyhhr.net/forums/problems-service-repairs-42/reduced-engine-power-engine-shutdown-error-code-p0340-p0601-47411/page2/ Reduced engine power engine shutdown error code P0340 and P0601 Chevy...
Jun 21, 2014 | 2009 Chevrolet HHR
Error code 09
During that 15 seconds, do you see the water moving in the spa?
If not then normally, that means the pump has not primed fully - hence the 09 Error Code. Pump could have a clog internally, but most likely problem, Dirty Filter.
Dec 31, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Motorola error codes01/09
Two questions: What type of Motorola radio (model name)? And is the fail code 01/09 or could it be 01/90?
Will watch for your reply.
Nov 11, 2013 | Radio Communications
WHAT IS THE SOLUTION FOR DVCAM ERROR CODE 09-224 AND 09 -824 RESPECTIVELLY, PLZ IM VERY IN FOR THAT NOW . FOR THE DVC MODLES 2000AP &1800AP.
The error 09:824 Failed to detect the threading FG during unthreading.09:224Failed to detect the threading FG during threading.For this what u have to do is,clear all the Error in ur Eprom IC.So go to maintenance menu and service Support.then check the FG function.in that way it solve ur r problem
Apr 05, 2011 | Sony DSR-1800 DV/Mini DV VCR
Error Code
A error code F1-09 deals with the finisher of the copier. Have the bins gotten stuck or got something in it's way when moving up & down. I would turn the copier off and unplug the finisher from the copier, 1 screw holds connector in. Then I would turn it back ON and see if the code is gone, if so reconnect the finisher and you should be good to go...
Jun 11, 2009 | Sharp AR 201 Copier
09-824 error
09-824 error code indicates a problem with the threading motor. check to make sure noting is obstructing the threading ring.
May 18, 2009 | Sony DSR-1500 Mini DV VCR
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
3,929 people viewed this question
Top Sagem Televison & Video Experts
Andy Fraser
Andy Fraser
electracon
 Mikey
Mikey
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
