Question about Cyberhome CH-DVD 300 DVD Player
No sound on movie
The dvd plays but there is no sound and it isnt set on mute either. checked the input and output cables and they are colo-coded so they are connnected the right way.
    Problem Solver:
  • 14 Answers
What are you connecting the sound to the tv with?
Be aware that a component cable only carries video
http://akamaipix.crutchfield.com/graphics/infolib/homelib/hComponentVideoJack.jpg
cables that carry sound include scart
http://tech.petegraham.co.uk/wp-content/uploads/2007/03/scart.jpg
phono
http://akamaipix.crutchfield.com/graphics/infolib/homelib/hPhonoInputs.jpg
and optical
http://www.getdtvready.com/images/optical%20cable.jpg
If this is correctly connected then check in your DVD player menu for sound output, some DVD players wont auto-detect what type of sound cable you are using and you may have to set it to the type of output you are using.
Good luck.
Posted on Mar 05, 2009
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
Jan 05, 2015 | Car Audio & Video
Set up to play dvd movie on TV
You just need an RCA cable. Find the output from your dvd and connect to the input of your tv. The cable has three connectors in three colors...red/white/yellow. Res and white is audio and yellow is the video.
Dec 22, 2007 | Televison & Video
The sound goes on and of when watching a movie
see the cause and fix it: God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Jul 21, 2012 | Wharfedale DVD-M3 DVD Player
I have a picture but no sound
1. check input sound connection
2. check audio mute or not
3. check audio system in menu
4. check speakers (connect external speakers)
5. check amplifier IC bad or not
Aug 18, 2011 | LG Televison & Video
The sound just stopped working. It's not muted or anything.
  • 1 Check the power. Don't be embarrassed if your problem is as simple as an unplugged power cord. It's better that you should discover this than pay a repair technician to come out to your house and find out.
  • 2 Isolate the problem. The main troubles that will crop up with a TV set are either no picture, no sound or both.
  • 3 Check the input setting on your remote control. If you have other devices connected to the TV, such as a video game system, those devices must be used with a different input setting than the input you use for watching programs or movies on a DVD or Blu-Ray player. Chances are, the kids were playing a game and forgot to turn the input back the way it was.
  • 4 Press the Input button on your remote control to return to the setting you wish to use. For example, the cable box might be connected to Input 1 and your DVD player might be connected to Input 2. Newer television sets have at least 3 inputs.
  • 5 Check the coaxial connection from your cable or satellite receiver to the television. The cable should be attached securely by twisting the round lock nut clockwise. Also check the power connections for the satellite or cable receiver. If either is unplugged, you won't receive a programming signal on the TV.
  • 6 Make sure the video cable is securely attached to the TV jack if you have a home theater system. The video cable runs from the Video Out jack on your home theater receiver to the Video In jack on the back of your TV.
  • 7 Check your receiver setting. Home theater receivers manage several components, so if you have the receiver set to operate the CD player but you are trying to watch a movie on your Blu-Ray player, you'll need to change the selection to Blu-Ray to watch the movie on your TV.
  • 8 Check the TV speakers to see whether they have been muted by accident. Press the volume button on your remote control or go to the Menu section and scroll down until you reach TV Speakers. Toggle left or right to turn the speakers on or off.
  • 9 Press the speaker button on your receiver to make sure your external home theater speakers are activated. Many home theater systems use external for their superior audio rather than the speakers inside a television
  • pls rate me or vote for me on how its works.
    Feb 05, 2011 | RCA F27442 27" TV
    My Kenwood KRFv5300D is working throught the tuner / radio channel but wont play sound from the TV - I have a digitial cable running from the amp to the TV but nothing else - should i have more cords then...
    The only way it cCOULD work would be from a Digital Audio Output to a Digital Audio Input.
    What is the model of the TV? Does it REALLY output a digital multichannel audio program? TV's aren't generally known for their audio chops and some of us own monitors with NO speakers or sound capabilities. Hence we buy things like Kenwood receivers and better speakers.
    I would recommend that you draw the TV-related audio from the same place the TV gets it - Cable / DVD / BD. The audio hookup is simpler and the fewer intervening connnections, the better.
    Apr 22, 2010 | Audio Players & Recorders
    I have a SA 8300HD cable box connected to Yamaha RX-V2500 receiver using Digital Audio Out from cable box to DVR/VCR2 on the receiver. It had been working for 2 years. Then this past weekend it stopped...
    Pretty good problem description.
    Make sure the DVR/VCR2 digital input is assigned to the Cable box.
    When the DVR/VCR2 input is selected do you get any front panel indicators on the Yamaha that indicate a good digital bitstream?
    Try swapping the cable box output to the working DVD In connection to isolate it to either the source or the receiver's ability to decode it.
    Check the audio output settings for the Cable Box, too. Sometimes their outputs are adjustable. It may be muted or set too low.
    Mar 31, 2010 | Audio Players & Recorders
    Can not get this monitor to play sound on PC using XP Version 5.1. a driver needed?
    there is not a windows xp 5.1 so I am going to take a wild guess and you mean you want 5.1 surround sound
    If your computer plays sound through its own speakers normally then you do not need a driver.
    I took this from the FAQ
    1. Make sure the audio cable is plugged in to the back of the monitor and in to the Green port in the back of the computer.
    2. Press the Right Arrow button on the monitor itself and set the volume to 10.
    3. Double check your audio settings on your computer and make sure nothing is muted.
    This is not one of the better monitors in this price range having only a VGA input but is suitable for most people.
    Aug 14, 2009 | Sylvania CL772B 17" Flat Panel LCD Monitor
    My marantz DV 9500 doesnt output digital signal for audio cd anymore but outputs audio for dvd,sacd,dvd audio. Does it need servicing
    Make sure your playing componet like CD player have a digital output socket. Connect this to a digital port on the amp witk a single RCA or Optical cable if output available on CD. Make sure the digital assingment in amp is set for cd function and corresponding input(example cd plyer connected on dig 4 input on amp, press menu, setup, assignment, go to cd player, make sure setting on dig 4 or change input to dig 4, go to next component to memorise setting.and exit, see manual to assist you) if still no sound take dvd cable for instance that is working and put that in dig 4 port. if that works check in cd player that settings spdif/raw/pcm is correct one for yor digital output if still no sound soun pc board faulty.
    Aug 11, 2009 | Marantz DV-9500 DVD Player
    Dvd player plays the movie but there is no sound
    insert a normal music cd for 5 seconds eject. put your dvd movie back in
    Mar 05, 2009 | Cyberhome CH-DVD 300 DVD Player
    Cyberhome CH-DVD 300 DVD Player Logo
    77 people viewed this question
    Top Cyberhome Televison & Video Experts
    zappal
    Demonic-2011
    Demonic-2011
    Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
