Question about Epson Stylus Photo R1800 InkJet Printer
Epson Stylus photo R1800 loaded with Media Street inks...problem
Even after MULTIPLE head cleaning cycles there are narrow horizontal bands of missing color, particularly noticeable in sky and other solid tones
  • Epson Master
  • 19,396 Answers
Narrow horizontal bands of missing color is not a driver issue, that is a bad traction controller on printer mainboard.
you can just try reinstalling drivers from printer disk, but that usually does not solve the problem.
To fix it you need to replace printer mainboard.
Posted on Mar 09, 2009
    Scholar:
  • 162 Answers
It is a driver issue and should be reintsalled with apropriate driver from website as this usually comes with any patches which you will need for it. if this doesnt work then the contacts on the back of your ink cartridges might have excess ink on them and need cleaning which is hard but possible as long as you use ink replacement options and then dissconect from mains. if you use spirit for this it will evaporate before doing any damage to circuit boards. hope this helps
Posted on Mar 05, 2009
    Scholar:
  • 77 Answers
Do a heads alignment, not clean the heads. That should remove the bands.
  • 544 Answers
HI,
thank hou for choosing Fixya.com
it seems that your printer head is the problem.
i strongly suggest you that take your printer to a service center and ask them to check your printer head we hope that they can still clean it and no need to change the parts.
  • Mark Milan silaran
    Mark Milan silaran Mar 05, 2009
    HI,
  • 154 Answers
Will you please explain more,
try to print a self print page and give the statius of the quality.
Epson Stylus R1800 is not printing correctly. It is skipping spots leaving clear areas across the page. Changed all the cartridges.
your problem is not with the inks it is with the printhead... try running the maintenance and head cleaning... epson is notorious for print heads getting clogged!! good luck
Mar 31, 2010 | Epson Stylus Photo R1800 InkJet Printer
Banding
If your print head alignment is good, try printing at the slowest setting for the mean time until the banding is gone.
Jan 14, 2010 | Epson Stylus 1400 InkJet Photo Printer
Anyone know how to fix banding in dark areas of photographs?
I see your problem. You need smap and eject adjusment (PF adjusment), using R1800 adjsument program. Try to find at indoreset.blogspot.com
Jun 26, 2009 | Epson Stylus Photo R1800 InkJet Printer
My yellow ink head on my r1800 printer is clogged.
If it is within warranty then contact epson support. If not and normal head cleaning doesnt work then try a print head cleaning solution such as:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Hope this helps.
Mar 12, 2009 | Epson Stylus Photo R1800 InkJet Printer
R1800 head streaks
I have been plagued by the same problem - the nozzles don't appear clogged - yet on heavier media there is a definite abrasive sound - and its leaving horizontal bands. After many cleanings with no luck I tried cleaning the heads with a bunch of Q-Tips lightly coated in Windex. After removing a ton of black deposits - it didn't immediately fix the problem; frustrated I turned the printer off. The next morning when the clean-heads-on-power-up kicked in - I noticed a large amount of ink collected in the vacuum sponge. It seams the bit of reside left over from the cleaning may have finally dissolved what I can only guess was a large ink deposit that had hardened and was striking the media when heavier stock was loaded. At any rate - no more abrasive sounds - and more importantly no more horizontal banding.
To clean I disconnected the power when the head was traveling. Then the head was free to move as I gently tried using the Q-Tips to clean the heads.
Hope this helps.
Dec 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Cyan will not print
Try replacing the cartridge. Sometimes they do get clogged and won't clear no matter how many cleaning cycles you run.
....John
Mar 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
How to remove print head of epson stylus photo r1800
Had the same problem - but the print head is actually easy to remove.
1) Remove ink cartridges
2) Remove 3 Phillips head screws at the bottom of the cartridge housing. (looking down from the printer front - top left, bottom left, top right).
3) There are 2 small plastic tabs on a plastic bracket that secure the flex cable on the right hand side of the cartridge housing. Gently release the tabs with a small flat head screw driver.
4) Lift the print head straight up (don't pull on the flex).
There may be a release for the flex to separate from the print head. But I did not see one. Instead I poured 1/4" of Windex in the bottom of a small plastic container and soaked my print head for about 15 minutes (occasionally agitating).
Then put back in reverse order - be sure to seat the flex in the guide (top-back-right) of the cartridge housing before screwing down. Then run a cleaning or two to flush the cleaning fluid out of the print head. (I have a waste ink tank installed so I am not worried about dumping excessive ink into the waste sponges).
The differences was remarkable - though there was still slight banding - maybe should have soaked longer (1 hr perhaps?) - I may repeat if it remains an issue.
Additionally there were large solid deposits on the left side of the print head which were responsible for scraping heavier weight photo paper. These dissolved in the Windex too.
Jan 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
26 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
