Question about ASUS My Cinema-P7131 (90C1VFV00UAYZ)
My PC Cant display when i insert tv card into PCI Slot
Hi.Actually my problem is may be diffrent from others,my (MyCinemaP7131) is not working.i mean when i insert tv card into PCI Slot my pc cant displaying,i think its tv card fault.if iam not wrong then suggest me that is it possible to repair it? or there is no technician to solve my problem?
  • Anonymous Mar 07, 2009
    Actually sir my tv card is faulted hardware.i use it 1 year now its occur problem of hardware of tv card,there is no problem of softwares or tv signal.i say that when i insert tv card into pci slot of mother board my pc cant displaying!
    Problem Solver:
  • 14 Answers
Hard to understand what you mean.
Make sure all the neccesary software and drivers are installed, and obviously make sure your TV signal is strong enough.
Posted on Mar 05, 2009
PLEASE HELP .QUESTION BELOW
Did you move the lead between the computer and the monitor onto the new board you installed?
Mar 09, 2015 | Computers & Internet
Use of PCI-e x16 slot for non-video card
...........................................!O_O!...........................................................
WHY would you want to do that?
There is a PCI-Express x1 slot on the motherboard.
Black in color, and in-between the black PCI-Express x16 slot, and a white PCI slot.
Use the PCI-E x1 RAID adapter card in the PCI-E x1 slot, and a PCI-Express graphics card in the PCI-E x16 slot. Sheesh!
A PCI-Express slot is not an evolved PCI slot.
Completely different technologies.
PCI uses a shared Parallel bus architecture, while PCI-Express is based on Serial point-to-point.
So your idea of how to 'fix' your problem, is to use a PCI-E x1 card in a PCI-Express x16 slot, and a PCI graphics card in a PCI slot?
Completely backwards.
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
PCI-Express x16 slot uses the same lanes from the Northbridge, as the OnBoard video?
UTTER NONSENSE!
The Northbridge chip handles the Faster capabilities of a computer.
Handles the Processor, Ram Memory, and HIGH-SPEED Graphics.
HIGH-SPEED graphics is the Accelerated Graphics Port (AGP) technology, and the PCI-Express technology.
The Southbridge chip handles the Slower capabilities of a computer.
The PCI bus is one of those slower capabilities handled by the Southbridge chip.
The PCI bus is also a shared bus. This slows data down.
The AGP bus, and PCI-Express bus are Not shared. They also have a direct link to the Northbridge chip.
The PCI Bus has to go through the Southbridge chip, which has to go through the Internal Bus, THEN to the Northbridge chip.
OnBoard video, or Integrated Graphics, uses the PCI bus.
When you inserted the PCI-E x1 RAID card in the PCI-Express x16 slot, and a PCI graphics card in the PCI slot, BIOS just assigned another IRQ for the PCI-Express x16 slot.
(Interrupt Request)
No fancy technology going on there.
Backwards technology going on with a PCI-Express x1 card in a PCI-Express x16 slot, though.
I do not concur, and do not think that is a good solution, Kevin.
Regards,
joecoolvette
Aug 24, 2012 | Gateway Foxconn C51GU01 Motherboard
Purchased D-Link PCI Express card for my Dell desktop Dimension E521 and can't figure out if my computer has a PCI Express slot?? please help???
every computer will have at least one pci slot its white in color i insert your card in to the slot and press it tightly and screw the pci card to cabin and insert the cd received with the pci card and install them
Dec 15, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Install VGA of Video card
with your VGA card in pci slot locate the vga pci slot in our motherboard insert it firmly. Turn on the pc and make it sure that pc detects your new card and install the vga card driver supported by the manufacturer.
Feb 09, 2010 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Server power issues with PCI cards
Have you tried inserting it in a different PCI slot? I understand that this one in not faulty, but obviously the HP isn't getting its POWER OK signal ...
Mar 18, 2009 | HP ProLiant ML110 Server
PC not booting when AVERmedia TV tuner card is inserted
Techguru2009: Seems you might have a conflict with your I/O. You need to reset the bios either by loading defaults or just remove the CMOS battery for ten minutes. After start the computer without the pci card. If all is well, then shutdown. insert the card in a different slot on the motherboard. Power up and the bios should recognize the update. Hope this helps.
Jan 28, 2009 | Gateway GM5084 PC Desktop
Sign of the Dead Videocard?
There is a problem in your display card. please replace it. Insert an graphic card into PCI slot of motherboard. The PCI slot will be in white color. Thank you..
Sep 10, 2008 | HP Pavilion zd8000 Notebook
PCI slot no working
Hi Adam, you did a great job trouble shooting your system & you even answered your own question. If one PCI slot works the other should but since you tested that you're self & the PCI slot failed than the PCI slot is bad. My guess is one or more soldered points under the PCI slot. (Underside of the motherboard) is cracked or broken. It may be possible for you to re-solder the cracked or broken joints. The only way to prove this theory will be to remove the entire motherboard from the case & visually check every single joint. There is no single driver for the PCI slot. The PCI slots are part of the chipset driver which is already installed. There is alway replacing the motherboard.
Great job Adam!
Mike
Aug 12, 2008 | MSI K9VGM-V Motherboard
No video
ok fine i think there exists some problem in the cable connecting from the CPU to the monitor just try removing that & inserting it again ....
if the same problem persists then there may be some problem in the port of the video card just take tester & test is there power supply or not ....
if there is no power supply then some of the capacitor on the video card might have burned out due to this ports will not be working ....
if there is power supply then there will be one IC(integrated circuit ) on the motherboard just near by the AGP or PCI express slot (i think in your motherboard there are 3 IC s near there)
in those 3 IC s if some IC goes means also you will not get the display ...
(the video must be inserted to the PCI express slot or AGP slot only) you must not insert it on PCI slots ...
you make a difference of PCI or AGP slot as this will be only 1 or 2 on every motherboard & it will be smaller in size than the PCI slots & there will be colour difference(may be the PCI slots will be white colour & AGP or PCI express slot in black or brown colour it depends on the motherboard)
check on which slot you have inserted it & insert it correctly if you inserted in some other slots ...
remove the video & insert it again & try check the cables the cable may be loose contact ...
any doubts you can reply me
i am always here to assist you
thank you
bye
dnt forget to rate my solution
Jul 03, 2008 | Computers & Internet
Video card
Okay an AGP video card will go into a brown slot but not all computers have one, especially dells. The computer should automatically detect when a new video card is inserted and run off of it bypassing the onboard video. If you do have a brown slot and it's different than the connection of the video card you purchased, then you need a PCI express video card. This slot can be other colors as well. If you don't have a PCIe slot then you need a PCI video card that will go into one of the available white slots on your motherboard.
That being said, when you said the colors weren't great, what exactly did that mean? You may just have needed to tell the computer to display in high quality (32 bit) or change the options in the game to do so.
Jun 14, 2008 | Compaq Presario S4020WM PC Desktop
ASUS My Cinema-P7131 (90C1VFV00UAYZ) Logo
299 people viewed this question
Top ASUS Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Michael Galve
Michael Galve
David Payne
David Payne
Are you an ASUS Televison and Video Expert? Answer questions, earn points and help others
