Question about Numark CDN95 2-Disc CD Player
While playing, Player 'freezes' so all functions fail
I loaned my new CDN95 to another dj and unfortunately, upon its return, has been malfunctioning. After a few minutes of playing, (sometimes in less than a minute of playing) it 'freezes'. There is 'sound' coming from the cd being played but just that bit where it 'freezes' and is unintelligible. I have been told that it is the power supply, (specifically, the 68 uf - 400 Volts capacitor). However, since I have no tech manual, I have taken such council with a pinch of salt and have not tried to fix it. Ideas? Anyone?
  • 3 Answers
Hmmm - slide the lid back and put a meter across the 3 power transistors that should be on the power supply board - seen from the top. (do this with the power off..:)) You may find once these warm up - which doesn't take long, they are breaking down
Posted on Nov 23, 2009
Turntable is starting to slow down as it is playing
This maybe a failing motor or belt. I would take it to the repair shop to be sure which.
Mar 07, 2016 | Crosley Cruiser 3-Speed Portable Turntable...
Alright well I have a Numark rack mount dj set with two CDN95 2 disc players. Well I bought it used with speakers and everything and do not know how to plug everything, I really need some help please...
As shown in the Quick Start Guide (link below) this unit should be connected to a Mixer Unit.
http://www.numark.com/stuff/contentmgr/files/0/662529d8e9e5b8ebe1747274e5bad9d6/file/cdn95_quickstartguide.pdf
Looking at the Diagram they appear to be standard AV Cables so you should just be able to plug the CD Outputs into the Amp AV Inputs (as long as it's a Dual Amp) and then connect your speakers to the Amp (make sure the speakers impedance matches the Amp.
Further details available at http://www.numark.com/cdn95?tt=5
Please leave feedback
Cheers
Andy
Apr 25, 2011 | Numark CDN95 2-Disc CD Player
Hello, How would I repair and find parts for a
What I do is first look on ebay for the same item in spares or repair. Buy it cheap and swop out the damaged/broken bits.
If that fails I download the service manual. Can take some google effort, but it can be found. By using the service manual, you will be able to repair and replace any part of your cdn95, assuming your not affraid of a little work and electronics.
If you are, then I suggest a visit to your nearest electronics repair shop is in order
Jan 06, 2011 | Numark CDN95 2-Disc CD Player
ION Discover DJ mixer "Scratch/Search" switch
plug in the turntable first, then start the program.
if all lights are lit try again .
hope it helps
Dec 24, 2010 | ION Audio Discover Dj Turntable
Hello i have the numark cdn95 2 disc cd player had a power outage in my home i did not have my numark cdn95 plug up to a surge and when i push the power button the buttons key lock light up and it wont...
Hi. Here is a link to a free download of your manual http://safemanuals.com/user-guide-instructions-owner-manual/NUMARK/CDN95-_E
Often times, a surge will require going into the machine and replacing one or two fuses. This is not an expensive job. Most all stereo shops have the capability to do this for a few dollars. Joe
Oct 21, 2010 | Numark CDN95 2-Disc CD Player
Dell dj is non functional
Hold play button while inserting a paperclip into reset opening on dell dj. Release paperclip while still holding play. Recovery mode should come up hopefully.
Dec 25, 2008 | Dell DJ MP3 Player
Numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Oct 13, 2008 | Numark CDN95 2-Disc CD Player
DVD Player freezes on some commercially produced DVDs
The microprocessor or memory componets on the player isnt functioning asits supposed too. This is rather troubling and there isnt any easy fixes possible.. My suggestion is seeing as its new return it and get a replacement. Chances are it will fail very soon.
Jul 09, 2008 | Insignia IS-PDVD10 Portable DVD Player
Help with dvd player DRC282 remote code
I purchased this same DVD player (DRC282) and none of my universal remotes worked for it. Since I was lucky enough to buy one without a remote, I ended up purchasing an RCA universal remote (RCR3273). Once again, none of the codes worked so I had to unplug the unit for 5 minutes, then plug it back in and hold the Standby button for 15 seconds to return it to it's factory settings. I manually searched through 71 codes before I found a match but the play, pause, rewind and many other functions failed. I tried again skipping over 71 and found the right code at 115 tries. That one had all the functionality I needed. You should try the same strategy with your Comcast universal remote. Skip the first match and keep going until you hit the second manual match.
Apr 09, 2008 | Televison & Video
Numark CDN95 2-Disc CD Player Logo
169 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
