SOURCE: booting trouble...
I recomended u first to clear CMOS settings and if it wont work so the bios need to flash...
Befor u flash it open it and check everything -if all cable are connected correctlly ram hdd pw
Try also to boot up without HDD
IF ALL THOSE WONT WORK JUST LET ME KNOW I WILL HELP YOU.OK?
SOURCE: Won't boot
was there any changes done to your system like upgrading anything
All your power seems to be on right
SOURCE: won't boot
I had this too. It kept happening after I would install updates. I think the problem turned out to being that my harddrive (only 4GB) had run out of space.
The way I ended up fixing it was to turn the power off by holding down the button, turn it back on and hold the F9 key. This allowed me to "restore factory defaults" and it booted up again. I lost all the changes I had made, so if you had settings saved, this may not be your best option.
If it is a harddrive space issues, I would recommend getting to the console (CNTRL+ALT+T) and then typing "sudo synaptic" to get to the package manager. You can then remove packages that you no longer need or want to use (like the kids games, possibly Skype). This stuff is a little advanced, so if you're not sure of what you're doing, you may end up changing something you didn't mean to and needing to start back over again by restoring defaults.
SOURCE: asus EEE PC 900A Linux- boot problem after downloading updates
Consider downloading a specific release of Ubuntu; eeebuntu. Download the ISO and then conenct an external DVD device to it, during the BIOS screen, choose the ESC button and boot from the external device.
This Ubuntu-specific group offers three kinds of ISO's (simple, super basic, and a loaded release), all of which allow all parts to work out of the box:
http://www.eeebuntu.org/
If this does not work, check the informal eeepc forums
http://forum.eeeuser.com/
