Question about Syscan DocketPORT 465 Scanner
"The scan was aborted because the scanner was not powered on....
...or not connected properly"
That is the message I get while attempted to use my DocketPort465 scanner. Trouble is, the scanner is connected properly on both ends. I uninstalled and then reinstalled the software and I am still getting this message. Help?
5 Suggested Answers
SOURCE: Epson 3490 Scanner not communicating properly with PC
The new PC was Vista and the CD that came with the scanner completed loading a driver without complaint. However, a new driver was needed for Vista. After downloading the new driver from Epson, uninstalling the old driver and installing the new driver, it worked.
Posted on Mar 06, 2008
mohanchennai
  • 490 Answers
SOURCE: can't uninstall microtek 5900 scanner
This is a funny problem. Try & locate SCanwizard 5 files and delete them. Complete the registry deletion as suggested. Run scandisk. Install and uninstall Scanwizard 5.
Posted on Mar 09, 2008
  • 79 Answers
SOURCE: Exact same problem
firstly I hope the model number is correct. if yes try once again the following steps.
disconnect the Docketport from usb. go to device manager and see there devices marked with yellow exclamation mark. remove them and restart the windows.
1. download the driver and install it
http://www.docucap.com/drivers/DocketPORT465_v1_1_4_setup.exe
2. secondly Docketscan application is needed ..download it too and intall
now try connecting the dockerport
I hope this should make things work.
Posted on Aug 07, 2009
muntejaya
  • 10421 Answers
SOURCE: Problem with DocketScan ii software
Please install again the driver. You can get it downloaded at : www.nodevice.com/driver/company/Lexmark/Printer.html
www.lexmark.com/
www.driverslab.com/drivers/Printer/Lexmark/9/63.html
Posted on Feb 12, 2011
Won't Scan -- "Cannot properly communicate with the scanner"
I think the USB cable is defective or the scanner is failing.
Apr 25, 2017 | Epson Gt-15000 A3 Flatbed Scanner Eu-45
Perfection 1670 Flatbed Scanner: When I try to scan I get a message saying: "Can...
Do the following:
Uninstall the scanner from your computer
Restart
Re-install all software and drivers with the original CD * if you dont have the drivers check the manufacturars website *
Restart again
And then it should work fine. If this fails use the scanner wizard in Windows Control Panel and follow the step by step instructions.
May 18, 2010 | Epson Perfection 1670 Flatbed Scanner
Scanner does not work when requested from HP Director
Make sure the cable is plugged all the way in to the printer it gets loose for some reason and have had this problem my self many times. I replaced the US plug and mine went away but test the cable first.you can go to WWW.hp.com and support and read the Trouble bullitins for this printer and you will find a white paper or TSB on this.
Sep 28, 2009 | HP PSC 1315 All-In-One InkJet Printer
The software cannot communicate with the scanner (Prime Film 3600
I have a PrimeFilm 1800u. When I attempt to scan into a Roxio application, the program does not respond. The hardware and software are both installed. No problems scanning or communicating with this scanner before. Is there somethere there that has a soultionfor this problem ? Thanks
Mar 16, 2009 | Pacific Image PrimeFilm 3600u Film Scanner
Server is busy message
How I can remove the code LL-91 from my printer xerox 510
Jul 23, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Mar 05, 2008 | Epson Perfection 3490 PHOTO Flatbed...
Us sertek scanner
Does the scanner also have a usb
connection?
Nov 16, 2007 | Office Equipment & Supplies
Scanner not responding to preview scan
Try this as a last ditch effort. Remove the software. Reboot the computer and come off line. Disable the Anti Virus program. Now install the soft ware. Then try. If the red light still flashes then assume it is new scanner time.
Jul 26, 2007 | Epson Expression 1640XL Flatbed Scanner
Getting error code Code[ffff:0024]while scanning
while i am trying to scan the images .. i am getting the error code like Code[ffff:0024] while warming up the scanner, besides a sound from the scanner making it power off (light inside the scanner goes off ) so that i could not get scanned anything ... what will be the reason ? please suggest me the trouble shoot kaarthik
Apr 14, 2007 | Acer Scan to Web 3300U Flatbed Scanner
Syscan DocketPORT 465 Scanner Logo
903 people viewed this question
Top Syscan Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Syscan Office Equipment and Supply Expert? Answer questions, earn points and help others
