Question about Kenmore Refrigerators
Odor in freezer
Odor coming from fan in freezer section of refrigerator
If its a foisty dirty water smell. it could be build up of dirty water in the the heat exchanger at the back at the base just pull it out and soak it up give it a good clean up and check for blockages etc could save you a few quid
Posted on Mar 06, 2009
3 Suggested Answers
  • 1073 Answers
SOURCE: odor like gas coming from freezer section of elecric refrigerator (Hotpoint)
wou ld unplug the machine and ventalate the room and call for a&e factory service ( sears) 800-805-9505 to be sure
Posted on May 05, 2008
  • 89 Answers
SOURCE: When motor comes on there is a stale,odor
check around the compressor area and the drain pan there might be a mouse or something dead under there make sure to unplug the fridge before you go messing around back there
Posted on Jul 11, 2009
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
I have an oder in my fridge and freezer. no spoilage in there. both the fridge and freezer has an odor and gets into all the food. cleaned it out, shut it off for a day and still i have it. would would...
ok.its a very common issue.just tie a handful of baking soda in a soft cloth and keep such1 or 2 pads in both the freezer and fridge section.this will absorb all the bad odor within a day or two.once the odor is gone throw the pas away.repeat this once in three months to prevent the bad odor from coming again.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 28, 2010 | Amana ABB1927DE Bottom Freezer...
I can smell items in my freezer when I open the door of the fridg
Good day,
All cooling in a refrigerator, be it the freezer section, or the fresh food section is performed by the freezer.
The freezer takes care of itself, but also by the function of the fan motor in the freezer, blows a limited amount of the freezer air into the fresh food compartment to cool it to the nominal 37 degrees.
The odor in the freezer is disguised by the extremely cold air, and is not apparent. But that odor when raised to 35 or 40 degrees will become noticeable.
As well, the freezer compartment rises to 30 degrees plus when going thru it's automatic defrost cycle, which occures for approx. 30 minutes once or twice a day, adding to the problem.
Sealing the packages is probably the only real answer.
Thank you for using FixYa.
Dec 18, 2009 | Kenmore Refrigerators
Have alful odor in freezer and ref,had some things spoiled and lefted bad odor in freeer and smell went into ref tooked everything out and washed them out good, and put backing soda in but smell was still...
empty the unit and put a dish of charcoal in the frig and the freezer. Let it run for a week and see if that helps. Some odors will get into the plastic and insulation and cannot be removed.
Eric
Nov 19, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Is it possible to turn OFF completely the refrigerator section and leave ON the freezer section of our side by side, so that we can use the freezer only. We do not need the refrigerator section.
Don't know which refrigerator make/model:
There are two dials, one for refrigerator and one for freezer.
Set refrigerator dial to lowest setting, leave freezer setting alone. Refrigerator will still operate at warmer swetting so it will not create mildew or odors... use odor-killing soda.
You might store foodstuff / cans/sealed boxes of cereal, flour, etc.
Sep 19, 2009 | Refrigerators
Jul 11, 2009 | Kenmore 50522 / 50524 Side by Side...
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
Foul odor coming from freezer. Kenmore model w/ freezer on top.
Clean the refrigerator thoroughly fresh food and freezer under all drawers. Then place charcoal briquettes in each 8 or 10 total. 4 or 5 in the bottom of the fresh food section. leave the for several days. If that doesnt take away the smell consider if a mouse may have gotten into a fan blade and well that can create a really bad smell.
Jan 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Odor like gas coming from freezer section of elecric refrigerator (Hotpoint)
May 05, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Bad odor in freezer
the only source for odor in a refrig is from food. check to be sure that nothing has gone bad in the refrig section as well as air circulates back from the fresh food section as well as the freezer. if you stil cant find odor source try charcoal or unscented kitty litter in a small container to help remove bad odors..
Dec 12, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
105 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
