FixYa.com
Tags:
Gateway MX6920 PC Notebook
Recovery Console will not install in MCE 2005 SP2
By Bouncy - usenet poster
I tried to install the Recovery Console in Windows XP MCE 2005 SP2, but an
error occurs, and continues to install. However, after the Recovery Console
installation and restart of Windows, there is no prompt to enter in to the
Recovery Console.
I run:
E:\I386\WINNT32.EXE /cmdcons
This Windows Setup error message displays:
The option to upgrade will not be available at this time because Setup
was unable to load the file E:\I386\WINNTUPG\NETUPGRD.DLL.
The system cannot find the file specified.
Then the Windows Setup window displays that the Recovery Console needs
approx. 7MB of disk space to install and click Yes to install or No. I
click Yes and the Recovery Console installs without any errors. The last
dialog window that appears shows that the Recovery Console successfully
installed.
Anyone else experiencing this error or is this a known problem?
Thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Rogers
Rogers - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I reloaded Windows XP MCE 2005 SP2 on the laptop because I thought possibly
one or more files may have been missing from the pre-installed Windows XP
MCE 2005 SP2 installation on the laptop due to this error and it occurs
again after installng the Recovery Console. Thus I have essentially
completely removed the Recovery Console and installed it again.
This is frustrating! :)
I will remove the Recovery Console per the instructions, but I doubt it will
do any good after I had already reloaded the Windows XP MCE 2005 SP2 on the
laptop.
Any other suggestions in the meantime?
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
pandamama
pandamama - usenet poster
Rating: 0%, 0 votes
You could try completely removing the Recovery Console and then reinstalling
it, to see if the error message recurs.
(delete instructions also on the same page)
Jon
The problem with troubleshooting is that trouble shoots back.
There is plenty of evidence to suggest that "Mark"
<nipperspot-at-hotmail-dot-com ...
Solution #3
Not Rated (0)
Jimmy NY
Jimmy NY - usenet poster
Rating: 0%, 0 votes
The Gateway MX6920 laptop has a system restore feature that displays some
text with a two second countdown to press F11 to enter the System Restore
(second partition on the hard drive -- D:). This is blocking the Recovery
Console prompt appearing, however, if I press the space or an arrow key, the
menu does appear where I can boot in to either Windows XP MCE 2005 or
Recovery Console. When I select Recovery Console, this error occurs:
File \minint\system32\biosinfo.inf could not be loaded.
The error code is 14.
Setup cannot continue. Press any key to exit.
Now I need to figure out why this occurs. I could not find anything in the
Microsoft Knowledge Base about this error or problem.
Any suggestions or solutions on this error?
Solution #4
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
Couple of possibilities
(1) The "timeout=" setting in your [boot loader] section may be too low.
(2) Your system is using another boot.ini on one of your other drives (ie
another drive is the active partition) if you have a multidrive setup.
Jon
Now that we have all this useful information, it would be nice to be able to
do something with it. Actually, it can be emotionally fulfilling just to get
information. This is usually only true, however, if you have the social life
of a kumquat.
-UNIX Programmer's Manual
Solution #5
Not Rated (0)
man1
man1 - usenet poster
Rating: 0%, 0 votes
Thanks for the information.
I checked the c:\boot.ini file and it shows the following in the [operating
systems] section:
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows XP Media Center
Edition" /noexecute=optin /fastdetect
C:\CMDCONS\BOOTSECT.DAT="Microsoft Windows Recovery Console" /cmdcons
and the C:\CMDCONS directory exists along with the BOOTSECT.DAT file.
I'm not sure why the prompt is not displaying on boot up.
Solution #6
Not Rated (0)
lawyer
lawyer - usenet poster
Rating: 0%, 0 votes
It should still install successfully despite any message about an upgrade
option being, or not being available.
It should add a line like
to your c:\boot.ini file.
You could try adding that manually.
Check your various drives in the root folders for a folder C:\cmdcons,
D:\cmdcons etc. which is where Recovery Console is stored.
Jon
If you would be well served, serve yourself
It's certainly worth mentioning that "Mark" <nipperspot-at-hotmail-dot-com had previously written the following in message
Can you Help with these PC Laptops problems?
PC Laptops
wi-fi driver can't be installed...
in my acer aspire4710z i can't... Answer This...
PC Laptops
windows cannot communicate with...
please can you help me as this... Answer This...
PC Laptops
New ASUS G50vm-x1 from Best Buy
I bought this laptop yesterday,... Answer This...
PC Laptops
acer aspire 4720z audio driver...
can't load the audio driver on... Answer This...
We need to talk
Get a hold of me at... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
