Question about Sony Computers & Internet
Bottom of sreen on my sony vaio disappearing
I have a sony vaio which i have hardly used the screen is disappearing been told by sony that it with cost 260 pounds to fix
I have acer arbicam i need soft ware drive free
Posted on Mar 05, 2009
Dark sreen
put some dark covering over the logo
May 15, 2014 | Sony Vaio VPCEA36FM
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
I have a Sony Vaio PCG-2J3L and when the lighting for the screen is on bright the screen will stay lite for a couple of seconds and then go black but you can take a flash light and turn it on the scre
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 04, 2012 | Computers & Internet
How do i reboot my laptop
Restore to factory settings
Restoring your Sony VAIO computer to its original factory settings is a great way to remove old programs and files that are buried within your computer that you no longer need, or to get rid of a virus that you just can't seem to shake.
This process will allow you to start anew with your computer, and can potentially save you from simply throwing the computer away because you don't think it can handle the workload anymore and spending money on a new machine.
Unplug any cables connected to your Sony VAIO machine with the exception of the power cord and monitor.
Click "Start" in the lower left corner of your screen.
Click "Control Panel."
Click "Performance and Maintenance."
Scroll down to the bottom of the Performance and Maintenance screen and click "VAIO" recovery wizard. The VAIO Recovery Wizard dialogue box will appear.
Click "Next."
Select "Proceed with System Recovery" and click "Next."
Select "C Drive Recovery" and click "Next."
Click "Next" to confirm that you want to proceed with the C Drive Recovery.
Click "Finish" to restart your Sony VAIO machine and initiate the recovery procedure.
Upon restarting your computer, the Sony VAIO Recovery Wizard will prepare your hard drive for recovery and then restart your computer again.
The necessary files will be copied to your computer and your hard drive will be recovered.
Click "Finish" when a screen appears telling you that your recovery process is complete.
Your computer will restart.
Click "Next" when you arrive at the Windows setup screen.
Follow the on-screen instructions to setup your version of Windows.
When you have finished setting up Windows, click "Finish."
Upon restart, the Sony VAIO Recovery Wizard will install necessary files on your computer.
Your computer will restart automatically when these files are installed and your Sony VAIO will be restored to its original factory settings.
Hope this helps
Oct 14, 2012 | Sony VIAO Laptops (Laptop NOT Included)...
How do I restore my Sony Vaio PCG-Kits orginal
try strart --> all program --> accesories --> system restore
Nov 18, 2009 | Sony VAIO PCG-K23 Notebook
System recovery #2 doesn't work
take out recov disks and do this to restore ur system to factory default all data will be wiped off from C:
Sony: When you first turn on the laptop and see the VAIO logo screen, press the F10 key (you need to do this before the VAIO logo disappears).
tell me if it helped and rate me well or ask for more!
Apr 08, 2009 | Sony VAIO PCG-V505EC Notebook
My VGN FS920 shuts down at the window loading screen
ok no need to get a bcakup disk or downlaod anything
if ur hard drive is original factory fitted
and
ur laptop came with pre loaded OS as XP
then do this without disk
pls let me know and rate me FIXYA for help
Mar 31, 2009 | Sony VAIO VGN-FS920 Notebook
IS Toshiba mk6006gah HARD DRIVE COMPATIBLE WITH SONY VAIO
I know someone that bought a toshiba mk6006gah for his sony vaio TR1 series, so i think it is. Just look at the harddisk the local shop took out for you. Somewhere on the disk is told wich size it is. You could also give me the typenumber of that disk. Then i could tell you the size for certain.
Mar 27, 2008 | Sony VAIO TR1MP Notebook
Sony Vaio has touchy screen
it seems as if its a technical mistake, if its in the warranty period do contact the service provider at the earliest
Feb 27, 2008 | Computers & Internet
Computers & Internet Logo
109 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
