Question about InFocus Proxima UltraLight X350 Multimedia Projector
Infocus Proxima UL X350 lamp replaced.
When powering up, unit says to replace the lamp; but, it has just been replaced. Is there a reset somewhere?
  • 2,237 Answers
In the menu, there is a settings option. you can reset the lamp timer from there.
Posted on Sep 04, 2009
Tip
How to reset the lamp timer for Panasonic DLP TVs.
When you replace the lamp on a Panasonic DLP or LCD TV you will need to reset the lamp timer to zero for the TV to reset the lamp timer and extinguish the change lamp indicator.
There are two methods used depending on which model TV you have. The older units use the first method and newer units use the second method. You can tell which method you need to use by whether you have a PIP and/or SPLIT button on your remote. If you have them use the first method, if you don't use the second method.
Method number 1 (for older units):
Follow the procedure below. You use either PIP or SPLIT button depending on whether your remote has SPLIT or not. Some do not.
Perform lamp timer reset only when the lamp has been replaced. The idea is to know when to replace the lamp before the end of it's life when it could explode or short out causing a hazadous condition. If you reset the lamp circuit at any other time the replace lamp warning will not come on at the recommended interval.
Be sure the power cord is plugged into a properly grounded wall outlet.
Then, press the POWER button on the projection display or the remote control to turn the unit on.
While pressing the VOL- button on the projection display, hold down the
PIP or SPLIT button on the remote control at same time for more than 5 seconds.
If your remote does not have a split button you use PIP, if it has a split button, you would use SPLIT.
When reset procedure is complete, the screen on the TV will indicate that the lamp has been reset. When lamp time reset is finished, the LAMP indicator goes out.
Method number 2 (for newer units):
Press volume down on the TV and the zero button on the remote at the same time for longer than 5 seconds and it will reset the lamp to zero.
These procedures should reset your lamp timer and you will be good until the current lamp fails or the change lamp indicator illuminates again signalling that it is time to replace the lamp. Three to six years on average depending on how much you run the unit per day. Do not ignore the indicator. Change the lamp immediately to avoid further damage and expense or worse.
Thanks for using FixYa and for the great rating.
hardrocko
on Apr 11, 2010 | Televison & Video
T.v.says lamp not working
If the display indicates then it is possible that the lamp has failed or that the Power to the lamp is cut off. You will need to check the status of the lamp and also the lamp connectors, the supply from the power.
Check to see if the cooling fan is clogged and so has reset the processor with a error. If so clean the filter to reset.
Jun 30, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
How do you replace the lamp for a panasonic PT-50LCZ70
Hello
To replace the lamp of your Panasonic Projection TV do the following. Read these instructions carefully and then try to do the job.
1. Turn the power off, wait until the power indicator turns off blinking red, then unplug the power cord from the wall outlet and confirm that the area around the lamp unit has cool down.
2. Remove the front cover procedure. Place your finger tips under the cover and pull it from the projection display.
3. Before loosening the lamp cover screw, first read the caution and warning labels in the lamp cover. Then loosen the lamp cover screw by using a screwdriver.
4. Loosen the lamp unit screw with a screwdriver. Then grasp the lamp unit, Figure 2, by the lamp unit handle and slowly remove it from the projection display.
5. Insert the new unit being careful being careful of the insertion direction. Press in the arrow mark making sure insertion is done correctly.
6. Replace the lamp unit and cover screw. Tighten the unit cover screw with a screw driver.
a. Properly dispose of the old lamp. Please see the operating instruction of the projection display unit.
b. NOTE: attached the lamp unit and lamp unit housing door securely. If the lamp unit and the lamp unit housing are not attached securely, the protective circuit will be activated and the lamp will not turn on.
7. Replace the front cover.
The second step, after lamp replacement is to follow the three steps procedure described below:
Warning: Perform lamp time reset only when the lamp has been replaced.
In order to complete the lamp time reset procedures:
1. Be sure the power cord is plugged into a properly grounded wall outlet. Then, press the POWER button the projection display or the remote control to turn the unit on.
2. While pressing the VOL - button, hold down the PIP or the SPLIT button on the remote control at the same time for more the 5 seconds.
3. When the reset procedure is complete, the projection display screen will show the following message "Lamp time was reset to 0."
Notes:
1. The writing in the screen may be different from the actual screen described above.
2. When lamp time reset is finished, the lamp indicator goes out.
OK.
Feb 23, 2011 | Panasonic PT-50LCZ70 50" HDTV
I replaced the lamp with the proper part #UX21513 and followed all instructions, but the lamp indicator is still flashing red and the TV doesn't come on. Is the lamp defective or is there a reset button...
There is no reset button for the lamp. My first resolution would be to unplug the TV, pull the lamp and try to reseat it. Sometimes the contacts are not perfect. Make sure that all panels and doors are closed as many units have a switch that must be activated with a pin on the panel and/or door. This would also keep the lamp from striking.
Also, some units have a default reset and that is done by pressing and holding the on/off button as you plug the power cord back in. Follow up with results.
Jun 30, 2010 | Hitachi 50C10E Lamp
Indicator lights on, no function, no fan, no lamp
Press the MENU button to display the "MAIN MENU", and then select "OPTION".
Press the ENTER button to display the "OPTION" menu, and then select "LAMP RUNTIME".
Press and hold the ENTER button for approximately 3 seconds.
The "LAMP RUNTIME" will change to "TIME RESET [POWER OFF]".
Turn off the power and disconnect the power cord.
This will reset the cumulative usage time for the lamp unit to "0".
Oct 11, 2008 | Panasonic PT-LB20U Multimedia Projector
Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jul 26, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
The unit powers on and off.
There is a short somewhere in the sweep Horizontal, or vertical, or the sweep power supply has a fault. not really a job for the consumer , unless you know about solid state electronics.
Sep 13, 2006 | Sony Grand WEGA KF60XBR800 60" Rear...
InFocus Proxima UltraLight X350 Multimedia Projector Logo
156 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
