Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Jams when you feed an original
When you feed five or six orginals one will not feed in past the feed roller. I have replaced the main drive unit the dev motor the feed tires, the sep pads and units,feed assembly, drive assembly,main board.
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    Throw it away
  • Leroy Elliott
    Did you replace the roller bracket?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 11 Answers
You need to replace the black plastic holder that the ADF roller sits in as they wear and the holes get oblong shaped and cause the rollers not to operate correctly.
Posted on Mar 22, 2009
Mx2600n is having paper jam BTW the black and white roller before the Fuser unit
There are a number of reasons why the paper would jam at registration. First off, if the paper is completely flat & straight it is probably a feed issue or paper detect issue. There are 2 little black photo reflectors before the rollers in the centre of the feed path. These sensors can get covered with paper dust & may need cleaning. Also try feeding paper from the manual feed tray & see if it jams. If you have jams from both cassette's & manual feed then its most likely a sensor of feed issue. If its from one tray only then the sensors in the vertical path may be dusty with paper dust or worn pick up & feed tyres. There is also an issue with the feed clutches in the paper pick up drive unit which can fail & have been upgraded.
Secondly, if the paper is Z folded at the registration rollers but before the fuser then it could be the primary bed drive gear. This gear also drives the secondary belt unit located in the right hand door assembly.
Hope this helps.
Dave.
Jan 11, 2017 | Sharp Mx2600n Color Copier, Printer,...
Canon ir 2018, my problem is after five five, six paper print then paper jam problem from pick up unit
Try cleaning the paper pickup roller, see if that helps.
If it is better, but still not perfect, fit in a new one.
Jul 31, 2015 | Canon Office Equipment & Supplies
Im using ricoh 2045..Paper jam occurs at point A1 (the lever the drops to remove the paper) . I have noticed roller A1 and registration roller doesn't rotate. When i remove the paper and close the covers...
this is not a thought I am 100% sure and give you the correct solution:
problem with the paper feeding section is dusty or due to developer drooping
1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
and drop the developer.
2. remove all paper trays with remove the four each screws
3. Remove the toner collection bottle
4. Remove the right side cover.
5. Remove paper left roller plate.(show in the picture)
6. Now remove the first tray paper feeding section(is a complete unit included paper feed rollers motor and clutch and gear section)
7. Clean the drooped developer from all gears and roller and motor section
8. remove the second and third tray paper feeding section and doing the same.
9. now fix it all
10. replace developer unit bush witch are faulty or if you don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer drooping on the gear good_help.pnggood_help_0.png
Jan 27, 2011 | Ricoh Aficio 450 Copier
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Konica 7025 paper jam
Does this happen when he orginals go thur the document feeder? How does the copy look if the orginal is placed on the glass. Vertical feed problem mite be dirty rollers or dirty clutch,
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
Dr 5010c feeds one to five sheets, then stops
Clean the rubber rollers (pickup and ******) with a damp cloth, loosen the papers to be scanned. Clean all the rollers in the scanning path. What is the eror that is displayed? Download the user manual from this site http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11293 (5010um.pdf). Change the rollers if they are old.
S. Mohan, Chennai, India
Apr 16, 2009 | Canon DR-5010C Scanner
Hp laserjet 8150 printer jams from tray 3
Check the rollers in tray 3 to see if they are slick. If not, replace the paper input unit C4214-69017.
Feb 19, 2009 | HP LaserJet 8150dn Printer
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
HP ALL IN ONE PRINTER
Follow these steps to clear paper jam
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it around so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you.
Figure 2: Removing the rear access door
  1. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  2. From the rear access door opening, remove the jammed paper.
  3. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  4. Reinstall the rear access door.
  5. Reconnect the power cord to the unit and turn the unit on.
Preventing paper jams
The following information will help prevent paper jams from occurring:
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Jun 19, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Printer malfunction
The samsung printer have three paper jam sensors. First (paper jam 0) after the feed rollers. Second (paper jam 1) at the left of the feed rollers and third (paper jam 2) at the fuser unit where it is hot. You can see the actuator between the two white rollers. Paper jam 2 is mainly cause by the scrappers out of position on the side of the upper heat rollers.You will have to clean it and put it back into position.
Dec 19, 2007 | Samsung ML-2150 Laser Printer
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
282 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
