Question about Toaster Ovens
I have a tabletop oven and I don't know how to use it Moulinex CTG 300. Fan-assisted oven and grill - very small
  • Anonymous Mar 07, 2009
    i need the cook book that comes with it can i get one some where
Where can I buy a replacement white George foreman drip tray? Thank you
Hi,I think if you have the papper work for the item there should be a part number on there some where,
or google g/f parts,I have one but have lost the book.
all the best
Mar 17, 2015 | George Foreman "" Grill With Bun Warmer...
How do I set a farberware t490c commercial tabletop convection oven to work
Try calling or emailing Farberware (distributed by Salton/MAXIM Housewares): faberware-electric@saltonusa.com OR 1-888-881-8101. Ask for Operating Manual
Dec 29, 2014 | Farberware T490C 1500 Watts Toaster Oven...
Free instruction manuals for prima super chef
Why not just ask someone to print one out for you?
If your Fagor Pressure Cooker or Commercial Cookware needs to be repaired, or if you have any questions in regard to the use and care of the product, please call the Fagor Cookware Customer Service Department at # 1-800-207-0806 (Monday to Friday from 8:30am to 5:30pm EST), or email us your questions to info@fagoramerica.com SERVICE CENTER LOCATIONS
Aug 08, 2014 | Fagor 12 Quart Halogen Tabletop Oven
Halogen tabletop oven
You can use any oven-safe dish that will fit inside the oven (preferably, with the low rack in place). I've seen 3 qt round casseroles that will fit when you aren't using the extender. (For example, this should fit: http://www.crateandbarrel.com/dining-and-entertaining/casseroles/lucerne-3-quart-casserole/s512853 ) Some casseroles are sold with non-oven safe lids. Make sure that you check the temperature range for the specific dish. Some are only rated to 400 degrees F.
Unfortunately, I do not know of any sources that sell the accessories separately.
I hope this helps.
Jun 03, 2013 | Fagor 12 Quart Halogen Tabletop Oven
Unusual screw head
take picture of it w/ phone or camera or anything u have thats digital. Take to lowes, or depot, or somewhere possibly that sells tools and ask sales person.
Aug 02, 2012 | Toaster Ovens
Need to buy replacement fan blade but I don't need the entire fan assembly. Could you help?
DON'T KNOW HOW OLD IS YOUR OVEN BUT IF YOU CAN REPLACED THE MOTOR AND FAN BLADE , ((PROBABLE ONE OR BOTH PART ARE DEFFECTD)) YOU MAY CONTACT SEARS THEY MAY GET THE PART FOR YOU CHECK IF YOUR OVEN HAS ANY WARRANTY CALL 1800-4MY-HOME JUST GET MODEL#
Feb 18, 2011 | Anvil COA8005 6600 Watts Toaster Oven with...
Whirlpool fan assisted oven - fan motor coil burning out
The PCB board is definitely at fault here. One of the dc voltage lines is transferring too much current. The regulator and resistors are probably compromised. The better option is to replace the board than to try and fault find the components.
please rate my help++++Thanks for using FIXYA
Jun 23, 2010 | Toaster Ovens
Burned out diode in GE 168970 toaster oven
Just clip the diode out (pay attention to the white band around the end) take the diode to radio shack and match it's size physically.Then put it back in using regular electrical solder (rosin core) put the band on the diode facing the same way it came out
Jul 24, 2009 | Toaster Ovens
Can you toast bread in it?
You turn on the grill part, set the temperature dial to high wait a few minutes then place the bread on the grill tray provided.
You will need to position the grill tray near the top of the oven because that is where the elements are.
The grill gets hot so you will need to use tongs or gloves to gain access to the bread
Keep a careful eye on the bread because unlike a Toaster it will not eject the bread when it is done and it will catch fire.
Quicker and cheaper to buy a purpose built toaster and use the other one for doing casseroles etc
Jun 16, 2009 | Dualit 89100 1500 Watts Toaster Oven with...
Toaster Ovens Logo
149 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Toaster Oven Expert? Answer questions, earn points and help others
