Question about Microsoft Zune JS8-00001 Digital Media Player
Zune will not play when charging
My Zune will not play when it is charging via usb. Is this normal?
  • ruth_waid Mar 09, 2009
    My ZUNE will not play in my CAR if it is charging on the USB connection.
  • 7 Answers
If your software is running on the computer it is. if the zune prograam is on turn it off and it will still charge and you can listen to it
Posted on Mar 09, 2009
How do i connect the naxa USB connection to another devise
that device does not support your zune via usb it would be best to use the aux jack and then plug that into the head phone jack.
Jul 10, 2012 | Car Audio & Video
My zune 120 will not power on. When plugged into the computer via usb, the computer doesn't acknowledge it. Three forms of charging and it just has a black screen
Your device's battery is damaged due to Overcharging or due to permanent loss of charge its better to change the battery of the device....
Aug 29, 2010 | Microsoft Zune JS8-00001 Digital Media...
My Zune 4gb won't sync with my software and will not charge
I had a similar problem with my 30GB Zune. The first normal solution is to make sure that the USB port is providing enough power to the Zune to charge it by trying a different port or computer, but since your other Zune charges it is likely not the problem.
Other possibly solutions are performing a hard reset on the Zune (hold back and up until it resets), or allowing the zone to completely discharge and try again. In my case, none of these solutions worked and I was forced to send my Zune in for a new battery, which Microsoft was willing to replace for free.
Jul 29, 2009 | Microsoft Zune JS8-00001 Digital Media...
Wont turn on
Your charger may be damaged, if the device is charged via USB, your USB port may be damaged / disabled, try an alternate USB port / computer, try an alternate charge of exact specifications.
Your battery may be damaged, the unit may be damaged. If your Zune is still under warranty, request an RMA from the manufacturer.
If it is NOT still under warrenty, please locate the nearest electronic componant repair shop, or remanufacturer
May 19, 2009 | Microsoft Zune120 Digital Media Player
Zune 80 GB - Won't Charge
i lost my drivers microsoft lifecam vx-1000
Feb 07, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Stuck on startup screen.
pull the case apart and pull the battery out for about thirty seconds. put it back in and back together and it should work.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Please help!!!!!!!!!!!!!!!!!!!!!!1
My Zune 30 is frozen. What should I do?
Follow these steps:
  1. Disconnect your Zune from USB and AC power sources.
  2. Because the player is frozen, its battery will drain—this is good. Wait until the battery is empty and the screen goes black. If the battery was fully charged, this might take a couple of hours.
  3. Wait until after noon GMT on January 1, 2009 (that's 7 a.m. Eastern or 4 a.m. Pacific time).
  4. Connect your Zune to either a USB port on the back or your computer or to AC power using the Zune AC Adapter and let it charge.
Once the battery has sufficient power, the player should start normally. No other action is required—you can go back to using your Zune!
Dec 22, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune won't charge
now what you do is if the zune just has a black screen with a battery symbol and it stays that way forever when on the charger. you, take the zune off the charger and press the play/pause button and if it turns on for a second with the low battery symbol then turns off, your in luck, just hold the play/pause button for 10 - 20 minutes. the zune will have turned on and off alot agitating the battery. once you hold it for 10 - 20 minutes put it on the charger, then presto it works. let charge fully then die completly for every time you use it for a bout a month to let the battery get back into it's normal cycle. ~Dan herzberg~ Thank you*
Feb 18, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
After charging it froze up!
I have the same problem, it is completely frozen and will not turn on or off even after I charge it. It appears to be completley frozem, help!
Aug 29, 2007 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
128 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
