FixYa.com
Tags:
IBM DS4800  Hard Drive Array
Exchange 2003 Cluster Recovery Options
By Green1 - usenet poster
I am trying to determine what my best course of action is to recovery my 2
node (a/p) Exchange 2003 Ent cluster to my DR Site.
The Exchange 2003 Ent cluster backs onto a SAN that is synchronously
mirrored to the DR Site SAN. We have a high bandwidth low latency network
between our production data center and DR Site.
We have a live AD domain controller at the DR Site. Redundant internet,
firewalls, hot servers.
So my question is, should I look at geographically dispersing my cluster? I
can easily span a VLAN across the WAN. Can I just pick up my passive node
and move it to the DR Site? Or would I need to add a 3rd node for the DR
Site?
Or my other option is to setup a standby cluster (single node) pre-staged.
I was thinking of running this on VMware though (I understand support may be
an issue in this configuration).
Anyhow any thoughts or comments would be appreciated.
Mike.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
pawa
pawa - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
" They'll also get stroppy if you're using SAN based replication"
There's a support policy for replication of Exchange data to contend with,
and most async replication isn't supported. Host based replication suffers
the same fate.
The only solution I can think of that is supported is async replication of
snapshots, because it's not live data. In Exchange 2007, MS introduced log
shipping which is one way out of the support quandry. If you're still on
2003, look at the October 2006 issue of Technet Magazine.
It's basically a standby cluster with async replication of snapshots.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Duke
Duke - usenet poster
Rating: 0%, 0 votes
There's the thing you see.
If you won't use VMware because Microsoft might pull the rug on you
you have to use something else.
Microsoft will pull that same rug with whatever 3rd party geographical
clustering option you choose, i.e. Veritas.
They'll also get stroppy if you're using SAN based replication.
Honestly, you're damned if you do and damned if you do it another way.
All you need to do is to see what your support people and/or vendors
can and will support and how competent & professional they consider
them to be.
Solution #3
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
True enough. Another way of looking at this is if you have a real and
serious requirement for Microsoft support you will probably have a
Premier support agreement. If that's the case then you are supported
by Microsoft when virtualised.
If you have VMware and like the idea of VMotion you can have a cast
iron assurance that your vendor or VMware (EMC) will support you to
the hilt, better than Microsoft will because VMware will ensure that
your problem is fixed without refusing at the 3rd fence and demanding
that you put it all on physical hardware and regenerate the problem
before going any further.
Personally I would rephrase Rodney's last two sentences (probably the
first and only time I would ever presume so to do) to read "You will
need support on Microsoft technologies at some point. Will your chosen
vendor fully support the technology they sold you?"
Solution #4
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
Assuming that support is an issue for me, then where does that leave me?
Run the standby cluster (single node, pre-staged) on stand alone hardware?
If that is the case should I not then look at the geographic dispursion of
my cluster nodes? That almost seems easier, assuming I can move the existing
passive node.
In that scenario (geo cluster) I am just not sure how fail-over would work?
Solution #5
Not Rated (0)
LiZzIe
LiZzIe - usenet poster
Rating: 0%, 0 votes
I am not sure how many teenagers drool over computer geeks, but... the lack
of Microsoft support is huge for some applications and organizations. I
would talk to your management before going that route. Exchange has issues,
as does every major application - you will need Microsoft badly at some
point. Will they support you?
Cheers,
Rodney R. Fournier
MVP - Windows Server - Clustering
# - Clustering Website
# - Blog
# - Cluster Training
ClusterHelp.com is a Microsoft Certified Gold Partner
Solution #6
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
VMware would be a great solution. Yes, support might be a drag from
Microsoft but your storage vendor and VMware themselves would drool
over you like a teenager at prom night.
Do you know about VMotion from VMware? You should and if you do, you
should be looking at using it.
Even if you don't use VMware the other solution that pops straight
into view is Veritas clustering. You ditch the 2nd node from your main
site and send it over to the DR location.
Your storage vendor is almost certain to have a Veritas specialist on
staff, it's part of their core business (ours has several).
Don't waste a moments thought of what Microsoft might say to you about
the virtualisation path though. The other vendors will take real good
care of you.
Can you Help with these Network Storage problems?
Network Storage
telefunken ttv-29tb pincushion
I have the above tv and the... Answer This...
Network Storage
external drive just stopped...
First, Windows warned that a... Answer This...
Network Storage
transferring files from...
I recently purchased the Antec... Answer This...
Network Storage
DNS-323 ACCESSING A NETWORK...
I have made a few attempts in... Answer This...
Network Storage
Trouble with Simple Share 250
posted by Kb2MSE on Jun 24,... Answer This...
Repair Service
Find Network Storage Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
