Question about LG CHOCOLATE VX8500 Cellular Phone
Navigation Wheel Center Button Doesnt Work
The center button on the navigation wheel won't work unless i pop the wheel out. I cant select pictures or go to the menu or even reply to texts. I've tried turning my phone off then on again, and I took it to Verizon. All they did was spray it and brush it to try to clean it. Nothing has worked so far. Does anyone know how to help?
  • Anonymous Mar 11, 2009
    center button does not work at alll
  • Anonymous Apr 10, 2009
    my center button will not work
    Problem Solver:
  • 19 Answers
Sometimes what happens is that the receptor in the back of the device gets corroded (or sticky from kids) and it causes the buttons not too work fortunately if a Verizon Wireless is unable to see any physical damage they should warranty replace the device without any problem, and even if your device is out of warranty they offer a replacement for 50 dollars which is still cheaper than having a cell phone repair tech actually fix it for you, if the store will not do it for you call the customer service 800-922-0204 and they will change it for you. hoped this help!
Posted on Mar 05, 2009
My samsung juke phone won't work. If I take out the battery and charge it, the screen will flash. The second I press the prongs together, it stops working.
You may need to reset the phone, but it will delete everything on the phone. You may follow the steps below:
  1. From the main screen, press the center of the navigation wheel to choose Menu.
  2. Select Settings & Tools then press the center of the navigation wheel to choose OK.
  3. Select Phone Settings then press the center of the navigation wheel to choose OK.
  4. Select Security then press the center of the navigation wheel to choose OK.
  5. Enter the lock code then press the center of the navigation wheel to choose OK.
    The default lock code is the last 4-digits of the mobile number.
  6. Select Restore Phone then press the center of the navigation wheel to choose OK.
  7. Select Yes to confirm then press the center of the navigation wheel to choose OK.
Jul 26, 2016 | Samsung Cell Phones
Tip
Chevrolet Truck Steering Wheel Removal Instruction
1 Turn the steering wheel from side to side until it locks into place. This will make the process a bit easier, as the wheel won't be turning as you work.<br /><br />2 Remove the horn button in the center of the steering wheel by pulling it off towards you. This will expose the steering wheel nut at the center.<br /><br />3 Unbolt the center bolt from the steering wheel, using the 1/2-inch ratchet, extension and socket. This might free the steering wheel right away, but most likely you'll have to proceed to the next step.<br /><br />4 Position the steering wheel puller on the steering wheel such that the center bolt on the puller is on the center shaft of the wheel. Then thread in the bolts supplied with the puller into the two threaded holes on either side of the center shaft on the wheel.<br /><br />5 Tighten down the center bolt on the steering wheel puller using the 1/2-inch ratchet and socket until the steering wheel pops free. Then remove the steering wheel puller from the steering wheel.
on May 28, 2011 | Chevrolet 1500 Cars & Trucks
How do i get my phone to send pic messages it just says invalid destination address every time i try to send a pic message?
This is from the following link: http://www.verizonwireless.com/support/knowledge-base-83298/To
Take and Send a Picture via Messaging.
  1. From the main screen, navigate: MENU > Media Center > Picture & Video.
    Utilize the 5-way navigation pad to highlight and the center button to select.
  2. Select My Pictures.
  3. Select a picture then press the right Soft key to choose Options.
  4. Select Send.
  5. Select Picture Message.
  6. Enter the 10-digit mobile phone number or email address then select OK.
  7. Select SEND.
To send an existing picture this is from the following link:
Send an Existing Picture via Messaging Samsung Convoy Convoy 2
Send an Existing Picture via Messaging - Samsung Convoy™/ Convoy™ 2
  3. Select the picture then press the right Soft key to select Options.
  4. Select Send.
  7. Select SEND.
Mar 03, 2016 | Samsung Convoy Cell Phone
Forgot password
remove my passward in my cell
Jun 02, 2011 | Samsung SCH-U470 Juke Cellular Phone
My sansa e260's navigation wheel lights up but the screen is blank. what do I do . It may be the battery is completely dead. Bob L.
Your battery is not dead because if it was, then navigation wheel would not be lighting up. Your screen is blank because when you touch the navigation wheel, you probably decrease the brightness of the screen. Turn the wheel counterclockwise, as this will brighten up the screen display. Press the center button when done. Reply back if this solution does not help.
Mar 04, 2011 | SanDisk Sansa e260 MP3 Player
2005 Jeep Grand Cherokee Navigation Issue The
Look on ebay for an REC Joystick replacement. In the mean time you can hold down the middle button on the right side of the back of the steering wheel, where you can control the radio features. When you hold this button down, a little red wheel symbol appears on the navigation screen which means you can control the navigation system from the steering wheel controls. This works for simple tasks until you get the replacement joystick. They are about $30 and take about an hour to install.
Dec 09, 2010 | 2005 Jeep Grand Cherokee
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Accidently changed my language feature to spanish -can't figure out how to change it back to english-please help
Change the display language from English to Spanish or vice versa using the
Language menu.
1. From the main screen, press the Center Select key ( ).
2. Use the Navigation wheel to highlight Settings & Tools and press the
Center Select key ( ). (It's the last option)
3. Press Phone Settings, #5
4. Press Language, #4
5. Use the Navigation wheel to select English or Español, and press the
Oct 22, 2009 | Verizon Communications Samsung Juke Cell...
Center button and click wheel not working on my ipod nano
Yes, well the exact thing it happening to me. What you could do and see if it works is this: Turn the Screen Lock on, off, and hold the center button and the Menu button. This will hard reset the iPod and use the origonal settings from when you first got your iPod. The second Tip: Take off all of the software, songs, games, ect. in iTunes and reset ALL the settings in iTunes. If this doesn't doesnt work (which it should), your iPod is broken and you need a new click wheel or center button.
Mar 27, 2009 | Apple iPod nano
How to send picture msg
Here's how send a picture in a message.
1. Press the Center Select Key
2. Press the Navigation Key to scroll to Messaging, and press the Center Select Key
3. Press the Navigation Key and scroll down to Create Message, and press the Center Select Key
4. Press the Navigation Key and scroll down to New MMS Message, and press the Center Select Key
5. Press the keypad to enter desired text
6. Press Options, by pressing the left soft key
7. Highlight Insert, and press the Center Select Key
8. Highlight Picture, and press the Center Select Key
9. Press the Navigation Key and scroll up or down to the desired picture
10. Press Insert, by pressing the left soft key
11. Press Send To, by pressing the right soft key
12. Press the Navigation Key, and scroll down to desired contact, and Press the Center Select Key
13. Press Send, by pressing the right soft key
You can find this, and other helpful stuff at
this page on the Motorola Support site
Don't forget to rate this solution once you've tried it !
Apr 17, 2008 | Motorola Mobility SLVR L7 Cellular Phone
LG CHOCOLATE VX8500 Cellular Phone Logo
385 people viewed this question
Top LG Cell Phones Experts
IT Solution
IT Solution
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
