Question about Oreck XL2600 Vacuum
My Oreck beater bar is not turning. The bar is free of hair or strings, the motor is working, just the bar will not move
  • 328 Answers
If the motor is working then check the drive belt. There's a door on the right hand side of the Oreck that comes off with a cross head screw. Check the drive belt isn't broken. If its intact then its a possibility that the beater bar has seized up - beater bars from Oreck are available although you should check EBay to see if you can get a cheaper part. Sounds like a drive belt problem though.
Posted on Mar 06, 2009
Beater bar wont turn replaced belt didn't fix the problem
you may have to take the beater bar off and clean out the hair,and string off of both ends, thats where the bearings are.
Jun 21, 2015 | Eureka 5856BVZ Boss Bagless Upright...
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
Kenmore canister power head not working?
Without more info, I would investigate the drive belt, make sure the beater bar is free to spin (no hair or carpet fibers twisted onto the moving parts), and then check that the power is getting to the motor of the power head. Most often it is hair/fibers that collect around the ends of the beater bar. This causes the belt to stall, heat up and stretch due to the drive motor shaft spinning on one spot because the belt can't move. After removing twisted hair/fibers, you probably only need to replace the belt.
Aug 08, 2014 | Kenmore 25614 / 25615 Progressive Bagged...
Beater bar
It could be your brush bar is not working properly if there is debris restricting the endcaps, the brush bar motor could be defective, it could be a switch or wiring problem.
Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brush roll won't turn only a few times
Shane:
Unplug the machine and lay it on it's back with the handle release in the release position (the vacuum head should be laying flat also). Remove the foot plate from the vacuum head. Manually turn the brush roll (called a beater bar). The beater bar should turn fairly easily and the belt should turn the motor armature shaft (now would be a good time to check the inside surface of the belt for grooves or damaged spots which would cause the armature shaft to slip on the belt). If the beater bar has too much resistance to your turning it, I would suspect that the bearings at each end of the beater bar are fouled with hair, carpet fibers and string. Remove the beater bar from the machine and manually spin the motor armature shaft (where the belt contacts the motor) to see that the motor armature shaft spins freely. Remove the bearings from the end of the beater bar (they won't come off easily so you may have to use a prying tool such as a screwdriver). Try to spin the bearings. If they are fouled, dribble some rubbing alcohol into the bearing (I use a spray bottle... it's much neater) and turn the bearings while keeping them soaked with alcohol until they spin freely without ratcheting. Drop some 30 weight engine oil into the bearings until they are saturated, then clean the outsides of the bearings with a clean rag (no alcohol) until the outsides of the bearings are completely dry and no oil drips out of them (don't want the oil to attract dirt). You'll probably need to replace the belt. Reassemble the machine and it should work for you.
Jun 07, 2013 | Oreck UPRO14T - Vacuum Upright Commercial...
When I use the vacuum it smells like something burning but it does work. How do I fix this? Thank you Sharon Post
Hi ssharonxxx...
Sounds like you have hair,strings,debris caught on the beater bar and it is causing the belt to burn on the beater bar or motor.
Remove the bottom of your vacuum and clean,oil and replace the beater bar, that should solve your burning smell problem.
Please take time to rate me thumbs up
Sep 14, 2011 | LG Electronics Kompressor Pet Care Upright...
A smell like burning rubber comes out of the vents whenever it is used. It starts as soon as the vacuum is turned on. I've emptied the filter, but maybe I need a new one? I don't think the suction...
Hi sevillekathe...
The problem is that you have is that hair,strings,etc has gotten wrapped around the beater bar of the vacuum and it is trying to slow down the motor but the motor will not slow down so the smell you smell is the belt burning up because it is slippling and creating smoke and smell
You will need to remove the beater bar from the bottom of the machine and clean the hair,strings,etc from around the bearings on each end of the beater bar.
Also check your filter bag, check the hose going to the vacuum if you have one for blockages, and once you have the beater bar off check your belt condition and look for blockages going to the bag.
Aug 30, 2011 | Dirt Devil M083405 Versa Power Stick Vac...
Beater not turning but belt good. beater motor not turning but turns manually
Hi Dan:
check both ends of the beater bar. Pet/Human hair, thread, strings and even dirt can really get wound up in between the plastic ends and the bar. It might look ok but it won't turn effortlessly. If you find that is the case, you might be able to fish the junk out but from experience it's just better to buy a new beater bar or roller part.
Mar 12, 2011 | Electrolux EL8502 Versatility Bagless...
The motor spins but the belt will not move, therefore the rubber on the belt burns right where it is attached to the motor.
Sounds like your carpet beater roller is jammed up, probably with hair or string, in most cleaners you can remove the roller by taking the cover off below the brush. Remove the roller and clean wrapped uo stuff
Dec 06, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Brush won't turn.
Hi, W/D here.
You'll need to remove the base plate around the beater bar, and remove any hair that is around the ends of the beater bar. It tends to collect there, along with bits of string, ribbon, and such. When you're removing the hair, be aware of how the beater bar fits in the sockets that hold it in the vacuum frame; you have to replace them in the right way or the beater bar will rub.
Best regards, --W/D--
Aug 12, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Oreck XL2600 Vacuum Logo
1,084 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
