Question about Breadman TR800 Plus Bread Maker
I have an ~9 yo Breadman TR800 which works great, except the pan recently started leaking grease around the drive shaft into my dough. YUCK! The manufacturer no longer offers this in replacement but wants to give me a discount on a new model. No thanks! Does anyone know how I can fix this problem?
  • jkwbaum Mar 21, 2009
    These bread pans eventually all have this problem. I have the same machine, still works great. I've baked a loaf almost every day ever since we got it. Have gone through 4 or 5 pans already. Each one eventually developed the same problem. The seal at the bottom has a finite life and eventually no longer seals completely. So the axle grease gets pulled up into the pan.
    Can't even buy a replacement pan anymore (and Salton doubled the price for the replacement paddle). Found a like-new unit at a garage sale and got a new pan & paddle that way. Very unfortunate that Salton has abandoned this and eventually will force you to buy a new machine for lack of parts. The machine itself works great after 10 years of very heavy use - should be able to still use it until the machine itself dies.
You can put the flour first around the blender, and put water on the side. This way , it will not leak.
Posted on Jan 16, 2010
Tr800 replacement pan
ebay is a good source or try breadmachineparts.com
Dec 18, 2013 | Breadman TR800 Plus Bread Maker
The device on the bottom of the bread pan appears to be locked and will not turn to knead the dough. Is there anything I can do? It worked fine the last time I used it.
The synthetic seal around the shaft which DRIVES the paddle is fried.
I need a replacement to fit on the shaft OR if necessary 2 new shafts with NEW seals
Feb 28, 2011 | Breadman TR2200C Ultimate Bread Maker
The paddle keeps coming off during mixing and leaving a black stain in the dough
Hi, The sealed bearing located on the bottom of the bread pan has failed. This bearing is sealed with lubricant to allow the paddle shaft to spin easily. The black stain you see is the lubricating grease. You need a new bread pan. Hank
Jan 22, 2011 | Breadman TR2500BC Bread Maker
Bread pan pops out during the kneading 2 cycle
I had a similar problem after using the same machine for several years. It worked well for years and then popped off the shaft whenever I had a rather stilll dough. To solve the problem I bent the clips on each side of the bread pan that hold the pan into the machine up and toward the center of the machine. I did not use any tools to do the bending. It solved the problem. The pan no longer jumps up out of the clips and off of the shaft.
Jun 02, 2009 | Breadman TR2200C Ultimate Bread Maker
I have a Breadman Model: TR845. It seems that the gear in the actual machine that turns the knead paddle is striped. It turns when the pan is empty ... so I know it is working, however with dough inside or...
I had the same problem with my Breadman TR845 that I bought used at Goodwill. I made my first loaf O.K. then could not get the knead paddle to turn except when the pan was empty. I took it apart and discovered that the timing belt (flat belt with integral teeth) had slipped off the black plastic gear attached to the shaft of the motor. The belt was still around the shaft of the motor which allowed it to move the paddle only when empty. I needed a small spacer washer that would keep the black plastic gear from sliding on the shaft and allowing the belt to slip off. There is a lip only on one side of the plastic gear so it if moves the belt can slip off. I created a spacing washer from the cap on a tube of toothpaste. I cut the cap in half and had to use a metal file to get it the right size. I needed to be 1/4 inch tall and 3/4 inch in diameter. I cut the spacer so that I could slip it over the shaft. After putting it all back together everything works fine. And the toothpaste tube was almost empty anyway.
P.S. There are lots of screws that hold it together and the belt and gears are at the bottom of the Breadman and you have to take the whole thing apart to get to the bottom. I was able to leave all the wires attached so that putting it back together went quickly compared to the work of taking it apart.
Steve S.
Apr 27, 2009 | Breadman TR845 Bread Maker
Bread paddle for Breadman tr800
try http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Jul 20, 2008 | Breadman TR800 Plus Bread Maker
Breadman plus model tr800 instruction manuel
I can email you the instructions if you want.
Nov 10, 2007 | Kitchen Appliances - Others
Breadman TR800 Plus Bread Maker Logo
486 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
paul
paul
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
