Question about Garden
I have a 92 Toro riding mower with ignition problems. It recently stopped running while in use. Replacing the ignition switch did not solve the problem. I removed the spark plug, plugged the ignition wire back on it, and grounded it while cranking the engine. Very little to no spark was produced. I'm thinking that the Magnetic Coil is defective but it costs $140+ to replace. Is there another area that I should look at? Thanks, Bill
  • 6 more comments
  • Bill White
    Bill White Mar 06, 2009
    Thanks for getting back to me.
    The Model# is 32-12OE02, and the serial# is 1020311.
    Another observation I had when it would still run, was that when starting, I noticed some stray sparking on the right side of the engine under the hood. The only thing I can think of is the cable going to the starter. Never saw this happen before of since.
        Bill
  • Bill White
    Bill White Mar 09, 2009
    Mine has the Briggs & Stratton Engine, and yes, has a sponge filter.
       Bill
  • Bill White
    Bill White Mar 10, 2009
    Not sure if this is the right fix. The 'Coil' is a magnetic pickup from the flywheel and the magnetism is strong. Your part# 398811 @ $41.55 is different than the one I found on the Toro Web Site.
    My Engine/Motor Model# is: E125V-N/10964B. The coil part# listed by them is: NN10730 @ $144.10.
    However, I will try doing as you suggested. The wiring for the coil is thru a harness and has quick disconnects/shoe type.
    Thanks
  • Bill White
    Bill White Mar 12, 2009
    My apologies. I took a long and hard look and realized that mine is the Toro Power Plus, which is the 12.5 HP model. You got me going on that one and you're right, the 398811 is a briggs number. I remember seeing the Briggs name somewhere around the engine but when I looked again I could not find it. It is a Magneto powered plug.
    So I guess my question now is, how can I determine if the Magneto/Coil is bad?
    Thanks for hanging in there with me.
       Bill
  • Bill White
    Bill White Mar 19, 2009
    Hi again:
    The oil is fine. Don't know about the pressure switch.
    Anyway, I'm a bit lost when attempting to measure the resistance.
    I checked the clearance on the coil-module and adjusted it to .002.
    Your spec was .02, I am guessing that you meant .002.
    However, I did find that when grounding the plug to the top of the starter housing I was getting a constant spark. This tells me that the coil is doing its job in generating the spark. But it does not tell me why it won't  fire when the plug is installed.   Any thoughts?
    Thanks, Bill
  • Bill White
    Bill White Mar 23, 2009
    One final thing I tried was to disconnect the 3 clip-ons from the harness to the terminal next to the Magneto-Coil and crank it over with the plug installed. Nothing, so I tried different combinations and still nothing. At this point I think there is an internal problem with the harness or something. My only alternative now is to take it into a dealer and let them fight it.
    Thanks again for your help,
        Bill
  • dr1plain May 11, 2010
    They made that one with a Briggs and an Onan 1991 wich one do you have ? the briggs used a spong air filter .
    I'm a toro dealer I need the model # so I can see what you got.
    most of the time you ether have spark your you don't no such thing as week spark on the bigger engines .
  • 24 Answers
Unplug all wires to the coil if no spark it is a bad coil . the wire is used to ground out and kill eng.
coil part # 398811 $41.55
No voltage goes to coil .and it will kill if it does .
good luck
Posted on Mar 10, 2009
  • dr1plain Mar 11, 2009
    nn10730 is a onan part number, you told me you have a Briggs they use both on that model .
    The onan is a 12hp the Briggs was a 9hp 398811 is a briggs number .
  • dr1plain Mar 12, 2009
    Toro Power Plus 12.5/14hp Single Cylinder
    212-Series LT, 244-Series YT, 612-Z
    1. Disconnect the IP connector at the module.
    2. Disconnect the spark plug lead from the spark plug.
    3. Measure the primary coil resistance across the IP connector and the coil core. Primary resistance should be 1.0 Ohm.
    4. Measure the secondary resistance across the spark plug cable and the coil core secondary resistance should be 9.5K Ohm.
    5. If primary and secondary measurements are not as specified, replace the ignition module.
    NOTE: IGNITION MODULE TO FLYWHEEL MAGNET CLEARANCE. Measure the clearance between the ignition coil core and the flywheel magnet. If the measurement is not .020, loosen the module mounting screws and move the module to obtain .020 clearance.
    You have an oil presures switch on this unit some were wired to kill spark if oil is low . I will try and check if this one works that way.
    s
Drive belt runs off 42 Toro
HI, I have a Cub Cadet 50" cut I had a similar problem and I had to change the spring on the idler pulley it had lost tension and replacing it solved my problem. Not familiar with your mower but if it has the same principles as mine you might want to try that.
Jun 13, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
HOW DO YOU CLEAR A MAINTENANCE CODE ON A TORO LX468 RIDING MOWER?
Disconnect the battery for ten minutes. this is generally a universal method of clearing codes on electronic control modules. Hope this helps, plese post solved on fixya.com.So I get credit for a solved problem if it does. If not, check back and give me more info.
Apr 24, 2014 | Toro LX468 46" 22-HP Kohler Lawn Tractor
1989 toro 56127,7-25 riding mower
All you have to do is make sure that the connection if you have the old won . the switch has markings by each connector. You might have to switch the wires in the plug to line up with the proper connector on the plug. If you have questions let me know. Send me a pic of both switches with the connector view as close up as you can the better in need to see the markings and plug color of the plug cables.
Jun 22, 2013 | Garden
I have a Toro 16.5 riding lawnmower it stop and wouldn,t start back what could be my problem?
Battery charged? Bad fuel? Low on oil? 30w oil required. Clean carb. Check for improper ground on starting circuit. Ignition switch providing power to starter when key turned? Always use Stabile in gas. Remove bowl from carb ensure float is working properly. Float up no fuel flow, float down fuel flow. Ensure oil is full, low oil shutoff will not allow starting.
May 30, 2013 | Toro Lawnmower Lawn Mower SP Drive Belt...
Toro riding mower stopped cutting but still runs
Check if your drive belt has broken / come off the pulleys.
Also, if it has an electromagnetic cutter engagement, is it engaging the cutter drive?
Jun 17, 2012 | Toro Garden
My toro ride on mower cuts out after 45 minutes or so have to let it cool down for awhile before i can start it
Try this:
As soon as the mower begins to shut off, stop, keep it running, lift the hood and loosen the gas cap. If it begins to run better, clear the vent hole on the cap. If not, you have wasted very little time.
Gary
Feb 27, 2011 | Toro Garden
Needed a part for my mower ...old was on the part itself has BM35 and 701k , model number is E140V-C toro pt # is 92-5938 ....the part ssomeone sent me was 166-0832 it doessnt look the same .....at all...
Apparently the E140V-c is nnot the complete model number.
The two parts you listed are not the same. The 92-5938 is for lawnboy and toro and costs about 200.00 the 1660832 is for an onan and is about 40.00. It is best to work with the engine brand and model number the typoical gap is .010-.012 but depends on engine.
Aug 12, 2010 | Toro Garden
MY TORO RIDING LAWN MOWER CUTS OUT AFTER TAKING MY FOOT OFF THE BRAKE
sounds like the seat switch is faulty or blade engage switch is stuck down
try pulling wires from seat switch if continues to run with wires off faulty switch if not may be pto switch stuck down
have a look and check it sounds like a seat switch
cheers hope it helps
Aug 02, 2010 | Toro Lawn Mower With Toro Power Tools
I have a Toro 17-422 that stopped running because the 30 amp fuse blew for the ignition. Replaced fuse and when I went to restart the fuse blew again. With no electrical schematic it's hard to trace down...
It sounds as if the switch itself has a short circuit in it. First replace the fuse and pull the connector off the back of the switch and jump across the two large red wire connectors and see if it starts..
Aug 28, 2009 | Garden
I have a toro commercial self propelled, engine stops when I engage the self propelled. I t runs until then. What can I do to solve this problem?
Regularly check the wheel-drive belt on a self-propelled mower for wear and tightness .... "Affected engines may run rough, stall or bog down under load,"
Jul 22, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
878 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
