Question about HP LaserJet 5000dn Printer
I have HP 5000N Laser Jet print with "Close Top Cover" Error Message. I check (SW401) switch on and replace Terminal PCA (RG5-3560) and change/ check DCC Controller board(RG5-3517). I have check all my wire & cable. Both board in other HP 5000 I have.
  • 3 more comments
  • CE Hightower Mar 14, 2009
    Thank you for your help, but if you read the Error Message it say "Close Top Cover". I have check my Service Manual for HP 5000, Chapter 7, Table 7-5 Alphabetical Printer Message there and can't find it.
  • CE Hightower Mar 15, 2009
    I have check The Cover Assembly, I have 4 of them. But I did this one and other i have they all work
    I'll check this and Thank you
  • CE Hightower Mar 26, 2009
    Thank you for your help!!!
    POCBM May 11, 2010
    Is the error "Close top cover" OR "Open and Close Top Cover".?
    An expert whose answer gotĀ voted for 100 times.
  • 121 Answers
This may sound dumb but since you have another machine and have tested the switch and changed boards...have you tried swaping the top cover. I don't have a machine to look at or a very good picture but as I recall the part that activates the switch is on the cover maybe broken off or bent.
Posted on Mar 15, 2009
I have a HP office jet printer t45 with an error message c0030002, how can I fix this problem
Try this. Hope it will help you.
This indicates an obstruction to the print carriage. Turn off the power,
c003 xxxx
open the top cover, and look for something preventing the ink car-
(x = any
tridges from moving back and forth.
If the problem persists, close the top cover, turn on power, and open
the top cover again so the print cartridges move to the center. Remove
and reinstall both print cartridges. Close the top cover. Then remove
the power plug from the back of the HP OfficeJet, wait four seconds,
and plug it back in. If the front panel directs you to, realign the print
cartridges by pressing Enter and following the instructions on the
sheet that prints out.
For any error code not listed above, remove the power plug
from the back of the HP OfficeJet, wait four seconds, and plug it back
in. If the error code persists, contact Hewlett-Packard for assistance.
Oct 01, 2017 | HP Office Equipment & Supplies
10.10.00 supply memory error
10.00.00 SUPPLIES MEMORY ERROR alternates with For help press ? Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 00 = memory is defective
  • 00 = black print cartridge
  1. Turn the printer power off, and then turn the printer power on again to clear the message.
  2. If the message persists, go to this site for HP support ( .
  3. If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
  4. Turn the printer on again.
  5. If the error does not clear, turn the printer off and remove Tray 3.
  6. Turn the printer on and verify if the error clears.
If the error does not clear, contact HP support. reference site:
Another option would be: 1. Open the top cover, remove
the print cartridge, and
reinstall it.
2. Install a new HP print
3. Check the connection
between the
DC controller PCA
(location J97) and the
memory chip on the print
cartridge (location J600).
4. Replace the memory chip
cable and contact assembly.
5. Replace the
DC controller PCA.
kindly read this forum 1st:
Aug 26, 2011 | HP LaserJet P3005 Printer
Problem : 10.92.00 cartridges not engaged. The front door do not close probably I removed all cartridges the front door closed and the printers worked. Reinstalling the cartridges failed with same error...
10.92.00 The Black print cartridge are not engaged correctly.
? Open and then close the front door.
? If the message persists, make sure all the print cartridges are seated correctly.
? Clean the contacts on the memorycontroller PCA.
? Make sure that connectors J302, J303, J304, and J305 on the memorycontroller PCA are seated correctly. Also make sure that connector J1020 on the DC controller is seated correctly.
? Replace the memory-controller PCA if it is damaged.
? Check the gears on the print-cartridge drive motors. Replace defective motors.
? Replace the DC controller.
Aug 10, 2011 | HP LaserJet 3600n Printer
HP DesignJet 1050C stops printing - no error message
check all connectors on main pca. check trailing cables on carriage assembly. main pca may be bad.
Sep 08, 2009 | HP DesignJet 1050c plus InkJet Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
51.20 error message on HP laserjet 4250n printer
It is an error with the laser scanner unit
1 Press ( SELECT button) to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and dc controller
PCA (J83 and J84).
4 Replace the laser/scanner assembly.
See Laser/scanner assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
If nothing from above works and the printer is no longer in warranty, it is possible if the printer is being used in a very dirty or dusty enviornment that the lens and optics of the laser/scanner are so full of debris that the beam detect error occurs. You can remove the top cover and the big black box in the center is the laser scanner assembly. Remove the screws securing the top cover of the laser scanner and remove and clean up all the optics to include the main mirror in the front. I usually use a damp q tip and for the mirror I slide up from toner cartrdige shutter area and observe from the top as it cleans the mirror. Removing the complete assembly on this model is not easy since there are a couple of cables going to the dc controller which are difficult to remove so removing the top of the assembly is easier.
Here is the service manual:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | HP LaserJet 4250n Printer
52.00 error
Hp says you have a bad scanner unit(laser unit) or DC controller, but first reseat all your connectors on your scanner unit(laser) and DC controller. Your scanner is located under the top cover and the DC controller is located behind the right cover. If the problem still persist replace the scanner first.
Apr 23, 2009 | HP LaserJet 4350n Printer
HP lasrjet 4240n it won't print
The printer is unable to read the electronic information (e-label) on the print cartridge so that the printer can keep track of the page count for the print cartridge.
reinstall it.
between the
DC controller PCA
5. Replace the
DC controller PCA.
Sep 03, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
URGENT-- engine test problem in HP LaserJet 5000n
iam using hp5000n laser printer. It is giving 13.1 &13.3 error messages freequently. (This is paper jaming problem)
May 23, 2008 | HP LaserJet 5000n Printer
HP LaserJet 5000dn Printer Logo
101 people viewed this question
Ben Johnson
