Question about Kenmore 62722 Electric Dryer
Belt and assembly trouble. Please help!!
Kenmore 70 series electric dryer MOD: 101.62722101. TYPE: DWSR-ELE-2406028 - Ordered and recieved new belt, re-assembled dryer, turned it on and the belt started burning again. Is there a tension pulley i need to wrap the belt around? What exactly do i need to do to install the new belt? Please help!
-D
  • 496 Answers
Yes, there is a tension pulley but I"m at a loss as to how you're burning the belt, if not routed around the tensioner... seems to me you'd have a world of belt slack.
You might check and see if you can freely spin the drum, or if it seems to be locked-up. There may be an obstruction, keeping it from rotating... it shouldn't require so much effort.
Just a suggestion... Good luck.
Posted on Sep 01, 2009
  • 1214 Answers
SOURCE: Hello, and thank you for
Third from the last letter indicates the year built, which could be 1983 or 2002.
Posted on Feb 02, 2009
jan mczeal
  • 632 Answers
SOURCE: dryer will not start...checked belt and is
If the lid switch is defective, the washer will not function or work at all. It is located inside the washer main housing near the door frame. When you close the door, the switch is activated by an actuator. You have to raise or open the top or front panel of the machine to reach the switch. Replace if found defective.
Posted on Sep 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My dryer won't turn on
Make sure that the problem is not a broken belt, or a belt that has slipped off of the motor pulley or idle arm pulley.
Look to see if the motor is running first, sometimes you cannot hear the motor running but it is.
Also you can check your breakers to see if one is kicked out.
This problem can also be caused by a faulty start switch.
If this is not the problem than it may be time to call the repairman
  • 744 Answers
SOURCE: I have a broken broken belt but can't get
Make sure you have the correct replacement belt first. If you still have the old broken belt, measure it with a tape measure and do the same with the replacement. The new belt may be slightly shorter because the old one will have been stretched with use. Also check the part numbers again, but Kenmore changes numbers sometimes so that isn't always reliable.
The tensioners can be a little tricky sometimes. You can loosen it up if need be, then install the belt, hold the tensioner in place and tighten it back up. During re-installation, try to keep the belt as straight as possible around the drum so it doesn't take up more space, making it more difficult to install on the tensioner..
Posted on Jan 28, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Kenmore Series
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 13, 2010
My Kenmore 500 mod 110.69522800 type DWSR-ELE-2406026-FM54 start button wont turn it on. How do I fix this?
I will help you please contact me melissamaemartin@yahoo.com I have neen repairing appliances for 34 years
Feb 01, 2014 | Dryers
Have a Kenmore Elite Dryer that won't start. Mod 110.65962401 Ser MS0303258 Type DDOT-ELE-2406028-CV54
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2011 | Kenmore Elite HE4 Electric Dryer
My Whirpool dryer Mod. LEN 2000LWG, type DWSR-ELE-2406028-CV54, Imperial Series, was working fine, but after the second medium sized load it stopped drying the clothes. I finally noticed that the inside...
The Hum most commonly means that the drum belt on your dryer is probably broken
There is a simple way to test for this.
1 remove the clothes from the dryer.
2 put your hand inside the drum and turn it. If it is easy to turn, the belt is broken. If it is difficult to turn, the belt is good. You may be looking at motor problems.
Almost all of the time, it is a broken belt.
The link below has the full procedure for changing the belt.
Hope this helps,
Best Regards,
Mark
http://www.fixya.com/support/t6322596-get
Jan 19, 2011 | Whirlpool Dryers
Our kenmore dryer 600 series,model #110-67622600; ser #MUO91116; type: DWSR-ELE 2406028-CV54 less than 3 yrs old, lite comes when door opens, otherwise no action at all. drum turns manually, no clogs,...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 18, 2011 | Dryers
I have a Kenmore Series 70 Dryer. It starts but runs constanly never shutting off and not getting hot. Model number 110.62702181 Serial number MM0609310 Type DWSR-ELE-2406028- FM54
heatman101
Sep 13, 2010 | Dryers
Sep 26, 2009 | Kenmore Dryers
Dryer runs no heat
Sounds to me you either blew the fuse or tripped the circuit for the heating element. Try replacing the fuse or resetting the breaker before trying any repairs.
Jan 09, 2009 | Kenmore 64602 Electric Dryer
Kenmore 62722 Electric Dryer Logo
169 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
