The mic on the webcam goes crazy and a loud statis comes out randomly. I can't have mic on for long before that problem occurs, please help!
    President:
  • 8,637 Answers
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Posted on Mar 31, 2009
My problem is when I'm recording my voice and or just using my webcam I get a loud background noise, I didn't have this problem until maybe a week into having my webcam, can you please help me?
Make sure the webcam mic is set as default - especially if its a laptop which also has a mic.
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Your mic may also be picking up sound from your own speakers. To overcome this problem use a set of headphones.
Aug 12, 2010 | Logitech QuickCam Messenger Web Camera
Camera records loud background noise.
Ensure your webcam mic is set as default
Vista
TEST SPEAKERS
Restart computer
If the problem is due to feedback try using a set of headphones
Jun 06, 2010 | Logitech Webcam
I am getting a large amount of audio feedback (pulsing) when using skype and the logitech C500 webcam. The noise may not occur the first time I connect, but almost always occurs when I reconnect. Shutting...
You do not say if you are using a laptop with built in speakers or desktop with add on speakers. Also no indication of your OS.
I think the first thing you need to try is using a headset to cut out the possibility of 'feedback'
Check out your audio set-up
Typical audio set up
Laptop x webcam/mic x Vista x Skype
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Restart computer
CONFIGURE TO SKYPE
Start Skype.
On the Tools menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Set your speakers as default.
Select your webcam as the default microphone.
Click 'Save'
Dec 20, 2009 | Logitech Quickcam Chat Webcam
Echo occurs on voice chat
just down the mic volume and see als run the sound diagone test.
Sep 08, 2009 | Logitech QuickCam Communicate STX Personal...
My webcam works fine but the microphone crackles all the time
Feb 01, 2009 | Logitech Webcam
Mic problems
Go into the Control Panel and select Sound and Audio Devices.
Choose the tab Audio and then select under Sound Recording the Volume Button.
UNcheck any devices other than Microphone (checked). Also, put your microphone level midway.
See if that helps.
Nov 20, 2008 | Microsoft LifeCam VX-6000 Webcam
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Nov 24, 2007 | RCA RT2760 System
Help please
check the settings on your msn that the input is set to the mic and also on the sound in control panel that input is set to labte mic
Sep 30, 2007 | Labtec Webcam Pro
Computers & Internet Logo
170 people viewed this question
David Payne
David Payne
