Question about Acer Aspire 4315-2963 Notebook
Noisy fan the fan is noisy when it comes on it runs for about 5-10 seconds the goes off the when it runs again its a wee bit noisy is it about to go tried removing dust which there was a wee bit of fluff.
    Sergeant:
    Champion:
  • 224 Answers
I believe your laptop needs to be serviced. if you see dust and fluff, it might damage the fan and would need replacement
Posted on Mar 05, 2009
My Neff U1721 bottom oven has just stopped working - the fan still works, although is a bit noisy - what could be the problem/
Sound like the element has burnt out but if your fan is also noisy it is probley running slow which may have caused the element to overheat and burn out so it would be a good idea to replace the element and the fan motor
Regards
Ian
Apr 20, 2011 | Neff U1721 Double circotherm Electric Oven
Noisy chpset fan on MSI KT2 Ultra-ARU
yes, go to Zalman.com and get a cooler if you mobo is out of warranty.
Feb 24, 2010 | MSI KT3 Ultra Motherboard
Buzzing fan on a Marshall mg 100 head
Try to remove the fan and look for the sticker on the back side where the wires come out.
Remove the sticker, underneath it there will be a small aluminium cap (sometimes there is no cap and the axis is readily visible when you remove the sticker).
Take the cap off with a sharp tool (it shouldn't require a lot of force to do it), now you should be able to see the fan axis being held in place by a small clamp - put a drop or two of machine oil in there, move the fan blades a little to make the oil flow past the axis into the bearing.
Reinstall the cap, put the sticker back in place, reinstall the fan and test it.
Sometimes this will make things better, but if it doesn't then it is only fair to replace the fan.
regards
Triarcuate
Sep 25, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Can someone help pls my hp dv6000 fan stopt working the one above the proccecer and i dint notice this untill i turnd it on and melted a wee bit off the plastic above the fan becouse of the heat strain...
dirt **** and old age is the reason for fan failer
replace the fan then turn on the computer again make sure if the fan has 3 wires you replace it with a 3 wire as it monitors fan speed
Jul 25, 2009 | Computers & Internet
Is Toshiba Satellite M35-S456 Worth Fixing Noisy Fan and DVD I/O error?
It does sound like the problems you have could be largely down to the fan not running freely and allowing the processor to run hot. There for a new fan unit may be required. However a little trick to find out if over heating is the problem. Place the lap top in to a refrigerator for a couple of hours then leaving it placed in the fridge with the door open see if it will operate normally while sitting in the fridge.
If it does then the over heating factor is confirmed there for a new fan unit will solve the problems. This somewhat unorthodox method has worked for me on more than one occasion Hope this helps
Sep 28, 2008 | Toshiba Satellite A135 Notebook
Vw corrado 1987 1800cc 16valve
if your fan is coming when you shut your car off then it is likly your fan relay or a bad ground.Does it overheat when there is flow through the rad(when your driving on highway)or is it in town.
May 26, 2008 | 1984 Volkswagen Quantum
1989 corrado 16valve
check and change thermostat, water pump, radiator and cooling fan.
Fan noise
Generally fans on lower end cases are fairly cheap. I've had several new ones that make lots of noise new. You can call the manufacturers tech support and mess around tryig to get a replacemet or you can just order an inexpensive replacement fan. Cyberguys is where I typically buy my replacements. http://www.cyberguys.com/templates/searchproducts.asp?categoryID=191
Sep 18, 2006 | Vtech 8870KL ATX Mid-Tower PC Micro ATX...
Acer Aspire 4315-2963 Notebook Logo
250 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
