Proscan sent us 2 new remotes for our tv which is less than 1 year old but they are the wrong remotes. They say they no longer make that remote or that model tv so we are SOL. Have tried an RCA Universal Remote but we need 4 digit codes not 5 digit. Company gave us 4 digit codes but they don't work. What now?
0382,0376,0361,0000 are the codes to check. If you wish to get more details, check this
site. Pull up previous posts
there. Setup code list and
setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and
two-digit code list are there. Check
the site with patience. Surely you'll
get a solution to your problem. Search
the site by 'Timeslide' option. It will
make search easy. Or, type in the brand
name to your device into its search box, and press "Enter"
SOURCE: RCA universal 3 digit remote code for diamond vision TV
turn on your tv.Then push the code search button until the led still ,when the led keeps on let go the button now push and release the tv button then push and release the power button until the tv goes off,when the tv turn off stop to push the off button now push the set button the code are already set on the remote control( you might got to push the off button almost 100 times or more until you get the right code for your tv.Good luck
SOURCE: universal remote codes
I found the following web site which lists the codes for the RCA SystemLink 4 RCU400C universal remote. It's http://www.thompsontv.com/rcarc.html.
SOURCE: lost my manuel "codes" to my rca universal remote control crk74ba3
magnavox codes, 11454, 10054, 10030, 10706, 11990, 11963, 11944, 11931, 11904, 11525, 11365, 11254, 1198, 10802, 13=0386, 10230, 10187, 10186, 10179, 10096, 10036, 11028, 10024, 10020
SOURCE: need codes for rca universal remote rcr312w. for apex tv
With your model number at hand, check the RCA website for a later code list.
If you are the exception, you might find one.
Most all remotes have a 'search' function that lets you scan through all of the available code sets but this feature will, in most cases, provide only minimal functionality such as Power, Volume and Channel.
In truth, there isn't any such thing as a 'universal' remote, including the 'learning' remotes; I have one of those and it is unable to 'learn' from either of my later sets' remotes.
At best, these should be called (honestly) 'multi-brand.'
