Samsung hl-s6187 keeps turning itself off after a while of use, lamp light in front of tv turns green for a second or two then turns off ? is it a bulb issue ? or a cooling fan issue ?
  • 4 more comments
  • ddneu Mar 05, 2009
    samsung dlp tv keeps turning itself off after watching for a while . is this a bulb issue or a cooling problem ? answer posted was not very good ? check what again ? tv continues to turn itself off after being watched for a while
    tv about 3yrs old , no bulb has yet to be replaced , i have noticed on the right side of the front of the tv to be a little darker (first 3 inches of the right side of tv)when looking at the back of the tv , the light that reflects out doesnt appear to be an even light (looks weak on one side ) how many bulbs are with this tv hl-s6187w samsung
    if its a cooling issue , could it be dusty and clogged ? or do they just wear out ? also is this something that is easily fixed ? or do I need to bring someone in ?
    ok a bit confused , one reply says cooling fan issue another reply says replace the bulb and that tv only has one bulb
    bulb timer ? how and where do i reset it ?
    still one person says cooling issue another says bulb
  • 154 Answers
Turn off the tv and check it again.
Posted on Mar 05, 2009
  • crysiszone Mar 05, 2009
    its most likely to be transformer issue, its getting heatted up due to which the tv turns off after while.
    Scholar:
  • 162 Answers
It is prob caused by a bulb. how long is it since you have relaced it? if you are looking at more than 12 mths? if so then it is usually a safe option that it needs changing. also if you have recentley changed the bulb then you will have to reset the bulb timer which on some models can also turn system off for safety reasons. hope this helps
  • scott rimmer
    scott rimmer Mar 05, 2009
    hi sorry i should have been more specific. if you go onto the menu option if that is your screen stays on long enough and look for setup options as there will be an option within that counts how many hours the bulb has been working for. if you find this then you can reset it and find out if this is the only problem but im saying that if its been over two years like you say since the last change then you will almost definitley need an new one although i admit that as one of the above solutions suggesting cleaning it will not do no harm due to static. if the counter does nothing or you cant see screen image due to prob then you should look at the unit for exernal out socket and plug into secondary screen as they all have the ability to show duel screens through usually rgb connetion white red and yellow connections.
    Sergeant:
    Champion:
  • 224 Answers
It is a cooling fan issue as when it heats up, the fan cannot cool it down. Hence to protect itself from causing any damage, it turns off.
  • Shakeel Muradali
    Shakeel Muradali Mar 05, 2009
    Cooling fans wearout when there is a dust factor involved. In my experience, 90% of these fans wearout due to the dust or lint.
  • 10,594 Answers
How old is this TV and have you replaced its Lamp?
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics Mar 05, 2009
    It is DLP TV and have one bulb inside. You can replace it by yourself and Bulb (lamp) is available in Part Store.
    Your Tv is not old fashioned rear projection TV that has 3 picture tubes at rear. It is like multimedia projector, 3 LCD to make an image and use Lamp as light source. It calls..DLP TV
    Regarding fan issue, if fan is defective then TV will work for little time until it got high temperature and then goes to standby.
    If lamp is weak or dead, TV will not boot up or show any screen and immediately goes to standby.
    I would request "Computer Experts" to please stop responding TV issues, if you have No Real Experience of TV Repair.
    Your TV does not requires Bulb timer reset. Just replace its bulb and job is done.
    Thanks.
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
HL-S5086W turns itself off
if your tv is dlp. the blub is probably the cause. i have a r5087 and had same problem. replaced blub and set works fine
Nov 16, 2013 | Samsung HL-S5086W 50" HDTV
HI FOLKS, I HAVE A SAMSUNG HL-P5063W DLP TV THAT WON'T TURN ON. WHEN I PLUG IT INTO TO WALL I GET THE SOLID RED STANDBY/TEMP MESSAGE ON FRONT ON/OFF BUTTON. THEN WHEN I TURN IT ON, THE STANDBY/TEMP MESSAGE...
Bad Lamp Call FOX 1-800-227-5369 Lamp number is
BP96-00608A or BP96-00826A $109.00 Mats Electronics is another company for Lamps 1-800-628-1118 or Find one on E-Bay
Nov 30, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
210 people viewed this question
Top Televison & Video Experts
