Question about SanDisk Sansa Clip MP3 Player
Why won`t my sansa mp3 player work?
My mp3 player isn`t recognized by the computer even though i installed tehe driver from the cd it came with.
  • 54 Answers
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Posted on Mar 06, 2009
My computer won't recognize new SanDisk sansa clip. My computer won't read CDs, thus won't read the installation disk. Is there anyway to download what's on the CD so the computer will recognize the MP3...
Driver:
http://www.sandisk.com/sandisk-support/driver-download-wizard
Manual:
http://www.sandisk.com/sandisk-support/warranty-and-user-guides
Sansa Media Converter:
http://www.megaupload.com/?d=3IPZO6Q0
Dec 28, 2010 | SanDisk Sansa Clip MP3 Player
My computer does not seem to recognize my Sansa Fuze
Look exact model of a player and look the driver through search system. After installation all will work.
http://heaters.agilityhoster.com/
Aug 09, 2009 | SanDisk Sansa Fuze MP3 Player
Is there driver/ software for Win ME for the Sansa Clip mp3?
a friend told me that if the device shows as"connected" when hooked up (it does) AND the battery charges correctly (it does), then (a)the USB connection had enough juice; and (b) the PC recognizes it - i just had to FIND it. device manager/ MyComputer: nada; same for ANY file/ folder with "sansa" or "sandisk." working thru WMP (Windows Media Player), however, I discovered that drive E - for a portable hard drive, NOT currently connected via USB - was STILL showing up in the "Copy to CD or device" field. sure enough, it was the SanDisk clip player (even though it was NOT under the "Recognized Portable Devices" subsection). without using the installation disk at all, it downloaded tunes just fine. *note: the installation disk seemed to be an .exe file ONLY for the Rhapsody music service. as noted above, it was unnecessary. also - my USB ports are 1.1 and not 2.0, and package stated USB 2.0 was a "minimum requirement" - not true*
Jun 17, 2009 | SanDisk Sansa Clip MP3 Player
Installation cd won't load
If you have a Windows-based system (esp.Vista), grab the software directly from Sandisk's website. The software itself is not Mac-compatible, even though the computer may recognize the device when plugged in.
Mar 26, 2009 | SanDisk Sansa Clip MP3 Player
My sansa mp3 player isn`t recognized by the computer
It may depend on your operating system, but there are known issues in vista. There is also a hotfix from microsoft. This is from the Sansa Website FAQs at http://www.sansa.com/support/sansa_clip/faqs
My Sansa player is not recognized by my computer when I connect it.
The most common reason for this problem is not having the latest Windows Media Player installed, or having a Windows OS version that is not supported by the Sansa player.
The Sansa players support Windows XP SP2 and Windows Vista and above. If your operating system version is supported by the Sansa player:
SOLUTION 1 – Download and install the latest Windows Media Player
SOLUTION 2 – If that didn’t help, and you are running Windows Vista, apply the following hotfix - KB940199
SOLUTION 3 – If that didn’t help, download and Install the MTP Porting Kit (click here)
SOLUTION 4 – If that didn’t help, try connecting the device to the PC using MSC mode
On the Clip: Go to Settings > USB mode & choose MSC
I hope this helps and please don't forget to rate my answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
SANSA
My computer not recognise sansaclip
Jun 24, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e200 MP3
Did you try to plug the mp3 player in to the usb while the CD was in?
Jun 02, 2008 | SanDisk Sansa e200 MP3 Player
Sansa c200
To obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Thank you
Computerrep
Apr 18, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Cannot get my computer to recognize my Sansa e260 MP3 player
you only have to install the CD that came with your sansa in the box , after that it should recognize it
Dec 09, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
90 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
