Question about Ricoh Office Equipment & Supplies
Ricoh Aficio 1224c error code SC 544
Hi, nice people,
just after I changed the password of my Aficio 1224c, 2 min later a windows test came out, and hang before it was ready, this paper was no so dark as normal,
then I get this message ''code SC 544''
the printer button is red, and also a service key has light up also red,
what to do, I don't have the service manual to know where are the thermostats, and I don't know if it can be reset like the other products?
thank you for the help
greetings, Mo.
Well, I have no idea why changing your password would affect it this way. the code you're experiencing is a fuser warm up error, due to blown fuse, thermostsat, possible power supply prob...regardless, it can only be reset by a service tech in service mode once the problem is fixed. Sorry.
Posted on Mar 05, 2009
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
Mar 01, 2013 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
Hello i have ricoh aficio 1224c color . but the is have problem error sc792 . please help me best regards Salar
SC 792 :Finisher error .
The machine does not recognize the finisher , but recognizes the relay unit .
Possible causes :Defective connector
defective cable
incorrect installation
Aug 10, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh (Aficio) 1224c. code sc670 we want to decode this codesc670
Hi, it looks like a bad controller board. Try resetting it from in service mode with 7807. Also if you can view or printout the error history with 5990-004 for further trouble shooting. Hope this helps
Aug 03, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh aficio 1018d sc 544
Hello!
This code is related to a Fusing low temperature error.
You probably need to change Hot roller (or fusing rooler) and thermistors.
You can reset this code but it will pop-up again sooner or later.
The best advise i can give you is to call a technician (if you do njot have technical knowledge)
If you still want to reset the code tey this:
Press yellow key
Press in the key pad 107
Press red key at least 5 sec.
Exit all the way out.
Turn the machine off and on.
Hope this helps you
Aug 03, 2011 | Ricoh Aficio 1018D Copier
Ricoh 1224c Error SC-421 Please help
Hello!
Well, that is not an easy error. Your machine is detecting a short circuite in the discharge plate. It could be just a defective harness between the High voltage supply unit and the BICU.
So... The best advise i can give you is to call your technical support.
Jul 12, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh Aficio 1013 error code sc 544
Symptom: Detected fusing temperature
remained abnormally low for 1
second during fusing operation
(below 140°C) or during standby
mode
Possible Cause: Fusing thermistor defective
• PSU defective
• Bad connection between fuser and
machine
Dec 18, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
How repair error sc 590 in ricoh aficio 550
SC590: Toner collection motor error
-Definition- [B]
The toner collection motor sensor output does not change for 3 seconds while
the toner collection motor is on.
- Possible causes -
· Toner collection motor defective
· Too much load on the drive mechanism
· Poor toner collection motor connector connection
· IOB defective
· Toner collection motor sensor defective
Sep 06, 2010 | Ricoh Aficio 1224C Black and White Copier
Ricoh Aficio 1224C/1232C problem code SC 792
Hello sir; try to turn off and back on the machine to reset, if don't work next few steps need to follow;
1, press "clear mode" then enter 107 then press and hold "clear/stop" key until SP mode show up.
2, turn power off and back on .
Jan 09, 2009 | Office Equipment & Supplies
Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Jun 18, 2008 | Office Equipment & Supplies
1,574 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
