Question about Garden
How to adjust the high/low on pouland P3416, need a special tool?
No screws only a couple of pins sticking out.
  • 4 Answers
It can only be adjusted by a certified tech and has to be taken apart and set to factory specs.
Posted on Mar 11, 2009
I have just put in new carb an need help to do the settings
If it is a Zama carb, the set up procedure for a new carb is on line. Only problem is that with the new carbs you might need a special tool to adjust the low and high mixture screws. To get around this you can use a dremel tool to cut a straight groove across the head of the adjuster(s) so you can then use a flat blade screw driver.
Oct 28, 2015 | Husqvarna Garden
How to adjust zama carb
start with your screws turned in. adjust the high screw to 1 turn and the low to 1/2 turn. this should get unit running. once running then you can fine tune the carb
Oct 09, 2014 | Poulan P3416 16Inch 34cc 2Cycle Gas...
What is carburetor setting on a2.3 chainsaw
There is no fixed carburetor setting on these engines, just two screws to adjust low-end and high-end operation. Special tool may be required, there are about a half-dozen screw head standards. Check eBay for tool. Get the engine to run and idle fast (idle adjust) so it doesn't stall, adjust low-end screw so that engine doesn't hesitate or sputter when accelerated. Adjust high-end screw to run fast and smooth on full throtle. Readjust idle to normal.
Oct 28, 2013 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
How do you adjust the idle on th poulan p3314 gas chainsaw and is there a special tool you need it just wont idle
Most poulan chain saw have three screws idle, high, and low.. if you look air filter cover you will usually see three holes and the high and low will usually have plastic covers on it.. adjust the low 1/4 of a turn and the idle screw in about 1/4 or until the idle picks up... On the plastic cover where the three holes are you will see H which is High L which is Low and I which is Idle... Let me know if you have any problems.. thanks
Jul 16, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
I have a sears 27cc weedeater. I need to adjust the carb low and high but it looks like a female torx type of screw. What size is the female torx and where do i get the tool
unfortunately you have to order this special tool and it doesn't go by size but rather by name. It's a 2-stroke carb adjustment tool. find a small a small engine shop in your area and have them order one for you or you could do a google search for small engine repair speciality tools.
Nov 27, 2010 | Sears Garden
The screws do not have a flat head? How do I adjust the carb?
if you have plastic caps on the screws you have to pop them off to turn the screws. some screws have a slot and some don't.
for the one's that don't use a pair of needlenose plyers to turn them.
Jun 23, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Craftsman model 358.791042, gasoline weedwacker wont stay running
The high speed needle valve needs adjusting and it takes a special splined tool to adjust it. I currently am trying to find where I can purchase the tool to adjust the high and low carburator screws.
Mar 17, 2010 | Craftsman Garden
Need the jet adjustments for the high and low jets for a pouland wild thang 40cc chain saw
set them both at 1 1/2 turns out and then fine tune it when running. hope this helps you.
Oct 21, 2009 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
ToyotaHeadlightAllignment
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Oct 07, 2009 | 1995 Toyota Camry
Husqvarna 435 wot run at full speed runs at idle fine and looks like u need a special tool for the high low carb adustment
On that model the low adjustment may be factory set, and the adjustment screw is replaced with a roll pin. The high adjustment has a cover on it that can be prised free revealing the screw beneath. Turn screw all the way in (clockwise) GENTLY dont overtighten only to when you feel slight resistance on the screw. then back out 1 1/2 turns. This is the base setting. Turn at 1/8th turn either way until good high speed rev is obtained, but no further in than 1 1/4 turns out, or you will run the saw lean and cause damage. Check and replace your plug if fouled at all.
Feb 19, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
139 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
