Question about Canon PIXMA iP1600 Printer
Paper jam Non existant paper jam, and computer does not recognize printer
Unplug printer and open the front. Try taking out the cartridges and re-installing them. There could be a bit of paper stuck int here and then plug back in and run a test page
Posted on Mar 07, 2009
How do I fix a non-existent paper jam?
Sometimes there is a tiny bit of paper caught in the jam sensor mechanism that cannot be immediately seen. This is not uncommon and will cause repeated jamming and continuous jam indications. It takes a bit of detective work to locate it sometimes. If there is no paper, then the sensor may have been damaged by the jam itself. Most printers today are so inexpensive, it is almost cheaper to replace the while unit than to buy refill ink cartridges. That said, if you cannot locate the problem, get a new printer.
Sep 07, 2014 | Canon Pixma iX6520 Inkjet Printer 4895b002
How do I load paper into my Canon Pixma MX452 printer?
A lot of times the printer has a small piece of paper jammed in it or has had a jam and will not recognize the new paper. Try this to see if it resolves your issue.
Jun 25, 2014 | Canon Pixma MX452
Brother printer clear non-existant paper jam
There probably is one or a sensor is dirty would be the most likely culprits.
Jul 09, 2012 | Brother MFC-8460N All-In-One Printer
Mfc-7420 says paper jammed/ and no feeding paper -all faulse messages-no paper there jammed
This is a huge problem, not only with the MFC-7420 printer, but literally every printer known to exist! The best way to solve this problem is to look at where the printer is connected. If it's connected to your computer, it may be trying to print something from there still, causing the information that the printer is receiving to become jumbled up and confused. I'm going to go step by step to try to help you out of your printer misery:
First: Unplug the printer from your computer entirely. Then unplug your printer's power source.
Second: Re-plug back in your printer's power source, and wait for it to turn on fully.
Third: Double check to make sure everything is working fine aside from the non-existent "paper jam."
Fourth: Re-plug back in the printer to the computer, and cancel all scheduled prints that are queued on your computer.
Lastly: Retry printing!
Hope this helps.
Feb 24, 2011 | Brother MFC 7420 All-In-One Laser Printer
Make sure that all rollers in the paper tray is working properly. If not, then this might be the reason why your having this issue. Try calling your manufacturer to have it replaced, if it's still under warranty.
Dec 03, 2009 | Office Equipment & Supplies
Non-existent paper jam
There is almost certainly an optical sensor somewhere that either has a tiny bit of paper or dust in it. Try blowing dust out of the insides of the printer with a shop vac set to blow air out. Also try disconnecting/reconnecting the optical sensors throughout the paper path of the printer. Only do these things with the printer disconnected from everything.
Nov 01, 2009 | Dell 924 All-in-One InkJet Printer
The display says there is a paper jam, but there is none
Sounds like the printer need to be "reset"
Cancel all print jobs.
Disconnect the printer from your computer
Turn power to printer off and unplug it.
wait 1 min, then reconnect printer to your computer.
then plug printer back in and turn it on.
Start your print job over.
Should the paper jam suppossedly still exist, cancel the print job and run the maitenance program off the printers' menu that is stored on your computer.
Start print job again.
Should the problem still exist contact support at Samsung via the links on their homepage.
Good luck.
Oct 05, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Apr 17, 2009 | Epson Stylus C86 InkJet Printer
Paper Jam will not clear
  1. I have identical problem with the Xante 1200.
Mar 14, 2008 | Xante AW 1200 Laser Printer
Canon PIXMA iP1600 Printer Logo
old marine
old marine
