Question about Xerox DocuColor 240 All-In-One Laser Printer
Toner cartridge error
Toners from USA do not work on My Docucolor 250 which I bought from Europe.
WHY?
Please try to use your USA based chip placed on the toner cartrage and replace the same with the europe cartrage. It will work
Posted on Apr 03, 2009
  • Irina Filip Aug 25, 2011
    how can i do that?
Can Xerox DocuColor 3535 toner ink be used in Xerox WorkCentre 7228?
From experience, I wouldn't do it...
The different series usually have slightly different toner composition, so you may find that your copier will be majorly over-toned or under-toned. by doing that.
I personally wouldn't risk it, and I have been in the industry 24 years...
Oct 26, 2014 | Xerox Office Equipment & Supplies
Can you reset toner level in Xerox DocuColor 260?
Usualy what i did i use toner chip (100%) fix it to toner cartridge then insert to machine, check the amount if 100% then pull out the toner cartridge and replace old chip insert back to the machine, check it will be 75%.
Sep 05, 2014 | Xerox DocuColor 242-252-260 PS
Konica minolta bizhub c250 error C-2AO3
magenta toner cartridge EEPROM access error, cleaned the connection between the toner cartridge and the machine once cleaned if the issue persists remove the toner cartridge and put back in again if again the error persists replace the toner cartridge with a new one and last resort if the issue is still not fixed then replace the mechanical control board.
Oct 04, 2012 | Konica Minolta Minolta Konica Bizhub C250...
Invalid black toner replacement cartridges
Hi, Please make sure what version printer you got? USA version? or Asian version or euro version?
After confirm what version printer you got buy corect version CHIP or toner it will works.
Use any of other area toner will result toner invalded.
Regards
May 20, 2009 | Samsung CLP 300 Laser Printer
Black stain shadow from the same image print
a fault or an error has occurred see user guide for information on fault code 042-326  Docucolor 250
Mar 26, 2009 | Xerox DocuColor 12 Color Copier
Toner drum chip reset for xerox docucolor 250
dc250 crum reset solution done yes B Patel mumbai 09029222006
Jul 21, 2008 | Office Equipment & Supplies
Docucolor 12 error 9-356
That is a yellow toner empty message
Jun 09, 2008 | Xerox DocuColor 12 Printer
Docucolor 12 error code HELP
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Sep 13, 2007 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 240 All-In-One Laser Printer Logo
159 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
